Command / Query / Advice (r10662) [message #577680] |
Tue, 22 September 2009 13:19 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
--------------040406000203020709080500
attached is the new model that describes commands (import a.k.a query,
and invoke). The model contains the description for advice.
This version is very much simplified as it uses a generic mechanism for
advice. Each advice is simply an advice to set a value of a particular
type (string, boolean, version, etc) with an escape mechanism to
instantiate any type.
The applicability of the advice is controlled via a PointCut (a
selection of resources where the advice should be applied), and a
featurePath in each advice that is a path relative to the selection made
by the pointcut to the particular item(s) that should receive the advice.
This should enable tooling to present/edit advice in a fashion similar
to CSS. Perhaps something like this:
request[name=org.foo.*] {
source: required;
mutable: required;
revision: r10662;
Another nice effect is that it is possible to describe an invocation of
an action on a build unit that is not currently present in the current
environment.
All that is required is that the invocation command references a
resolver that is configured to resolve against other "repos" than the
workspace and target platform.
- henrik
Content-Type: application/pdf;
name="Command.pdf"
Content-Disposition: inline;
filename="Command.pdf"
JVBERi0xLjQKJaqrrK0KNCAwIG9iago8PCAvVHlwZSAvSW5mbwovUHJvZHVj ZXIgPEZFRkYw
MDQxMDA3MDAwNjEwMDYzMDA2ODAwNjUwMDIwMDA0NjAwNEYwMDUwMDAzQTAw MjAwMDUzMDA1
NjAwNDcwMDIwMDA3NDAwNkYwMDIwMDA1MDAwNDQwMDQ2MDAyMDAwNTQwMDcy MDA2MTAwNkUw
MDczMDA2MzAwNkYwMDY0MDA2NTAwNzI+Ci9DcmVhdGlvbkRhdGUgPEZFRkYw MDQ0MDAzQTAw
MzIwMDMwMDAzMDAwMzkwMDMwMDAzOTAwMzIwMDMyMDAzMTAwMzUwMDMwMDAz OTAwMzUwMDM2
MDAyQjAwMzAwMDMyMDAyNzAwMzAwMDMwMDAyNz4KPj4KZW5kb2JqCjYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMQovTGVuZ3Ro IDcgMCBSCi9X
aWR0aCAxNDkKL0hlaWdodCA3OQovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
ZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0K eJztwTEBAAAA
wqBs61/KGh5AAQAAAAAAAAAAAABwblzYrWEKZW5kc3RyZWFtCmVuZG9iago3 IDAgb2JqCjM1
CmVuZG9iago4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTIKL0xlbmd0aCA5IDAgUgovV2lkdGggMTQ5Ci9IZWlnaHQgNzkKL0Jp dHNQZXJDb21w
b25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1 IDI1NSAyNTUg
MjU1IDI1NV0KL1NNYXNrIDYgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJztwkENAAAMAyHpe57t+WggdKWqqqqqqqqqqqqqqqqqqqqqqqqqqqqq qqqqqqqqqqqq
qqo6/QGeNFJpCmVuZHN0cmVhbQplbmRvYmoKOSAwIG9iago2MAplbmRvYmoK MTAgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMwov TGVuZ3RoIDEx
IDAgUgovV2lkdGggMTQ5Ci9IZWlnaHQgNzkKL0JpdHNQZXJDb21wb25lbnQg OAovQ29sb3JT
cGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cExAQAAAMKgbOtfyhoeQAEAAAAAAAAAAAAAcG5c2K1hCmVuZHN0cmVhbQpl bmRvYmoKMTEg
MCBvYmoKMzUKZW5kb2JqCjEyIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTQKL0xlbmd0aCAxMyAwIFIKL1dpZHRoIDE0OQovSGVp Z2h0IDc5Ci9C
aXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFz ayBbMjU1IDI1
NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMCAwIFIKL0ZpbHRlciBbIC9G bGF0ZURlY29k
ZSBdCj4+CnN0cmVhbQp4nO3CQQ0AAAwDIel7nu35aCB0paqqqqqqqqqqqqqq qqqqqqqqqqqq
qqqqqqqqqqqqqqqqqjr9AZ40UmkKZW5kc3RyZWFtCmVuZG9iagoxMyAwIG9i ago2MAplbmRv
YmoKMTQgMCBvYmoKPDwgCi9GdW5jdGlvblR5cGUgMiAKL0RvbWFpbiBbIDAg MSBdIAovQzAg
WyAxIDEgMC44MTk2MCBdIAovQzEgWyAxIDEgMSBdIAovTiAxIAo+PiAKZW5k b2JqCjE1IDAg
b2JqCjw8IAovRnVuY3Rpb25UeXBlIDMgCi9Eb21haW4gWyAwIDEgXSAKL0Z1 bmN0aW9ucyBb
IDE0IDAgUiBdIAovRW5jb2RlIFsgMCAxIF0gCi9Cb3VuZHMgWyBdIAo+PiAK ZW5kb2JqCjE2
IDAgb2JqCjw8IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0Rldmlj ZVJHQiAKL0Nv
b3JkcyBbIDE2MjEgMzExIDE2MjEgMzkwIF0gCi9Eb21haW4gWyAwIDEgXSAK L0V4dGVuZCBb
IHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5kb2JqCjE3 IDAgb2JqCjw8
IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFkaW5nIDE2 IDAgUiAKPj4g
CgplbmRvYmoKMTggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAv SW1hZ2UKL05h
bWUgL0ltNQovTGVuZ3RoIDE5IDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgov Qml0c1BlckNv
bXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAv RmxhdGVEZWNv
ZGUgXQo+PgpzdHJlYW0KeJxjYCAM/kMAGhcm8P8/igAy/R9B/6cmH9l8dPsx 3IfhfhQAAMZ3
foIKZW5kc3RyZWFtCmVuZG9iagoxOSAwIG9iago0MQplbmRvYmoKMjAgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNgovTGVuZ3Ro IDIxIDAgUgov
V2lkdGggMTYKL0hlaWdodCAxNgovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
ZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01h c2sgMTggMCBS
Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJxjYKAfOHPs yfSOY0UJGwvi
NhTGbwCygSK4FC+cegaorDZnR3/DIQgCsoEiQHGsilNDVvY1HFw68/y6pVcg CMgGigDF0bTc
uf4m0X95Z9X+FXMuIItfv/gSKNJdux8oC1QDFwe6szZne3PJHiCaN/E0RPDo ngcQESBqKto5
p/8kXH1x4sbMyDX5sesgCCK4c8MtCDc7eg0QAdXA1ScFLI/xXBDrtTDSfR4Q QQTXLbkI4QLF
o9znJ/ovQzY/wX9ZrPfCKI/5QARVv/QSkA1RH+O1ANl8oNtSg1ckBSxN8F8U 57cQIrhx+RUg
GygCRClByxdNQwTRo3sfQp3m58eta6vYjRw+R/feA4oUJmwEyiKHDxDMn3Q6 1mtJRdqWrpp9
yCgnZk1K0AqgLGaUAQXjvJeUpmwqTdkIQ5uAIlgVQwAwtUxtP5oTvRbofSA5 o+s4nvRDJAAA
uCHWTwplbmRzdHJlYW0KZW5kb2JqCjIxIDAgb2JqCjM0NgplbmRvYmoKMjIg MCBvYmoKPDwv
VHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNwovTGVu Z3RoIDIzIDAg
UgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1BlckNvbXBvbmVudCA4Ci9D b2xvclNwYWNl
IC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJl YW0KeJxjYKA9
+A8DVOJTEwAABSMs1AplbmRzdHJlYW0KZW5kb2JqCjIzIDAgb2JqCjE5CmVu ZG9iagoyNCAw
IG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAv SW04Ci9MZW5n
dGggMjUgMCBSCi9XaWR0aCAxNgovSGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9u ZW50IDgKL0Nv
bG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1 NSAyNTVdCi9T
TWFzayAyMiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nGNgGAXE
grk1+rgQVvVTKwx//LyIiYDiWNV3FZliVQ8Ux6q+Nsfy+49rQPTjJxj9gJJA cazqi9Jss5Ls
