Dali, Toplink (GlassFish) and DB2 [message #581903] |
Sat, 15 April 2006 21:02 |
Hi!
This topic is a little bit off-topic but I hope to get an answer from
the Dali/Toplink people here. ;)
I'm using Dali and generated some entities from existing tables. It's a
DB2 database. The problem is that I don't know how to set the DB2 schema
at runtime. When creating the connection in Eclipse Dali allowed to to
select a database schema (other than the default that belongs to the
user). However, I'm not aware of such an option in the persistence.xml
using GlassFish/Toplink.
The problem is probably because DB2 uses the user's schema as the
default schema. However the entity exists in a different schema on the
same db. Thus, a simple "select object(o) from Entity o" fails because
GlassFish is using the wrong schema.
I know that there is a property in Hibernate "hibernate.default_schema".
But I haven't found something similar in GlassFish.
Any ideas?
Thanks, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
FUDForum. Page generated in 0.04000 seconds
