EAnnotation details [message #582795] |
Fri, 13 November 2009 06:21 |
I want to create an ecore.EAnnotation object with some entries in the
details ecore.EMap. The problem is, that the put method from ecore.EMap
could not be found...
thanks in advance
Enrico
My EWL file:
wizard createDataTypeObject {
guard : self.isKindOf(EDataType)
title : 'Create ' + self.name + 'Object'
do {
var o:new EDataType;
self.eContainer.eClassifiers.add(o);
o.instanceTypeName = 'org.eclipse.emf.common.util.Enumerator';
o.name = self.name + 'Object';
var a:new EAnnotation;
o.eAnnotations.add(a);
a.source='http:///org/eclipse/emf/ecore/util/ExtendedMetaData';
a.details.put('name', self.name + ':Object');
a.details.put('baseType', self.name);
the exception:
Method 'map' not found (...\Ecore.ewl@15:18)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:190)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:67)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:37)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:123)
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:185)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:36)
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.ewl.EwlWizard.process(EwlWizard.java:78)
org.eclipse.epsilon.ewl.EwlWizardInstance.process(EwlWizardI nstance.java:66)
org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.exe cute(ExecuteWizardInstanceCommand.java:42)
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction. execute(AbstractContributeWizardsAction.java:237)
org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$ 1.widgetSelected(AbstractContributeWizardsAction.java:225)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
FUDForum. Page generated in 0.03777 seconds
