Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Corrupt JAR, error while reading: midlet/MIDlet.class
Corrupt JAR, error while reading: midlet/MIDlet.class [message #580561] Sat, 22 May 2010 06:32 Go to next message
Hi everyone,
I finally managed to get around the compile errors, now its running the apps that is the problem. After SVN checkout it works fine, but after some code changes it just says
Installing suite from: http://127.0.0.1:60591/MIDlet.jad
*** Error ***
A problem occured during deploying application from http://127.0.0.1:60591/MIDlet.jad
Reason:
I've tried with many different J2ME projects that I have on my SVN repository, and most of them work after a clean checkout, sometimes i even have to remove my workspace to get it to work again. What Im i doing wrong? The the class is there, and everything in the build path is set up correctly. Im using J2ME SDK 3.0 with the latest version of Eclipse with MTJ on OSX (Snow Leopard)
I tried to google this, but no one seem to have a explanation of whats going wrong.
Please help me out here, I thought the switch from Ubuntu (where things like this never happened) to OS X would be easy.
Thanks in advance.
Re: Corrupt JAR, error while reading: midlet/MIDlet.class [message #580691 is a reply to message #580561] Tue, 01 June 2010 08:26 Go to previous message
just to double check. as far as i remember there was no WTK 3.0 for Mac (there is only support for vista and XP). is that the SDK that you are trying to use on Mac? on mac you can use the motorola sdk or some java based sdk such as microemu or mpowerplay
Previous Topic:iDEN Device problems
Next Topic:Missing features of MIDP 2.X/CLDC API (WTK 3.0)
Current Time: Wed Oct 29 07:21:00 EDT 2025
Powered by FUDForum. Page generated in 0.03101 seconds
