Test11743 error [message #586492] |
Thu, 07 August 2008 02:25 |
RobertHua Messages: 58 Registered: July 2009 |
Member |
When I tested the test11743 ,the result was failed.The errors was
following:
[DEBUG][BuilderUtil.java:276] char set encoding set from default =UTF-8
[DEBUG][Wire.java:83] << "l version='1.0'
encoding='UTF-8'?><soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Client</faultcode ><faultstring>The
endpoint reference (EPR) for the Operation not found is
http://localhost:9080/axis2/services/xdsrepositoryb and the WSA Action =
urn:anonOutInOp</faultstring><detail
/></soapenv:Fault></soapenv:Body></soapenv:Envelope>"
[DEBUG][AxisEngine.java:116] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493]
receive:urn:uuid:6d65a064-0d60-7404-2132-001d7dab48a4
[DEBUG][Phase.java:269] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Checking pre-condition for
Phase "Addressing"
[DEBUG][Phase.java:282] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Addressing"
[DEBUG][Phase.java:289] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking Handler
'AddressingBasedDispatcher' in Phase 'Addressing'
[DEBUG][Phase.java:303] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Checking post-conditions
for phase "Addressing"
Phase "Security"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Security"
for phase "Security"
Phase "PreDispatch"
"PreDispatch"
for phase "PreDispatch"
Phase "Dispatch"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Dispatch"
'RequestURIBasedDispatcher' in Phase 'Dispatch'
'SOAPActionBasedDispatcher' in Phase 'Dispatch'
'RequestURIOperationDispatcher' in Phase 'Dispatch'
'SOAPMessageBodyBasedDispatcher' in Phase 'Dispatch'
'HTTPLocationBasedDispatcher' in Phase 'Dispatch'
for phase "Dispatch"
Phase "RMPhase"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "RMPhase"
for phase "RMPhase"
Phase "OperationInPhase"
"OperationInPhase"
for phase "OperationInPhase"
[DEBUG][Phase.java:315] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking flowComplete() in
Phase "RMPhase"
Phase "Dispatch"
[DEBUG][Phase.java:334] [MessageContext:
for Handler 'HTTPLocationBasedDispatcher' in Phase 'Dispatch'
for Handler 'SOAPMessageBodyBasedDispatcher' in Phase 'Dispatch'
for Handler 'RequestURIOperationDispatcher' in Phase 'Dispatch'
for Handler 'SOAPActionBasedDispatcher' in Phase 'Dispatch'
for Handler 'RequestURIBasedDispatcher' in Phase 'Dispatch'
Phase "PreDispatch"
Phase "Security"
Phase "Addressing"
for Handler 'AddressingBasedDispatcher' in Phase 'Addressing'
[ERROR][Source.java:196] Error sending SOAP message to the repository.
Error was Error Sending SOAP Message.
org.eclipse.ohf.ihe.common.ws.OHFSOAPException: Error Sending SOAP
Message. [Caused by org.apache.axis2.AxisFault: The endpoint reference
http://129.6.24.109:9080:9080/axis2/services/xdsrepositoryb and the WSA
Action = urn:anonOutInOp]
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:251)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:363)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:384)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:148)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:104)
at org.eclipse.ohf.ihe.xds.source.Source.submit(Source.java:193 )
at
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa11743.test(Mesa 11743.java:117)
at
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa11743.main(Mesa 11743.java:135)
Caused by: org.apache.axis2.AxisFault: The endpoint reference (EPR) for
urn:anonOutInOp
at
org.apache.axis2.util.Utils.getInboundFaultFromMessageContex t(Utils.java:486)
at
org.apache.axis2.description.OutInAxisOperationClient.handle Response(OutInAxisOperation.java:343)
at
org.apache.axis2.description.OutInAxisOperationClient.send(O utInAxisOperation.java:389)
at
org.apache.axis2.description.OutInAxisOperationClient.execut eImpl(OutInAxisOperation.java:211)
at
org.apache.axis2.client.OperationClient.execute(OperationCli ent.java:163)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:244)
... 7 more
urn:anonOutInOp]
at
at
at
at
at
at
at
urn:anonOutInOp
at
at
at
at
at
at
... 7 more
FUDForum. Page generated in 0.03574 seconds