MRFQnLwAGQYAALIKVikKZW5kc3RyZWFtCmVuZG9iagoyNSAwIG9iago3NQpl bmRvYmoKMjYg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltOQovTGVu
Z3RoIDI3IDAgUgovV2lkdGggMTE0Ci9IZWlnaHQgNDAKL0JpdHNQZXJDb21w b25lbnQgOAov
Q29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2Rl IF0KPj4Kc3Ry
ZWFtCnic7cEBDQAAAMKgbO9fyhxuQAEAAADwZHWshg0KZW5kc3RyZWFtCmVu ZG9iagoyNyAw
IG9iagoyOAplbmRvYmoKMjggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3Vi dHlwZSAvSW1h
Z2UKL05hbWUgL0ltMTAKL0xlbmd0aCAyOSAwIFIKL1dpZHRoIDExNAovSGVp Z2h0IDQwCi9C
NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAyNiAwIFIKL0ZpbHRlciBbIC9G bGF0ZURlY29k
ZSBdCj4+CnN0cmVhbQp4nO3CMQ0AAADDIOk7a3tGILRSVVVVVVVVVVVVVVVV dR2W8KEmCmVu
ZHN0cmVhbQplbmRvYmoKMjkgMCBvYmoKMzcKZW5kb2JqCjMwIDAgb2JqCjw8 L1R5cGUgL1hP
YmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTExCi9MZW5ndGggMzEg MCBSCi9XaWR0
aCAxMTQKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNw YWNlIC9EZXZp
Y2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJzt wQENAAAAwqBs
71/KHG5AAQAAAPBkdayGDQplbmRzdHJlYW0KZW5kb2JqCjMxIDAgb2JqCjI4 CmVuZG9iagoz
MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW0xMgov
TGVuZ3RoIDMzIDAgUgovV2lkdGggMTE0Ci9IZWlnaHQgNDAKL0JpdHNQZXJD b21wb25lbnQg
OAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAy NTUgMjU1IDI1
NV0KL1NNYXNrIDMwIDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cIxDQAAAMMg6Ttre0YgtFJVVVVVVVVVVVVVVVV1HZbwoSYKZW5kc3RyZWFt CmVuZG9iagoz
MyAwIG9iagozNwplbmRvYmoKMzQgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAy IAovQ29sb3JT
cGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgMTM3OCA1NDUgMTM3OCA1ODUg XSAKL0RvbWFp
biBbIDAgMSBdIAovRXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAx NSAwIFIgCj4+
IAplbmRvYmoKMzUgMCBvYmoKPDwgCi9UeXBlIC9QYXR0ZXJuIAovUGF0dGVy blR5cGUgMiAK
L1NoYWRpbmcgMzQgMCBSIAo+PiAKCmVuZG9iagozNiAwIG9iago8PC9UeXBl IC9YT2JqZWN0
Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xMwovTGVuZ3RoIDM3IDAgUgov V2lkdGggMTQ0
Ci9IZWlnaHQgNjMKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAv RGV2aWNlR3Jh
eQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cGBAAAA AMMgtvlLXeEA
VQEAAAAAAAAAAK8BA+z/6QplbmRzdHJlYW0KZW5kb2JqCjM3IDAgb2JqCjMz CmVuZG9iagoz
OCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW0xNAov
TGVuZ3RoIDM5IDAgUgovV2lkdGggMTQ0Ci9IZWlnaHQgNjMKL0JpdHNQZXJD b21wb25lbnQg
NV0KL1NNYXNrIDM2IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cIxEQAADAMh6R3fdmVkgaMrVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV3 H8Zz99sKZW5k
c3RyZWFtCmVuZG9iagozOSAwIG9iago1MgplbmRvYmoKNDAgMCBvYmoKPDwv VHlwZSAvWE9i
amVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTUKL0xlbmd0aCA0MSAw IFIKL1dpZHRo
IDE0NAovSGVpZ2h0IDYzCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3Bh Y2UgL0Rldmlj
ZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3B gQAAAADDILb5
S13hAFUBAAAAAAAAAACvAQPs/+kKZW5kc3RyZWFtCmVuZG9iago0MSAwIG9i agozMwplbmRv
YmoKNDIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UK L05hbWUgL0lt
MTYKL0xlbmd0aCA0MyAwIFIKL1dpZHRoIDE0NAovSGVpZ2h0IDYzCi9CaXRz UGVyQ29tcG9u
ZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAy NTUgMjU1IDI1
NSAyNTVdCi9TTWFzayA0MCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBd Cj4+CnN0cmVh
bQp4nO3CMREAAAwDIekd33ZlZIGjK1VVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVdx/Gc/fb
CmVuZHN0cmVhbQplbmRvYmoKNDMgMCBvYmoKNTIKZW5kb2JqCjQ0IDAgb2Jq Cjw8IAovU2hh
ZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3JkcyBb IDEzNDIgMTQg
MTM0MiA3NyBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRy dWUgXSAKL0Z1
bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iago0NSAwIG9iago8PCAKL1R5cGUg L1BhdHRlcm4g
Ci9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyA0NCAwIFIgCj4+IAoKZW5kb2Jq CjQ2IDAgb2Jq
Cjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTE3 Ci9MZW5ndGgg
NDcgMCBSCi9XaWR0aCAxMTIKL0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVu dCA4Ci9Db2xv
clNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+ PgpzdHJlYW0K
eJztwTEBAAAAwqBs61/KFl5AAQAAAAB8DF7VONwKZW5kc3RyZWFtCmVuZG9i ago0NyAwIG9i
agoyOQplbmRvYmoKNDggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltMTgKL0xlbmd0aCA0OSAwIFIKL1dpZHRoIDExMgovSGVpZ2h0 IDQ3Ci9CaXRz
UGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBb MjU1IDI1NSAy
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayA0NiAwIFIKL0ZpbHRlciBbIC9GbGF0 ZURlY29kZSBd
Cj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33Y1ZIejK1VVVVVVVVVVVVVVVVVV VfcPAFPlIgpl
bmRzdHJlYW0KZW5kb2JqCjQ5IDAgb2JqCjQxCmVuZG9iago1MCAwIG9iago8 PC9UeXBlIC9Y
T2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0xOQovTGVuZ3RoIDUx IDAgUgovV2lk
dGggMTEyCi9IZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic 7cExAQAAAMKg
bOtfyhZeQAEAAAAAfAxe1TjcCmVuZHN0cmVhbQplbmRvYmoKNTEgMCBvYmoK MjkKZW5kb2Jq
CjUyIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9O YW1lIC9JbTIw
Ci9MZW5ndGggNTMgMCBSCi9XaWR0aCAxMTIKL0hlaWdodCA0NwovQml0c1Bl ckNvbXBvbmVu
dCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1 IDI1NSAyNTUg
MjU1XQovU01hc2sgNTAgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+ PgpzdHJlYW0K
eJztwjERAAAMAyHpHd92NWSHoytVVVVVVVVVVVVVVVVVVVX3DwBT5SIKZW5k c3RyZWFtCmVu
ZG9iago1MyAwIG9iago0MQplbmRvYmoKNTQgMCBvYmoKPDwgCi9TaGFkaW5n VHlwZSAyIAov
Q29sb3JTcGFjZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgNjQ5IDIzIDY0OSA3 MCBdIAovRG9t
YWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRydWUgXSAKL0Z1bmN0aW9u IDE1IDAgUiAK
Pj4gCmVuZG9iago1NSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0 ZXJuVHlwZSAy
IAovU2hhZGluZyA1NCAwIFIgCj4+IAoKZW5kb2JqCjU2IDAgb2JqCjw8L1R5 cGUgL1hPYmpl
Y3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTIxCi9MZW5ndGggNTcgMCBS Ci9XaWR0aCAx
MDAKL0hlaWdodCAzOAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNl IC9EZXZpY2VH
cmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwQEN AAAAwqBs71/K
HG5AAQAAwK8BiCjFBgplbmRzdHJlYW0KZW5kb2JqCjU3IDAgb2JqCjI4CmVu ZG9iago1OCAw
