Visualization Perspective causes NPE [message #582635] |
Sat, 07 August 2004 11:39 |
Originally posted by: comfortably007numb-python.yahoo.com
I am using eclipse 3.0.1 (build 200407281300) with AJDT 1.1.11 from the
update site. When I try to switch to the visualization perspective I
get the following error. I get a similar exception when I click on a
package when the visualization view is open. Has anybody else had this
issue? If so, is there a fix? I can try a development version of the
plugin if this issues has been addressed in it.
at
org.eclipse.ajdt.ui.visualiser.AspectVisualizerPerspectiveFa ctory.createHorizontalLayout(AspectVisualizerPerspectiveFact ory.java:104)
at
org.eclipse.ajdt.ui.visualiser.AspectVisualizerPerspectiveFa ctory.createInitialLayout(AspectVisualizerPerspectiveFactory .java:38)
at
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:658)
at
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:193)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:100)
at
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1148)
at
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:736)
at
org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:728)
at
org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2917)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2915)
at
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:87)
at
org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:303)
at
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:318)
at
org.eclipse.ui.actions.PerspectiveMenu$4.widgetSelected(Pers pectiveMenu.java:134)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:954)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2595)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2298)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
waiting for reply,
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
FUDForum. Page generated in 0.03205 seconds
