Home » Archived » Riena » Use Ridgets without the UI concept
Use Ridgets without the UI concept [message #583418] Fri, 11 September 2009 05:42
Originally posted by: eclipsixusenet.mmartl.dfgh.net
I am currently trying to setup an eclipse RCP application that has the
normal Eclipse look but is using Riena under the hood.
I am currently trying to build a view which is using Rienas ridgets.
I have created a View that extends SubModuleView<MyController> and
MyController extends SubModuleController
I have started to use this in the normal Riena UI and it worked like a
charm in there.
But now I am having problems to have the Ridget and the Widgets in the
View to work together after I have changed my application class to
startup a normal eclipse RCP application.
Can somebody tell me what I have to do so the Ridgets can be used in a
normal eclipse application?
Thanks!
Michael
Previous Topic:add filter to ridget
Next Topic:Use Ridgets without the UI concept
Current Time: Wed Nov 05 14:38:10 EST 2025
Powered by FUDForum. Page generated in 0.17135 seconds