IG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAv SW0yMgovTGVu
Z3RoIDU5IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgMzgKL0JpdHNQZXJDb21w b25lbnQgOAov
Q29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUg MjU1IDI1NV0K
L1NNYXNrIDU2IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3Ry ZWFtCnic7cIx
EQAADAMh6R3fdjVkh6MrVVVVVVVVVVVVVdXlA1twBlIKZW5kc3RyZWFtCmVu ZG9iago1OSAw
IG9iagozNwplbmRvYmoKNjAgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3Vi dHlwZSAvSW1h
Z2UKL05hbWUgL0ltMjMKL0xlbmd0aCA2MSAwIFIKL1dpZHRoIDEwMAovSGVp Z2h0IDM4Ci9C
aXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BAQ0AAADCoGzvX8ocbkABAADA rwGIKMUGCmVu
ZHN0cmVhbQplbmRvYmoKNjEgMCBvYmoKMjgKZW5kb2JqCjYyIDAgb2JqCjw8 L1R5cGUgL1hP
YmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTI0Ci9MZW5ndGggNjMg MCBSCi9XaWR0
aCAxMDAKL0hlaWdodCAzOAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNw YWNlIC9EZXZp
Y2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sg NjAgMCBSCi9G
aWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHp Hd92NWSHoytV
VVVVVVVVVVVV1eUDW3AGUgplbmRzdHJlYW0KZW5kb2JqCjYzIDAgb2JqCjM3 CmVuZG9iago2
NCAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZp Y2VSR0IgCi9D
b29yZHMgWyA3MzkgNDE5IDczOSA0NTcgXSAKL0RvbWFpbiBbIDAgMSBdIAov RXh0ZW5kIFsg
dHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoKNjUg MCBvYmoKPDwg
Ci9UeXBlIC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgNjQg MCBSIAo+PiAK
CmVuZG9iago2NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9J bWFnZQovTmFt
ZSAvSW0yNQovTGVuZ3RoIDY3IDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgov Qml0c1BlckNv
ZGUgXQo+PgpzdHJlYW0KeJxjYCAE/iMAhI+QgZMQSSR5ND6aPIiHykc17z+G +Wh8FHk095EG
AGVdOsYKZW5kc3RyZWFtCmVuZG9iago2NyAwIG9iago0NAplbmRvYmoKNjgg MCBvYmoKPDwv
VHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjYKL0xl bmd0aCA2OSAw
IFIKL1dpZHRoIDE2Ci9IZWlnaHQgMTYKL0JpdHNQZXJDb21wb25lbnQgOAov Q29sb3JTcGFj
ZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0K L1NNYXNrIDY2
IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnicY2Cg B2jAC7CqJ9X8
UfUDqH7oAgCchByBCmVuZHN0cmVhbQplbmRvYmoKNjkgMCBvYmoKMjYKZW5k b2JqCjcwIDAg
b2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9J bTI3Ci9MZW5n
dGggNzEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBv bmVudCA4Ci9D
b2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRzdHJlYW0KZW5k b2JqCjcxIDAg
b2JqCjI4CmVuZG9iago3MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW0yOAovTGVuZ3RoIDczIDAgUgovV2lkdGggMTAwCi9IZWln aHQgNDAKL0Jp
dHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNr IFsyNTUgMjU1
IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDcwIDAgUgovRmlsdGVyIFsgL0Zs YXRlRGVjb2Rl
IF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVVVVVVVVVVVVVd f1PJPIkKZW5k
c3RyZWFtCmVuZG9iago3MyAwIG9iagozNwplbmRvYmoKNzQgMCBvYmoKPDwv VHlwZSAvWE9i
amVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjkKL0xlbmd0aCA3NSAw IFIKL1dpZHRo
IDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3Bh Y2UgL0Rldmlj
ZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3B MQEAAADCoGzr
X8oYPkABAAAAbwNujvfOCmVuZHN0cmVhbQplbmRvYmoKNzUgMCBvYmoKMjgK ZW5kb2JqCjc2
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTMwCi9M
ZW5ndGggNzcgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNv bXBvbmVudCA4
Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1 NSAyNTUgMjU1
XQovU01hc2sgNzQgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+Pgpz dHJlYW0KeJzt
wjERAAAMAyHpHd92ZWSBoytVVVVVVVVVVVVVVV1/U8k8iQplbmRzdHJlYW0K ZW5kb2JqCjc3
IDAgb2JqCjM3CmVuZG9iago3OCAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIg Ci9Db2xvclNw
YWNlIC9EZXZpY2VSR0IgCi9Db29yZHMgWyAxMzA2IDY4OSAxMzA2IDcyOSBd IAovRG9tYWlu
IFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRydWUgXSAKL0Z1bmN0aW9uIDE1 IDAgUiAKPj4g
CmVuZG9iago3OSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJu VHlwZSAyIAov
U2hhZGluZyA3OCAwIFIgCj4+IAoKZW5kb2JqCjgwIDAgb2JqCjw8L1R5cGUg L1hPYmplY3QK
L1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTMxCi9MZW5ndGggODEgMCBSCi9X aWR0aCAxNgov
SGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZUdyYXkK
L0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgIAz+w8Aw 4SMDAKVSdIwK
ZW5kc3RyZWFtCmVuZG9iago4MSAwIG9iagoxOAplbmRvYmoKODIgMCBvYmoK PDwvVHlwZSAv
WE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMzIKL0xlbmd0aCA4 MyAwIFIKL1dp
ZHRoIDE2Ci9IZWlnaHQgMTYKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNr IDgwIDAgUgov
RmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnicY2CgH5hbo48L 4VL/4+dFTIRL
/exqA6zqgeJY1U+vMPj+4xoQ/fgJRj+gJFAcq/rJ5UYLZ+QswEBAcazq+0pN sLoHKI5VfWeR
GVb1QHGs6pvzzbG6HyiOVX1djkVTW2NTKzoCimNVX5llhdU9QHGs6ksybLCq B4pjVV+QaovV
/UBxrOpzU+yzkrAgoDhW9cQAANYX80cKZW5kc3RyZWFtCmVuZG9iago4MyAw IG9iagoxNTEK
ZW5kb2JqCjg0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTMzCi9MZW5ndGggODUgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCAzOAov Qml0c1BlckNv
ZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHG5AAQAAwK8BiCjFBgpl bmRzdHJlYW0K
ZW5kb2JqCjg1IDAgb2JqCjI4CmVuZG9iago4NiAwIG9iago8PC9UeXBlIC9Y T2JqZWN0Ci9T
dWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0zNAovTGVuZ3RoIDg3IDAgUgovV2lk dGggMTAwCi9I
ZWlnaHQgMzgKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCCi9N
YXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDg0IDAgUgov RmlsdGVyIFsg
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdjVkh6Mr VVVVVVVVVVVV
VdXlA1twBlIKZW5kc3RyZWFtCmVuZG9iago4NyAwIG9iagozNwplbmRvYmoK ODggMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMzUK L0xlbmd0aCA4
OSAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDM4Ci9CaXRzUGVyQ29tcG9uZW50 IDgKL0NvbG9y
U3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+ CnN0cmVhbQp4
nO3BAQ0AAADCoGzvX8ocbkABAADArwGIKMUGCmVuZHN0cmVhbQplbmRvYmoK ODkgMCBvYmoK
MjgKZW5kb2JqCjkwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUg L0ltYWdlCi9O
