| Problem with the PingPong sample [message #583278] |
Tue, 08 September 2009 07:05 |
Originally posted by: imedlamouchi.yahoo.com
Hello Everybody,
I'm starting with eclipse RCP and I was interested in RIENA to develop a
client/server application, therefore I installed eclipse 3.5 Galileo, then
I have created a new target definition 'Riena' that I add Equinox Core
SDK, Eclipse RCP SDK, Riena Core SDK and Riena SDK Samples from the
Galileo software site. I Tryed the communication ping pong example as
indicated in the 'Getting Started' but that didn't run and I don't catch
where is the problem. Here the console output I got:
- Console output after starting 'Riena Sample PingPoing Server':
osgi> Tue Sep 08 09:49:14 CEST 2009 INFO [Start Level Event Dispatcher] null
{org.eclipse.riena.internal.core.logging.LoggerMill}={servic e.ranking=-100,
service.id=41} ServiceEvent REGISTERED
Tue Sep 08 09:49:14 CEST 2009 INFO [Framework Event Dispatcher] null
BundleEvent STARTED
org.eclipse.riena.internal.core.Activator No stage information set.
{org.eclipse.riena.core.exception.IExceptionHandlerManager}= {service.ranking=-100,
service.id=42} ServiceEvent REGISTERED
BundleEvent STARTED
org.eclipse.riena.internal.communication.publisher.hessian.A ctivator start
hessian support on server
{org.eclipse.riena.communication.core.IRemoteServiceRegistry }={service.ranking=-100,
service.id=43} ServiceEvent REGISTERED
org.eclipse.riena.internal.core.StartupsSafeRunnable Startup required
bundle: 'org.eclipse.equinox.log' already started.
org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration No
configuration given!.
{org.eclipse.riena.communication.core.progressmonitor.IRemot eProgressMonitorRegistry}={service.id=44}
BundleEvent STARTED
{org.eclipse.riena.communication.core.publisher.IServicePubl isher}={service.ranking=-100,
riena.protocol=hessian, service.id=45} ServiceEvent REGISTERED
BundleEvent STARTED
{org.eclipse.riena.communication.sample.pingpong.common.IPin gPong}={riena.remote.protocol=hessian,
riena.remote.path=/PingPongWS, riena.remote=true, service.id=46}
BundleEvent STARTED
{org.eclipse.riena.communication.core.publisher.IServicePubl ishBinder}={service.id=47}
Tue Sep 08 09:49:14 CEST 2009 DEBUG [Start Level Event Dispatcher]
org.eclipse.riena.communication.publisher.ServicePublishBind er
servicePublish=hessian REGISTER...no unpublished services waiting for this
protocol
org.eclipse.riena.internal.communication.publisher.hessian.H essianRemoteServicePublisher
published web service. protocol=hessian,
url=http://192.168.1.105:8080/hessian/PingPongWS,
interface=org.eclipse.riena.communication.sample.pingpong.co mmon.IPingPong
web service count: 1
org.eclipse.riena.communication.publisher.ServicePublishBind er service
endpoints count: 1
{org.eclipse.osgi.framework.console.CommandProvider}={servic e.id=48}
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
{org.eclipse.equinox.http.registry.HttpContextExtensionServi ce}={service.id=49}
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
{org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=50}
BundleEvent STARTED
{org.eclipse.core.net.proxy.IProxyService}={service.id=51} ServiceEvent
REGISTERED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
FrameworkEvent STARTED
FrameworkEvent STARTLEVEL CHANGED
- Console output after starting 'Riena Sample PingPoing Client':
osgi> Tue Sep 08 09:51:35 CEST 2009 INFO [Start Level Event Dispatcher] null
Tue Sep 08 09:51:35 CEST 2009 INFO [Framework Event Dispatcher] null
BundleEvent STARTED
BundleEvent STARTED
{org.eclipse.osgi.framework.console.CommandProvider}={servic e.id=45}
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
{org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=46}
BundleEvent STARTED
org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found
protocol [hessian]
org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @6295eb
Tue Sep 08 09:51:36 CEST 2009 ERROR [Framework Event Dispatcher] null
FrameworkEvent ERROR
org.eclipse.riena.communication.core.RemoteFailure: Error while invoking
remote service
org.eclipse.riena.internal.communication.core.factory.CallHo oksProxy.invoke(CallHooksProxy.java:71)
at $Proxy13.ping(Unknown Source)
org.eclipse.riena.internal.communication.sample.pingpong.cli ent.Activator$PingClient.sendPing(Activator.java:69)
org.eclipse.riena.internal.communication.sample.pingpong.cli ent.Activator$PingClient.serviceChanged(Activator.java:56)
org.eclipse.osgi.internal.serviceregistry.FilteredServiceLis tener.serviceChanged(FilteredServiceListener.java:124)Tue
Sep 08 09:51:36 CEST 2009 INFO [Start Level Event Dispatcher] null
{org.eclipse.riena.communication.sample.pingpong.common.IPin gPong}={service.url=http://localhost:8080/hessian/PingPongWS,
service.protocol=hessian, service.id=47} ServiceEvent REGISTERED
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:930)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:220)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:149)
org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.pu blishServiceEventPrivileged(ServiceRegistry.java:757)
org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.pu blishServiceEvent(ServiceRegistry.java:712)
org.eclipse.osgi.internal.serviceregistry.ServiceRegistratio nImpl.register(ServiceRegistrationImpl.java:129)
org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.re gisterService(ServiceRegistry.java:206)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:506)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:524)
org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry.registerService(RemoteServiceRegistry.java: 76)Tue
Sep 08 09:51:36 CEST 2009 DEBUG [Start Level Event Dispatcher]
OSGi NEW service registered id:
org.eclipse.riena.communication.sample.pingpong.common.IPing Pong
org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory.createAndRegisterProxy(RemoteServiceFactory.java:164)
org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory.createAndRegisterProxy(RemoteServiceFactory.java:129)
org.eclipse.riena.communication.core.factory.ProxyFactory.an dStart(ProxyFactory.java:68)
org.eclipse.riena.internal.communication.sample.pingpong.cli ent.config.Activator.start(Activator.java:48)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:330)
Caused by: com.caucho.hessian.client.HessianRuntimeException:
java.net.ConnectException: Connection refused: connect
com.caucho.hessian.client.HessianProxy.sendRequest(HessianPr oxy.java:263)
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.j ava:151)
at $Proxy12.ping(Unknown Source)
org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:69)
org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:38)
org.eclipse.riena.internal.communication.core.factory.CallHo oksProxy.invoke(CallHooksProxy.java:59)
... 31 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient (Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unk nown
Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream( Unknown
Source)
com.caucho.hessian.client.HessianProxy.sendRequest(HessianPr oxy.java:261)
... 40 more
Tue Sep 08 09:51:36 CEST 2009 INFO [Framework Event Dispatcher] null
BundleEvent STARTED
Tue Sep 08 09:51:36 CEST 2009 INFO [Start Level Event Dispatcher] null
{org.eclipse.core.net.proxy.IProxyService}={service.id=48} ServiceEvent
REGISTERED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
Your help is indeed very precious.
FUDForum. Page generated in 0.03252 seconds
