e4 Testing with XWTTestCase [message #580818] |
Fri, 13 August 2010 22:45 |
St Clair Clarke Messages: 118 Registered: March 2010 |
I am attempting to test the following XWT UI:
<Composite
xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt"
x:Name="root"
xmlns:lang="clr-namespace:java.lang"
xmlns:demography="clr-namespace:biz.epims.reg.data.demography "
DataContext="{StaticResource religions}">
<Composite.Resources>
<demography:Religion x:Key="religions" />
</Composite.Resources>
<Composite.layout>
<GridLayout numColumns="2"/>
</Composite.layout>
<Label text="Religion" x:Name="religionsLbl">
<Label.layoutData>
<GridData horizontalAlignment="CENTER"/>
</Label.layoutData>
</Label>
<Label text="Christian Denomination" enabled="false" x:Name="christianDenomLbl">
<Label.layoutData>
</Label.layoutData>
</Label>
<Combo x:Name="religionCmbo" text="{Binding path=religion, BindingMode=TwoWay, UpdateSourceTrigger=PropertyChanged}">
<Combo.layoutData>
<GridData grabExcessHorizontalSpace="true" horizontalAlignment="FILL"/>
</Combo.layoutData>
<Combo.items>
<lang:String>African Traditional</lang:String>
<lang:String>Aetheist</lang:String>
<lang:String>Bahai</lang:String>
<lang:String>Buddhism</lang:String>
<lang:String>Cao Dai</lang:String>
<lang:String>Chinese Traditional</lang:String>
<lang:String>Christianity</lang:String>
<lang:String>Hinduism</lang:String>
<lang:String>Islam</lang:String>
<lang:String>Jainism</lang:String>
<lang:String>Juche</lang:String>
<lang:String>Judaism</lang:String>
<lang:String>Neo-Paganism</lang:String>
<lang:String>Primal-Indiginous</lang:String>
<lang:String>Rastafarianism</lang:String>
<lang:String>Scientology</lang:String>
<lang:String>Shinto</lang:String>
<lang:String>Sikhism</lang:String>
<lang:String>Spiritism</lang:String>
<lang:String>Tenrikyo</lang:String>
<lang:String>Unitarian-Universalism</lang:String>
<lang:String>Zoroastrianism</lang:String>
</Combo.items>
<Combo.Triggers>
<Trigger property="text" value="Christianity">
<Setter property="enabled" targetName="christianDenomLbl"/>
<Setter property="enabled" targetName="christianDenomCmbo"/>
</Trigger>
</Combo.Triggers>
</Combo>
<Combo x:Name="christianDenomCmbo" enabled="false" text="{Binding path=christianDenomination, BindingMode=TwoWay, UpdateSourceTrigger=PropertyChanged}" visible="true">
<Combo.layoutData>
<GridData horizontalAlignment="FILL" grabExcessHorizontalSpace="true"/>
</Combo.layoutData>
<Combo.items>
<lang:String>Christian denominations</lang:String>
<lang:String>-----------------------------</lang:String>
<lang:String>Anglican</lang:String>
<lang:String>Catholic</lang:String>
<lang:String>Evangelical</lang:String>
<lang:String>Jehovah Witnesses</lang:String>
<lang:String>Latter-day Saints</lang:String>
<lang:String>Orthodox</lang:String>
<lang:String>Pentecostal</lang:String>
<lang:String>Non-denominational</lang:String>
</Combo.items>
</Combo>
</Composite>
Here is my attempt at testing the religionCmbo:
import biz.epims.reg.ui.demography.ReligionForm;
import biz.epims.shared.test.XWTTestCase;
import java.net.URL;
import static org.eclipse.e4.xwt.IConstants.XWT_EXTENSION_SUFFIX;
import static org.eclipse.e4.xwt.XWT.findElementByName;
import org.eclipse.swt.widgets.Text;
class ReligionFormTest extends XWTTestCase
public void testReligionCmbo()
URL url = ReligionForm.class.getResource( ReligionForm.class.getSimpleName() + XWT_EXTENSION_SUFFIX );
runTest( url, new Runnable()
void checkTrigger()
Object religionCmbo = findElementByName( root, "religionCmbo" );
// assert religionCmbo instanceof Text
assertTrue( religionCmbo instanceof Text );
} // end method checkTrigger
public void run()
checkTrigger();
} // end method run
} // end method testReligionCmbo
} // end class ReligionFormTest
The url is correct.
However, it does not seem that the code in runTest ever gets executed and the test always runs without errors :blush: , something I fail to understand.
Please take a look at the code and let me know where I am going wrong.
St Clair
Re: e4 Testing with XWTTestCase [message #580964 is a reply to message #580818] |
Wed, 18 August 2010 21:39 |
Yves YANG Messages: 688 Registered: July 2009 |
If you can debug it, you can find the error in the line:
It should be a Combo
Best regards
Yves YANG
"St Clair Clarke" <st_clair@flowja.com> wrote in message
news:i44hua$9ok$1@build.eclipse.org...
> Hello,
> <Composite xmlns="http://www.eclipse.org/xwt/presentation"
> x:Name="root" xmlns:lang="clr-namespace:java.lang"
> <Composite.layout>
> </Composite.layout>
> <Label.layoutData>
> </Label.layoutData>
> </Label>
> <Label.layoutData>
> </Label.layoutData>
> </Label>
> <Combo.layoutData>
> </Combo.layoutData>
> <Combo.items>
> </Combo.items>
> <Combo.Triggers>
> </Trigger>
> </Combo.Triggers>
> </Combo>
> <Combo.layoutData>
> </Combo.layoutData>
> <Combo.items>
> </Combo.items>
> </Combo>
> </Composite>
> void checkTrigger()
> "religionCmbo" );
> public void run()
> checkTrigger();
> } // end method run
> The url is correct.
> understand.
> Thanks
> St Clair
FUDForum. Page generated in 0.02987 seconds