YW1lIC9JbTM2Ci9MZW5ndGggOTEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCAz OAovQml0c1Bl
ckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1 NSAyNTUgMjU1
IDI1NSAyNTUgMjU1XQovU01hc2sgODggMCBSCi9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJztwjERAAAMAyHpHd92NWSHoytVVVVVVVVVVVVV1eUDW3AG UgplbmRzdHJl
YW0KZW5kb2JqCjkxIDAgb2JqCjM3CmVuZG9iago5MiAwIG9iago8PCAKL1No YWRpbmdUeXBl
IDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29yZHMgWyAxNTU4IDU0 NSAxNTU4IDU4
MyBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVlIHRydWUgXSAK L0Z1bmN0aW9u
IDE1IDAgUiAKPj4gCmVuZG9iago5MyAwIG9iago8PCAKL1R5cGUgL1BhdHRl cm4gCi9QYXR0
ZXJuVHlwZSAyIAovU2hhZGluZyA5MiAwIFIgCj4+IAoKZW5kb2JqCjk0IDAg b2JqCjw8L1R5
cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTM3Ci9MZW5n dGggOTUgMCBS
Ci9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9D b2xvclNwYWNl
IC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJl YW0KeJztwTEB
AAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRzdHJlYW0KZW5kb2JqCjk1IDAg b2JqCjI4CmVu
ZG9iago5NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFn ZQovTmFtZSAv
SW0zOAovTGVuZ3RoIDk3IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0Jp dHNQZXJDb21w
MjU1IDI1NV0KL1NNYXNrIDk0IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2Rl IF0KPj4Kc3Ry
ZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5k c3RyZWFtCmVu
ZG9iago5NyAwIG9iagozNwplbmRvYmoKOTggMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltMzkKL0xlbmd0aCA5OSAwIFIKL1dpZHRo IDEwMAovSGVp
Z2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rldmlj ZUdyYXkKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzr X8oYPkABAAAA
bwNujvfOCmVuZHN0cmVhbQplbmRvYmoKOTkgMCBvYmoKMjgKZW5kb2JqCjEw MCAwIG9iago8
PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW00MAov TGVuZ3RoIDEw
MSAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50 IDgKL0NvbG9y
U3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAy NTVdCi9TTWFz
ayA5OCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nO3CMREAAAwD
Iekd33ZlZIGjK1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoK MTAxIDAgb2Jq
CjM3CmVuZG9iagoxMDIgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29s b3JTcGFjZSAv
RGV2aWNlUkdCIAovQ29vcmRzIFsgNzM5IDMwMiA3MzkgMzQyIF0gCi9Eb21h aW4gWyAwIDEg
XSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+ PiAKZW5kb2Jq
CjEwMyAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAy IAovU2hhZGlu
ZyAxMDIgMCBSIAo+PiAKCmVuZG9iagoxMDQgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltNDEKL0xlbmd0aCAxMDUgMCBSCi9XaWR0 aCAxMDAKL0hl
aWdodCAzOAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZp Y2VHcmF5Ci9G
aWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs 71/KHG5AAQAA
wK8BiCjFBgplbmRzdHJlYW0KZW5kb2JqCjEwNSAwIG9iagoyOAplbmRvYmoK MTA2IDAgb2Jq
Cjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTQy Ci9MZW5ndGgg
MTA3IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgMzgKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
b3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1 IDI1NV0KL1NN
YXNrIDEwNCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nO3CMREA
AAwDIekd33Y1ZIejK1VVVVVVVVVVVVXV5QNbcAZSCmVuZHN0cmVhbQplbmRv YmoKMTA3IDAg
b2JqCjM3CmVuZG9iagoxMDggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3Vi dHlwZSAvSW1h
Z2UKL05hbWUgL0ltNDMKL0xlbmd0aCAxMDkgMCBSCi9XaWR0aCAxMDAKL0hl aWdodCAzOAov
Qml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9G aWx0ZXIgWyAv
RmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHG5AAQAA wK8BiCjFBgpl
bmRzdHJlYW0KZW5kb2JqCjEwOSAwIG9iagoyOAplbmRvYmoKMTEwIDAgb2Jq Cjw8L1R5cGUg
L1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTQ0Ci9MZW5ndGgg MTExIDAgUgov
V2lkdGggMTAwCi9IZWlnaHQgMzgKL0JpdHNQZXJDb21wb25lbnQgOAovQ29s b3JTcGFjZSAv
RGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NN YXNrIDEwOCAw
IFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREA AAwDIekd33Y1
ZIejK1VVVVVVVVVVVVXV5QNbcAZSCmVuZHN0cmVhbQplbmRvYmoKMTExIDAg b2JqCjM3CmVu
ZG9iagoxMTIgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFj ZSAvRGV2aWNl
UkdCIAovQ29vcmRzIFsgMTE2MiA1NDUgMTE2MiA1ODMgXSAKL0RvbWFpbiBb IDAgMSBdIAov
RXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IApl bmRvYmoKMTEz
IDAgb2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9T aGFkaW5nIDEx
MiAwIFIgCj4+IAoKZW5kb2JqCjExNCAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW00NQovTGVuZ3RoIDExNSAwIFIKL1dpZHRoIDE3 MAovSGVpZ2h0
IDc5Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdy YXkKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8rX EEABAAAAAAAA
AAAAAAAAvAE3o1K6CmVuZHN0cmVhbQplbmRvYmoKMTE1IDAgb2JqCjM3CmVu ZG9iagoxMTYg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltNDYKL0xl
bmd0aCAxMTcgMCBSCi9XaWR0aCAxNzAKL0hlaWdodCA3OQovQml0c1BlckNv bXBvbmVudCA4
XQovU01hc2sgMTE0IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cIxEQAADAMh6R3fdi1EABxdqaqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq qqqqqqqqqqqq
qqqqbh/Odl++CmVuZHN0cmVhbQplbmRvYmoKMTE3IDAgb2JqCjY1CmVuZG9i agoxMTggMCBv
YmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0lt NDcKL0xlbmd0
aCAxMTkgMCBSCi9XaWR0aCAxNzAKL0hlaWdodCA3OQovQml0c1BlckNvbXBv bmVudCA4Ci9D
YW0KeJztwTEBAAAAwqBs61/K1xBAAQAAAAAAAAAAAAAAALwBN6NSugplbmRz dHJlYW0KZW5k
b2JqCjExOSAwIG9iagozNwplbmRvYmoKMTIwIDAgb2JqCjw8L1R5cGUgL1hP YmplY3QKL1N1
YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTQ4Ci9MZW5ndGggMTIxIDAgUgovV2lk dGggMTcwCi9I
ZWlnaHQgNzkKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCCi9N
YXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDExOCAwIFIK L0ZpbHRlciBb
IC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33YtRAAc Xamqqqqqqqqq
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqm4fznZfvgplbmRzdHJl YW0KZW5kb2Jq
CjEyMSAwIG9iago2NQplbmRvYmoKMTIyIDAgb2JqCjw8IAovU2hhZGluZ1R5 cGUgMiAKL0Nv
bG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3JkcyBbIDE0MzIgMTY3IDE0MzIg MjQ2IF0gCi9E
