Possible to Pass Parameters To AGR Verification Hooks? [message #58840] |
Thu, 16 March 2006 16:18 |
Originally posted by: jhouston.bea.com
My use case is: I record a test case that creates a new file and I want
to be able to use the new file test case like a "method" in another test
suite's test behavior. I'd like to be able to add a verification hook
that can execute a file diff on the new file against a baseline, but the
baseline file will be different depending on the givn user input. Is
there any way to pass in parameters to the verification methods?
If not, is there a way to call into a verification hook without
requiring UI input? For example, in my test behavior I want to be able
to insert a callback to the underlying JUnit file without having to
launch the recorder. If this is possible (and there is a way to get the
test cases in a test suite's behavior to run in sequence) then it would
be possible to add specifica callbacks where "parameters" can be static
constants in the JUnit file.
Any help?
FUDForum. Page generated in 0.02562 seconds
