Model Elemenet Types: "!" vs. "::" [message #582450] |
Mon, 02 November 2009 18:35 |
I am totally confused on the real diffrence between the two model element types character separator.
I was doing a simple model to model transformation. I have 2 ecore metamodles, and an epsilon model. I made a simple etl rule to test the transformation and, following the Tree2Graph example, used the ! character to separate elements. I kept getting a "Typed not found error" so I decided to try with the :: separator. So now the elements of the input metamodel where recognized but the ones form the output one not. So I changed the one for the output to ! and it all worked out.
So... when or how to know when to use one or the other? Does it has to do with some property of the metamodel ?
Horacio Hoyos
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
FUDForum. Page generated in 0.02951 seconds