b21haW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rp b24gMTUgMCBS
IAo+PiAKZW5kb2JqCjEyMyAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9Q YXR0ZXJuVHlw
ZSAyIAovU2hhZGluZyAxMjIgMCBSIAo+PiAKCmVuZG9iagoxMjQgMCBvYmoK PDwvVHlwZSAv
WE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNDkKL0xlbmd0aCAx MjUgMCBSCi9X
aWR0aCAxMDAKL0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
wqBs61/KDt5AAQAAAMBnk7OpmQplbmRzdHJlYW0KZW5kb2JqCjEyNSAwIG9i agoyOAplbmRv
YmoKMTI2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTUwCi9MZW5ndGggMTI3IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDcKL0Jp dHNQZXJDb21w
MjU1IDI1NV0KL1NNYXNrIDEyNCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29k ZSBdCj4+CnN0
cmVhbQp4nO3CwQkAAAwDodH7vLU7R0CxK1VVVVVVVVVVVVVVVVVd+JjDelEK ZW5kc3RyZWFt
CmVuZG9iagoxMjcgMCBvYmoKMzkKZW5kb2JqCjEyOCAwIG9iago8PC9UeXBl IC9YT2JqZWN0
Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW01MQovTGVuZ3RoIDEyOSAwIFIK L1dpZHRoIDEw
MAovSGVpZ2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2Ug L0RldmljZUdy
YXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEA AADCoGzrX8oO
3kABAAAAwGeTs6mZCmVuZHN0cmVhbQplbmRvYmoKMTI5IDAgb2JqCjI4CmVu ZG9iagoxMzAg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltNTIKL0xl
bmd0aCAxMzEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0NwovQml0c1BlckNv bXBvbmVudCA4
XQovU01hc2sgMTI4IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cLBCQAADAOh0fu8tTtHQLErVVVVVVVVVVVVVVVVVV34mMN6UQplbmRzdHJl YW0KZW5kb2Jq
CjEzMSAwIG9iagozOQplbmRvYmoKMTMyIDAgb2JqCjw8IAovU2hhZGluZ1R5 cGUgMiAKL0Nv
bG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3JkcyBbIDQxNSAzMDIgNDE1IDM0 OSBdIAovRG9t
Pj4gCmVuZG9iagoxMzMgMCBvYmoKPDwgCi9UeXBlIC9QYXR0ZXJuIAovUGF0 dGVyblR5cGUg
MiAKL1NoYWRpbmcgMTMyIDAgUiAKPj4gCgplbmRvYmoKMTM0IDAgb2JqCjw8 L1R5cGUgL1hP
YmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTUzCi9MZW5ndGggMTM1 IDAgUgovV2lk
dGggMTEwCi9IZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
bOtfyssWQAEAAAAA3ADS4SD+CmVuZHN0cmVhbQplbmRvYmoKMTM1IDAgb2Jq CjI5CmVuZG9i
agoxMzYgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UK L05hbWUgL0lt
NTQKL0xlbmd0aCAxMzcgMCBSCi9XaWR0aCAxMTAKL0hlaWdodCA0NwovQml0 c1BlckNvbXBv
bmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUg MjU1IDI1NSAy
NTUgMjU1XQovU01hc2sgMTM0IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2Rl IF0KPj4Kc3Ry
ZWFtCnic7cIxEQAADAMh6R3fdhXEARxdqaqqqqqqqqqqqqqqqqqq7g+P51Nc CmVuZHN0cmVh
bQplbmRvYmoKMTM3IDAgb2JqCjQxCmVuZG9iagoxMzggMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNTUKL0xlbmd0aCAxMzkgMCBS Ci9XaWR0aCAx
MTAKL0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNl IC9EZXZpY2VH
cmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEB AAAAwqBs61/K
yxZAAQAAAADcANLhIP4KZW5kc3RyZWFtCmVuZG9iagoxMzkgMCBvYmoKMjkK ZW5kb2JqCjE0
MCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW01Ngov
TGVuZ3RoIDE0MSAwIFIKL1dpZHRoIDExMAovSGVpZ2h0IDQ3Ci9CaXRzUGVy Q29tcG9uZW50
IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAyNTUg MjU1IDI1NSAy
NTVdCi9TTWFzayAxMzggMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+ PgpzdHJlYW0K
eJztwjERAAAMAyHpHd92FcQBHF2pqqqqqqqqqqqqqqqqqqruD4/nU1wKZW5k c3RyZWFtCmVu
ZG9iagoxNDEgMCBvYmoKNDEKZW5kb2JqCjE0MiAwIG9iago8PCAKL1NoYWRp bmdUeXBlIDIg
Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29yZHMgWyAxMCAzMDIgMTAg MzQ5IF0gCi9E
IAo+PiAKZW5kb2JqCjE0MyAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9Q YXR0ZXJuVHlw
ZSAyIAovU2hhZGluZyAxNDIgMCBSIAo+PiAKCmVuZG9iagoxNDQgMCBvYmoK PDwvVHlwZSAv
WE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNTcKL0xlbmd0aCAx NDUgMCBSCi9X
aWR0aCAxNzAKL0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
ZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0K eJztwYEAAAAA
wyC2+Usd5FUBAAAAAAAAwKsBUW3tIAplbmRzdHJlYW0KZW5kb2JqCjE0NSAw IG9iagozMQpl
bmRvYmoKMTQ2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTU4Ci9MZW5ndGggMTQ3IDAgUgovV2lkdGggMTcwCi9IZWlnaHQgNDcK L0JpdHNQZXJD
b21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUg MjU1IDI1NSAy
NTUgMjU1IDI1NV0KL1NNYXNrIDE0NCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURl Y29kZSBdCj4+
CnN0cmVhbQp4nO3CMREAAAwDIekd33aFBI6uVFVVVVVVVVVVVVVVVVVVVVVV VVVVVVU3PmT4
aY8KZW5kc3RyZWFtCmVuZG9iagoxNDcgMCBvYmoKNDgKZW5kb2JqCjE0OCAw IG9iago8PC9U
eXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW01OQovTGVu Z3RoIDE0OSAw
IFIKL1dpZHRoIDE3MAovSGVpZ2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50IDgK L0NvbG9yU3Bh
Y2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0 cmVhbQp4nO3B
gQAAAADDILb5Sx3kVQEAAAAAAADAqwFRbe0gCmVuZHN0cmVhbQplbmRvYmoK MTQ5IDAgb2Jq
CjMxCmVuZG9iagoxNTAgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltNjAKL0xlbmd0aCAxNTEgMCBSCi9XaWR0aCAxNzAKL0hlaWdo dCA0NwovQml0
c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sg WzI1NSAyNTUg
MjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTQ4IDAgUgovRmlsdGVyIFsgL0Zs YXRlRGVjb2Rl
IF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdoUEjq5UVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VTc+ZPhpjwplbmRzdHJlYW0KZW5kb2JqCjE1MSAwIG9iago0OAplbmRvYmoK MTUyIDAgb2Jq
Cjw8IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAK L0Nvb3JkcyBb
IDE4MSAzMDIgMTgxIDM0OSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQg WyB0cnVlIHRy
dWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxNTMgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTUyIDAgUiAK Pj4gCgplbmRv
YmoKMTU0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTYxCi9MZW5ndGggMTU1IDAgUgovV2lkdGggMTA4Ci9IZWlnaHQgNDcKL0Jp dHNQZXJDb21w
b25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0Zs YXRlRGVjb2Rl
IF0KPj4Kc3RyZWFtCnic7cEBDQAAAMKgbO9fyhxuQAEAAAAATwYLBwkgCmVu ZHN0cmVhbQpl
bmRvYmoKMTU1IDAgb2JqCjI5CmVuZG9iagoxNTYgMCBvYmoKPDwvVHlwZSAv WE9iamVjdAov
U3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltNjIKL0xlbmd0aCAxNTcgMCBSCi9X aWR0aCAxMDgK
