Re: Missing dependency on JSch when installing EGit on 3.5.2 [message #578757 is a reply to message #578742] |
Sat, 03 April 2010 07:39 |
Robin Rosenberg Messages: 332 Registered: July 2009 |
Jamie Penman-Smithson wrote:
> After updating to Eclipse 3.5.2 on Ubuntu lucid I'm unable to install EGit
> because it can't locate JSch:
> Cannot complete the install because one or more required items could not
> be found.
> Software being installed: Eclipse JGit Feature (Incubation)
> 0.8.0.201003292117 (org.eclipse.jgit.feature.group 0.8.0.201003292117)
> Missing requirement: JGit Core (Incubation) 0.7.1 (org.eclipse.jgit
> 0.7.1) requires 'package com.jcraft.jsch [0.1.41,0.2.0)' but it could
> not be found Missing requirement: JGit Core (Incubation)
> 0.8.0.201003292111 (org.eclipse.jgit 0.8.0.201003292111) requires
> 'package com.jcraft.jsch [0.1.41,0.2.0)' but it could not be found
> Cannot satisfy dependency:
> From: Eclipse JGit Feature (Incubation) 0.8.0.201003292117
> (org.eclipse.jgit.feature.group 0.8.0.201003292117) To:
> org.eclipse.jgit 0.0.0
> I've checked that jsch is installed:
> jamie@avior:~$ aptitude show libjsch-java
> Package: libjsch-java
> State: installed
> Automatically installed: yes
> Version: 0.1.42-1build1
> and the JAR is installed:
> jamie@avior:~$ ls -al /usr/share/java/jsch*
> -rw-r--r-- 1 root root 208590 2009-10-19 17:38
> /usr/share/java/jsch-0.1.42.jar
> lrwxrwxrwx 1 root root 15 2010-04-02 13:23 /usr/share/java/jsch.jar ->
> jsch-0.1.42.jar
> and that it's listed in the plugin registry:
> com.jcraft.jsch (0.1.42) "bundleName" [Resolved]
> org.eclipse.jsch.core (1.1.100.I20090430-0408) "JSch Core" [Active]
> org.eclipse.jsch.ui (1.1.200.r35x_20100210-1114) "JSch UI" [Starting]
We import the JSch stuff by package and version number and your version
of the JSch bundle does not export the packages with versions, which
is the recommended OSGi practice. Versions of EGit prior to 0.7 did not
require a specific version of JSch.
$ unzip -c /usr/share/java/jsch-0.1.42.jar META-INF/MANIFEST.MF|head
Archive: /usr/share/java/jsch-0.1.42.jar
inflating: META-INF/MANIFEST.MF
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 14.0-b16 (Sun Microsystems Inc.)
Bundle-ManifestVersion: 2
Bundle-Version: 0.1.42
Export-Package: com.jcraft.jsch, com.jcraft.jsch.jce;x-internal:=true,
com.jcraft.jsch.jcraft;x-internal:=true
Compare with the Eclipse packaging which has version numbers in Export-
Package.
Bundle-ClassPath: .
Bundle-Vendor: %venderName
Bundle-Localization: plugin
Bundle-RequiredExecutionEnvironment: J2SE-1.4
Bundle-Name: %bundleName
Bundle-SymbolicName: com.jcraft.jsch
Created-By: 1.4.0 (Sun Microsystems Inc.)
Export-Package: com.jcraft.jsch;version="0.1.41",com.jcraft.jsch.jce;v
ersion="0.1.41";x-internal:=true,com.jcraft.jsch.jcraft;version= "0.1.
41";x-internal:=true,com.jcraft.jsch.jgss;version="0.1.41";x-internal
:=true
Bundle-Version: 0.1.41.v200903070017
You should report this with Ubuntu as they are the ones providing the
packages,
-- robin
FUDForum. Page generated in 0.04130 seconds