L0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9E ZXZpY2VSR0IK
L01hc2sgWzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTU0IDAg UgovRmlsdGVy
IFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxDQAAAMMg6Ttre0Yg tFJVVVVVVVVV
VVVVVVVVVdcBvQbBhwplbmRzdHJlYW0KZW5kb2JqCjE1NyAwIG9iagozOQpl bmRvYmoKMTU4
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTYzCi9M
ZW5ndGggMTU5IDAgUgovV2lkdGggMTA4Ci9IZWlnaHQgNDcKL0JpdHNQZXJD b21wb25lbnQg
OAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVj b2RlIF0KPj4K
c3RyZWFtCnic7cEBDQAAAMKgbO9fyhxuQAEAAAAATwYLBwkgCmVuZHN0cmVh bQplbmRvYmoK
MTU5IDAgb2JqCjI5CmVuZG9iagoxNjAgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltNjQKL0xlbmd0aCAxNjEgMCBSCi9XaWR0aCAx MDgKL0hlaWdo
dCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VS R0IKL01hc2sg
WzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTU4IDAgUgovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxDQAAAMMg6Ttre0YgtFJVVVVV VVVVVVVVVVVV
VdcBvQbBhwplbmRzdHJlYW0KZW5kb2JqCjE2MSAwIG9iagozOQplbmRvYmoK MTYyIDAgb2Jq
IDU3NyAzMDIgNTc3IDM0OSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQg WyB0cnVlIHRy
dWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxNjMgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTYyIDAgUiAK Pj4gCgplbmRv
YmoKMTY0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTY1Ci9MZW5ndGggMTY1IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0Jp dHNQZXJDb21w
IF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984KZW5k c3RyZWFtCmVu
ZG9iagoxNjUgMCBvYmoKMjgKZW5kb2JqCjE2NiAwIG9iago8PC9UeXBlIC9Y T2JqZWN0Ci9T
dWJ0eXBlIC9JbWFnZQovTmFtZSAvSW02NgovTGVuZ3RoIDE2NyAwIFIKL1dp ZHRoIDEwMAov
SGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZVJHQgov
TWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxNjQgMCBS Ci9GaWx0ZXIg
WyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92ZWSB oytVVVVVVVVV
VVVVVV1/U8k8iQplbmRzdHJlYW0KZW5kb2JqCjE2NyAwIG9iagozNwplbmRv YmoKMTY4IDAg
b2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9J bTY3Ci9MZW5n
dGggMTY5IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21w b25lbnQgOAov
ZWFtCnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984KZW5kc3RyZWFtCmVu ZG9iagoxNjkg
MCBvYmoKMjgKZW5kb2JqCjE3MCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9T dWJ0eXBlIC9J
bWFnZQovTmFtZSAvSW02OAovTGVuZ3RoIDE3MSAwIFIKL1dpZHRoIDEwMAov SGVpZ2h0IDQw
Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgov TWFzayBbMjU1
IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxNjggMCBSCi9GaWx0ZXIg WyAvRmxhdGVE
ZWNvZGUgXQo+PgpzdHJlYW0KeJztwjERAAAMAyHpHd92ZWSBoytVVVVVVVVV VVVVVV1/U8k8
iQplbmRzdHJlYW0KZW5kb2JqCjE3MSAwIG9iagozNwplbmRvYmoKMTcyIDAg b2JqCjw8IAov
U2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nvb3Jk cyBbIDkxMCAz
MDIgOTEwIDM0MiBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0cnVl IHRydWUgXSAK
L0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxNzMgMCBvYmoKPDwgCi9U eXBlIC9QYXR0
ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTcyIDAgUiAKPj4gCgpl bmRvYmoKMTc0
IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1l IC9JbTY5Ci9M
ZW5ndGggMTc1IDAgUgovV2lkdGggMTEzCi9IZWlnaHQgNDcKL0JpdHNQZXJD b21wb25lbnQg
c3RyZWFtCnic7cExAQAAAMKgbOtfyhoeQAEAAAAAXBruRkTLCmVuZHN0cmVh bQplbmRvYmoK
MTc1IDAgb2JqCjI5CmVuZG9iagoxNzYgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltNzAKL0xlbmd0aCAxNzcgMCBSCi9XaWR0aCAx MTMKL0hlaWdo
WzI1NSAyNTUgMjU1IDI1NSAyNTUgMjU1XQovU01hc2sgMTc0IDAgUgovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cLBCQAADAOh0fu8tTtHQLErVVVV VVVVVVVVVVVV
VVVVxz9zkC4UCmVuZHN0cmVhbQplbmRvYmoKMTc3IDAgb2JqCjQxCmVuZG9i agoxNzggMCBv
YmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0lt NzEKL0xlbmd0
aCAxNzkgMCBSCi9XaWR0aCAxMTMKL0hlaWdodCA0NwovQml0c1BlckNvbXBv bmVudCA4Ci9D
YW0KeJztwTEBAAAAwqBs61/KGh5AAQAAAABcGu5GRMsKZW5kc3RyZWFtCmVu ZG9iagoxNzkg
MCBvYmoKMjkKZW5kb2JqCjE4MCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9T dWJ0eXBlIC9J
bWFnZQovTmFtZSAvSW03MgovTGVuZ3RoIDE4MSAwIFIKL1dpZHRoIDExMwov SGVpZ2h0IDQ3
IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxNzggMCBSCi9GaWx0ZXIg WyAvRmxhdGVE
ZWNvZGUgXQo+PgpzdHJlYW0KeJztwsEJAAAMA6HR+7y1O0dAsStVVVVVVVVV VVVVVVVVVVXH
P3OQLhQKZW5kc3RyZWFtCmVuZG9iagoxODEgMCBvYmoKNDEKZW5kb2JqCjE4 MiAwIG9iago8
PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9D b29yZHMgWyAx
MDcyIDMwMiAxMDcyIDM0OSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQg WyB0cnVlIHRy
dWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxODMgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTgyIDAgUiAK Pj4gCgplbmRv
YmoKMTg0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTczCi9MZW5ndGggMTg1IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDcKL0Jp dHNQZXJDb21w
IF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyg7eQAEAAADAZ5OzqZkKZW5k c3RyZWFtCmVu
ZG9iagoxODUgMCBvYmoKMjgKZW5kb2JqCjE4NiAwIG9iago8PC9UeXBlIC9Y T2JqZWN0Ci9T
dWJ0eXBlIC9JbWFnZQovTmFtZSAvSW03NAovTGVuZ3RoIDE4NyAwIFIKL1dp ZHRoIDEwMAov
SGVpZ2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rl dmljZVJHQgov
TWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxODQgMCBS Ci9GaWx0ZXIg
WyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwsEJAAAMA6HR+7y1O0dA sStVVVVVVVVV
VVVVVVVVXfiYw3pRCmVuZHN0cmVhbQplbmRvYmoKMTg3IDAgb2JqCjM5CmVu ZG9iagoxODgg
MCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUg L0ltNzUKL0xl
bmd0aCAxODkgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0NwovQml0c1BlckNv bXBvbmVudCA4
Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNv ZGUgXQo+Pgpz
dHJlYW0KeJztwTEBAAAAwqBs61/KDt5AAQAAAMBnk7OpmQplbmRzdHJlYW0K ZW5kb2JqCjE4
OSAwIG9iagoyOAplbmRvYmoKMTkwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QK L1N1YnR5cGUg
L0ltYWdlCi9OYW1lIC9JbTc2Ci9MZW5ndGggMTkxIDAgUgovV2lkdGggMTAw Ci9IZWlnaHQg
NDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdC Ci9NYXNrIFsy
NTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDE4OCAwIFIKL0ZpbHRl ciBbIC9GbGF0
ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CwQkAAAwDodH7vLU7R0CxK1VVVVVV VVVVVVVVVVVd
+JjDelEKZW5kc3RyZWFtCmVuZG9iagoxOTEgMCBvYmoKMzkKZW5kb2JqCjE5 MiAwIG9iago8
NDY4IDY4OSAxNDY4IDczNiBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQg WyB0cnVlIHRy
dWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxOTMgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTkyIDAgUiAK Pj4gCgplbmRv
YmoKMTk0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTc3Ci9MZW5ndGggMTk1IDAgUgovV2lkdGggMTU1Ci9IZWlnaHQgMjE5Ci9C aXRzUGVyQ29t
cG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9G bGF0ZURlY29k
ZSBdCj4+CnN0cmVhbQp4nO3BMQEAAADCoGzrX8oaHkABAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAB3BqwfrMkKZW5kc3RyZWFtCmVuZG9iagoxOTUgMCBvYmoK NTcKZW5kb2Jq
CjE5NiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQov TmFtZSAvSW03
OAovTGVuZ3RoIDE5NyAwIFIKL1dpZHRoIDE1NQovSGVpZ2h0IDIxOQovQml0 c1BlckNvbXBv
NTUgMjU1XQovU01hc2sgMTk0IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2Rl IF0KPj4Kc3Ry
ZWFtCnic7cLBCQAADAOh0fu8tTtHQLErVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVUd/NBxrUkKZW5kc3RyZWFtCmVuZG9iagoxOTcgMCBv YmoKMTI0CmVu
ZG9iagoxOTggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1h Z2UKL05hbWUg
L0ltNzkKL0xlbmd0aCAxOTkgMCBSCi9XaWR0aCAxNTUKL0hlaWdodCAyMTkK L0JpdHNQZXJD
b21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsg L0ZsYXRlRGVj
b2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhoeQAEAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAHcGrB+syQplbmRzdHJlYW0KZW5kb2JqCjE5OSAwIG9i ago1NwplbmRv
YmoKMjAwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTgwCi9MZW5ndGggMjAxIDAgUgovV2lkdGggMTU1Ci9IZWlnaHQgMjE5Ci9C aXRzUGVyQ29t
cG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1 NSAyNTUgMjU1
IDI1NSAyNTVdCi9TTWFzayAxOTggMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNv ZGUgXQo+Pgpz
dHJlYW0KeJztwsEJAAAMA6HR+7y1O0dAsStVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVVVVVR380HGtSQplbmRzdHJlYW0KZW5kb2JqCjIwMSAw IG9iagoxMjQK
ZW5kb2JqCjIwMiAwIG9iago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNw YWNlIC9EZXZp
Y2VSR0IgCi9Db29yZHMgWyAxNjIxIDIzIDE2MjEgMjQyIF0gCi9Eb21haW4g WyAwIDEgXSAK
L0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAK ZW5kb2JqCjIw
MyAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAov U2hhZGluZyAy
MDIgMCBSIAo+PiAKCmVuZG9iagoyMDQgMCBvYmoKPDwvVHlwZSAvWE9iamVj dAovU3VidHlw
ZSAvSW1hZ2UKL05hbWUgL0ltODEKL0xlbmd0aCAyMDUgMCBSCi9XaWR0aCAx NgovSGVpZ2h0
IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdy YXkKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgoBz8hwEq8TFNR2b8 ByNMPswIDHkQ
BYbYbAAAhFpSrgplbmRzdHJlYW0KZW5kb2JqCjIwNSAwIG9iagozNQplbmRv YmoKMjA2IDAg
b2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9J bTgyCi9MZW5n
dGggMjA3IDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1BlckNvbXBv bmVudCA4Ci9D
b2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAy NTUgMjU1XQov
U01hc2sgMjA0IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3Ry ZWFtCnicY2AY
PmBujT4uhFX91ArDHz8vYiKgOFb1XUWmWNUDxbGqr82x/P7jGhD9+AlGP6Ak UByr+qI026wk
e0wEFCcvQOBg/r7XkvZlQARkoEkBBY/e+AxEQAayIBoDDiAqIboIqoeoREbk mY/mfoguOInp
fuIBAJKIiLUKZW5kc3RyZWFtCmVuZG9iagoyMDcgMCBvYmoKMTIxCmVuZG9i agoyMDggMCBv
YmoKPDwgL0xlbmd0aCAyMDkgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJykvdmuZUlyJfaeXxE/oOD22f1dgCABAlrgg54bRFMFIZKCmgSE+/fy tWxw831PZFd1
s8DMc1fa9nkwM7ch/Xj2//6ntP/RevrxL3/+8fwcjaD/2OD/+0fqOf8oKf/4 U3+u9OPXH2mM
dP3cBL/++Nsf/+cf//ZHqksKH+uHf7LL+qf/9c/843/+f/74P6TUsj8qUur+ ubIUla+fm+A3
pconUmoNpT77o0dKfX7b1sdLfX78L3/803/6z//xH//lv/7bj3/59x/7d/rx 7//ybz9QAEgT
yhrj4c9f+nOhACEIP0nwtz/+9b+3KT/bk1bfDco//rc/0o//+4/0Mz37/378 f/uv//1uUF/e
IPycy1sRfmqD/lkb1Kp9zp95kBD9CT/1G474T6wF+X/8xmc/SfKTayN1XUP4 9/6HTEY/kzHO
wsHP3NneMq+fYeE8P3N71vzxf3Fa9kfl58pjbHJZJ6P9LKOgBe3nGKVKo/vP smZ9gfXnaiXx
S5S+kfkzP08+ZCxw/cy59de38+ded21/+/wspSwDn9XQlPSz5jx/CN1aldBK uwVfQjceVpx/
1lQxLruSNrECDALdfH7W/Uek29BcpUt5dXebdOlnqVbv3B8Qan0Wad/+S+h2 MXOUuyez/CwT
H1/gpuxryOdt91NBnZj0c5bySDUVk4MWtqdPa3afE2NTfqb5dOle6U89kA7D 84x50Y1dTNFh
mFmHq/9caz6sd8yahC6vJ0n7cs2b7m/Sl71hmq+FWXdDucjHz92dLN3Y/Vz1 +Qa2PZ4bnBss
RcD+s40ln7f5sMP7m5n7gdjhPckj3XQsZrG8Jw2lW/t37wRrq0o3O6tYP9NK 1cpLz6i6MFlp
qq3Fv2etkx/t4VoGrp6lxpWKNnbu1Sed6klGfYNj/1MakZ4kdCX1eqAv6Xwt uV90bf9iebve
vfGErv4cpdSwi3Y31xhnFtY+Csp8zcLKP3ls3eDzcw9aLGt/m8uzy0p9V9O8 QG6va8nuAsus
38G0cj2fa6l1963pCs1Zzt9VbFcqSKjwLN/LcTxZBmaDT3smwTz3zUVIzo29 QvducbqZS9EB
XDJLG0xt5W9gecp4jcU+1zp2xwXWn6nzgPL+bLDt5fF0gr3mZpQrr3eZ3Sb6 BtNI69WkPauz
vdu5a184P3Y3S1vF27mPJA4HjzrSzckjWaEvaeXe7Omi20d1r/rpLtDockln 8aMlPY9rWt7T
J7t/2Xa1dbe3Xq73oT+efX8k9jaCe5W1CBIaqcrKyUVOor0E9lD1ISON3Upo z7ys44Yr8+sP
/TjLRnn2Vv7BetMeTEJ7K2ajm3LrFWtcjxt/7UOhFzkdVtVTaeGS6m9w6Pl1 ds7EHFU5WdBo
HRK220Grdd+pByS08tTVsy8ma21qupn26cWZ2AcB+C+HvqSSOXWUCLJB4+k/ 94pqnO25T2+y
KE/bv0fcdIBSmSPO7gaxG/q86HBxZdmHZR9VNkNjTbmjWq9V6J4K/ufcFQTz nHrupv1jQ5tv
WVWWfKm9C93eRs8jO6aNlqR9a2/CA31p58Z8Lrp9R3XO056wNofQYTyrHAq7 siJ09clyVWc9
ZACWwjtv8wBL9h8HYZX0DZy5yRW8+bouLax71g6kLXx6rxfd2Gu3LkKPnOd/ kz7vEekcm7G3
g0zUnsvMg1jBX9rrvUCli2sfVqxbl75COor79m8X3bsSqXuzjVJNrrICUXfa 2+5p0vRH7ztQ
5tVWXBFp77FU82vl7AluI18rZ/NfdchK3HOgbdyzXsYSLiPv04UQr3OMd0u1 G92+fMe5sVlF
z1PuT/JSoNuNqSlHpgBNrmRVA/OAzpXx3HR7g9QmV3R58jA62QHh7B5pr4hS +gs0Ns/GUPbf
hje9Mgh9n3Y6tJuZHqcqbeV61775+zpWpGOvq+yrune9jfZejHo5YlplIGYp B/rS2QMrF+ky
+GzlYp/iK2IzQ4nbQxYiGpBSey2GvV1yKtdi2Od2Hu1eDPt8b6Vei2FD2crb HI7S4QabXZpX
p9LtOzrJyfK0aeXt42a9xn/fzf15zxS2H6vZp6gymPich4Bwtkub/XRb63Xv hC/5OAlHvZuz
9tQR2jfwONCXDEMduV90+/6eTQSQVKrOJg76/Gp2xg1V383eF9iodkNhPrio yryP8T2ck/LV
Gdf9KydunjD+6BRZwUCXwAvn+xjfbZncFOcYR/vTvFh+gueSk2N8F6NSbDjG N7j26MTjOYNv
oTAUjnF0rpI9O3QN50K9j/ENDpEJ/RjfUB0qEfoxDvBZ5T6xedrW9gI3K7B6 i8fzbmGTFReO
8d3CVIy3UjpwVj2/j3GsgaZMiB/j+/O2lA3xYzyTX+vxeN51U9S6jnHskNHG RfeuROvewkjr
YfL/FDCvfp3YeQsZqckNNMFusRos7SwHwSqPaAH2x1sWjmzmyPtkKKtfbCbA 1mp/0c2hQmUa
VfuipzcraQ9neskEA+rJVuKWXNvQ/ZOFbjNRrcmkDh+b3ZiK+wx3RZvNGi1C TsbxmdjjLcst
MgB7Z23mWT7GbV9ktMtoS+jWU4TxWOAstJK9xnq8K9C+PNN9p2RMBlitQ1ce 5TI2ZKIMwL17
ZMuPmmTLg7LoZd027y892Yf96DOe/xiup+T7ntgt3Iduu+imiSd7r4zejO5p RW7RmpIN66I2
aLf+mcunKWfhTddTszVmr80pW630It17VpPToYOn0e7tA03mZGHcCO3DS6Zz M6PF6PYlqMdm
Jt2uojbde5tD9zmeqd2n3Huhy/ov+/CD6vFa/0V1JOHzDaX5jEvAHGUfBbaE RcAEHe+6KGAC
7Lnfghs+Xj3PFwgGarT7aN+gKEte4OrUuB0BE71ZVWUhEzABitx/fd5kk9zg PlRtTZwm7cNt
znc7N6u+5aVLwGQ7V15xR2+6LcaUe+dvcHP046KDuDyfS8AE+JRmaj9piTDG Z1re0/cVVbaY
mSUq2/2ziryNGyz8zOsvNKT7gEOb1l9pSOfRkGLki+go8LOKzIphCj9L1BHf GtLawO/toa6i
1/W/92y5FqB2XOvjd2A/WrEKFRimc1OqtqtOYV8cghhY9xYaODkD3dKLZpfn WrH2yGUCcHMC
UDQdaBytmIM1STsW5vTD32UcrdgBu2nFKoRqHI7olGnFdg82H5elEaLtqlNX qEFf0vkt4jwX
nQ/SOFoxB2tSebxBksQBXMG/dFOxgx/CTCZTbjSsPRyDBrHv++gYL7q9pyv4 jV3eZrt1jJIc
nQD3XQsNtENlH+Fd2PQATrnCWF4tCu27qAldwQZa7NvcJKLeb1T5GvQl/dgs 7zjgrxeYIVHd
YNcLApXMhJPEIK35aemmA2cHGWRD++SqNjIKNjllfmmzyRmcpdeKTXBYorsx c4x50W12j6o8
lDcfrQTsXpZ1u6dr/oiQdu6mg2w0ZAk6uOek4r1hQ9ApQatgED/eIFXGF52w R4B2i4yuzioL
aUHM/yVg4n0VFsiuF8v7XkibV5yyiZzuvTC/bL3qRO1NC+3knxc4ofjvNqWV dyrAnKZNwd4s
AZRZadDPYdFl1aY23K8QlnY1T871xw01aM/edBMMGaGFBz80/FnC6Z9K0Bsc +YRYjEM69Zvt
yBfdu8c6ELjKnuLHp/8dT8oGnjD/FgzHZwND2a5jsWPC57rXZgeDUspFt+/2 hwOo5ZEuK7cM
Ooosve+xn70eiHRV5IVItzs8WtG1ro9JfV/hPekJt5mOHxHCQ0RuN50evx3K Yd6Cr7+xQZYe
xwfsoilhYyu4Qoe0U5sFqxeddx6SQCs2SAJapY8K1O+/r0Y46Lu5Q2Zb60Bf MlN13nRnRkMj
HPSzfjxy2WBxbRlZ1k2HurbnuPU6JI4x7i3aN2s827VF+4Aoq4taZeR9lm9O l7O8VEYO0HQZ
OYBDZWSUl6HVZc9URga4cKPFBbJvRapkroXkl7jTDeq6ZA5NRuYgUHDG1UsZ OUDTZWQB+fG+
cJ9Hnso7BBeezDc4hAN4VPZFY+TsMUhLfPDmHujijBwZGSX2kuSKMhmZEzWe fsBfF9hV9sXo
zD7SgXQUB4XIQPeuROoeDTqTc66cvx9hCvThevbnt6AvOPuWPE197gLjmeTf fgb1c33Igz4B
ylhtof8N3j+8Hz8dOuAL3Df0gzfWgtOuvsFIiYkGd/8R1G2Mh9iZwt9Z3wkL XiTVmMFBH5WV
odqbN8u18Fg+etxea4vBtc97G05b5oduQijUReQsFx91Z4ssl0OR5Tqgs1wb GlUvTme5dmPq
mDWyXLvJs0bu6ks694wn8GG/XqCzXAd0VmqhT+W5Wa4FU4F00U3n4QPLNQNj 7ywXml1XitcV
3m6pW47XGl5k5y0VbKhDXrlYLryy8un+HL4HCizXAQPL5eBhpRaUaStwV/px p5LloqP2/2K5
ABpr5izXBvfROa6FtOsd6cW742F6jXrRvRfml61XnajAch0wsFx7aAfU0hfL hdfz1ldkuTAr
fY6b5cL7PIY5sFwRcpYrgspy7fL2B+1mubySw0ot3HtP4K6+/tBn+2dedO8e 60CcM2e1+6ha
n4TXAwZGa/EsW9dK2wdwn+21IieMRG66fS+nGeRe0i3lk/3e4zPp6s91P+KZ dNOmi253c2pT
jNECWO1GEUYrQIfROqAcfih/i7fz+9+BxwmgMVBo7Jj9uRgtgHJVHkbrdD7w OA7qCYxH6BZO
ZP87MloHPHt4n+zJGTtltPZMjfWi8xmNjQiKDH1T3jWYbGWMFh9e28VA8fUS t37cmHiqLKvV
i65CtTsuRovPrpTCnNEK0LzelBUc4U25ddVtnDdlvDhdnDjal0srr4UE5cfI F92QbRwZLQ5C
HU9gtAI0w5sywJwungotnEtZsgM26AtLYKDQQjlxAqPFV+qqd5/RhRm535QX 1feB0eJETb2t
zpuyg93firuaXQRGC218urI85035ruStttsnl6ntenJdXfhJDd5fq+1q+wfU drW72q7L0ML8
K/ys/b+ttmvjVtu19EFD9xnMH9R2m/KttjPoUtsFOmOFdnlPGulWx0Fx9FLb QQj/prZr49bI
ffu7fFDbUca/1Xbo1De1HRrxUtsZdKntAp0PUvmgtmvjrbZr/YParo1vajuD LrVdoDO1Xesf
1HbUAd1qu7bvuW6qUgfrN7Xdhr6r7aBae6ntDLrUdgb+eoHf1Xa7vrfazqBL bRfoTEPX8ge1
3e7Sd7XdWXqutotL1NV2gc7Udijvm9oOjXmp7axzN137oLaDvu2ltjPoUttd dKK2ww+YZ1xq
u/3ju9ouLBBT210LydR2ge69MF9qu/3Jd7UdVXVvtR1+fFPbGRg0aijlm9oO LXup7Tb0XW2H
5rzUdrvh39V26M1LbWfQpbYLdO8ev9R2enyev9MHDd1nMH9Q250152q7uDZd bRfoTEll5V1q
O9ANblFX2xl0qe0CnantuNZN72DqOBwIsFiLUPmgttPj1zVy3/4uH9R23Ei3 2s6gS20X6Lzz
5YPazio1jdy3v8sHtd3Zza62M+hS24Vd7zNaPqjt/Kx3JdFeXN/Vdmfrudou blFX2wU6U9th
sX5T22GbvNR2OMO/qe0wey+1HXr2TW0XFoip7a6F5Je407narsGKY85bbYd9 +lLb7fZ9V9vh
ZvmmtnuBorbDMLzUdgZdartDF2fkk9qulQ9qOwMvtR26+FLbGXSp7QLduxJV 2+FG4jk+xGvh
TwFz6+OAcGaBikWOudl18g+4zypooX7Jx6VWvWnUHQRWPs88ED+GpX3PFx0Y 9fdZOswSCVfJ
WOXHDe27Yrzo4CbRl9BlWimTXVhe76KzBaYfViKESjXGYTSl279rVo5qdvWJ wWm/hL172pbm
CTW6tYA9WmFkepHzK2VpjEPpOJcc8Nk3Cy+oDYlU32DBlos1pgyqbJYctNLo hHoN0kFItdeL
rsPmLRGa8OsgnYG7kn2o6MztkSm8qx+xV5BKxvMcyEamcAccun0SrSTldTuc Bw5qCAvtkR0c
oSQX0E2XxJlD+ktlLy6Fpar6DfpNlmnXzvblrpcRblyd4b2kZfWvlkUe2iMz pnKM5Fw4CMnO
0dXmYyOjN54yFxFq4hF103XhnkVDTRvNhsPOBgv23+neS+89p1txH320LG3T jYUDGK70ATO9
ln8HhnsejlgQ0ML9PZ89yGPc9/zcBY06LjpYD9VHR3uqewyY3iJTQOunCMEG erQXXRPzUvG3
anoIFFjuar0tz+s6mrBOzi+OEf2gZu3Qnf7245ZxwBmMhQPcjt/NLrNTd2sF sG7RGccyp2kn
A51D+wyZujwPmMUGSPsy2oG0L4Pq0kN32qccgjqAjS2gJjlKXVqbe9UKT3uG rMkFeg3ZrNa9
Q1fVnDlKaxOCz5SFbBp/h4K0dkCX1nZ5rXL2grS2G7OXSxDN2OQO499LWpvw MXieH5e0FkGX
1g7oUtiuZNFnKkprMzCNRlfFHvuS1g4YpDU0u0b2l/U+awYdgzZ7c6n5ooPL gzK1Lq3RWy0F
Zi5CQVo7YJDWDuhSGLzyypo/Lmltg5VGixcdLQEvaQ0gzaujtLbB3MnzngUy cEU8r4VkiruL
7l6Yul59ooK0dsAgreEJrCpn5dIaXBmF7XBpDbMil2GQ1uCjR53akdYidDT+ AVRpbeILFVud
wziVuBQ2MRnP8+OS1iZs8J9+0b17/GV+fgqP4JEH+9qbpd6QCsI+jnyoKGOp 5LnX8Y8I4dLX
m+WAmxfJrVp5T7u3BeqVmy+FN6rnuhb0ZWdL8DddUddE3MztWfZ8VG3vtda7 vcr1Rzfavu6K
VrJqP5C+muz+33TgipWpnSO8G9JyE9e18A4HqmIIe9M1UQdLedK+Ju9cVi/N KSm8SHmBpSWk
g7DvunTRFXFD5pp5VK6I4Cxz2iDs83BcM/xeCV/mzrbPBFlyLpstOMKm+/P9 q5WXHg4PB1L3
oUPvbUOabLYq3et/BNnsQEE2O6DLZnDCbMpCuWy2sMbbJXMtNN/WlslmeJeS MTx0sJ/Wu9Fl
M3+qOrLZgYJsBjDrbeti2G6M+OG8QLI+QeZaQzzaL9lsg4tG4YEuzEiQzXaJ LQ/hEV02w0TR
Fy7KZgd0mQsvQT0HcU1HsTfVPhjduxJ9ZbB3WtH5hL+7W0/glWDweegzaO5S 59vsJhUBPHxk
+PYjmINJBfyjxF7cWmh/13XcUdNj71wRhOfGEhFuT2G7wYuyqQXBR1BULPhS 1fzD6pylSs/M
pCKANipwEpJT6zBYcBLaV0TUYtLtSDU6wfvKl/mhsxekwGDBt2ml+gQGK0CH wQqgMVgob+/b
52Kw6DJGWdAZLDRZZenDYAHcd/2tDr9AY7ACmN1tzuw7wk0y6DPUb7qh8SkC gxXAw2Cx2aIX
sOuFjluiiDvXEObkobXMoYMTyuMqwqca3RZwozo8QIfBCuBhsAJojBM9t+iG HRgsgmuuF13P
6bkYLIJz1YvBojsXY8GcBYJ6e791bQAzXQIuunthqvegT9RhsAJ4GCyAvao2 xBgsTMGky7Mz
WJwVvhUGBgvzN0dbgcG6IGOwLlAYLPo3GuNkDFaoxBgnQHsT3+pwNLrQATfQ vXvs3mCTj916
8Jy/w6EFN742yu/AIybTj4ymYGHNNTno7rW5tzVdYwPdUC/doA4HqDpCuwHp bbNSu25K+OW0
VftFZ2YqQR1O1x+7W0QdHqCjDg+gHINwp1qrfPj7aKIDaGpuOi/NdKvD6Rwk l+ah884fTXQA
tdIjsL7+jo1w8OxmWMPVWx2OmVKp9tD5jMZGOGhnfenqcRlYLnr4tBQOdjrU VLocxS0KF5r1
XFsU/k/NdAVmXAFnJyrlnOUK0GG5AmgsF8rbnGy5WC7Um1KLrBS9gESZGhZS gWbqen8B1JOe
j8ZycRCq6sjVuOJAh+UiWPjx4a6O69IFwskpR3U4WtjtUdiNKwo41PpcdGFG gnHFrmaWPi+W
ixM1WlBf/7pAY6XoDjVy4K6+ohtYoHtXonXvG0nO8aMOHzBAU9MFVeGNAg9t Ve6bOjyARx2O
j1tdctCJmhuVqDnAUYcDFGuPQwczlPQ+SysUxVOuM1GHX5CpwwNo6vBBG8Cu 86fqcIBpNbkA
RB2OprSqNgymDgf4VLWGMHU4OpfoNO/qcAzCqPqSZupwjkyfcn6JOjxARx0e QFOHA1qi1j/q
cA7qWE9Qc7PRqbdLHc4RbKlFupp+biYgX+rwAwZ1OEem9KgOZyWjpR9RHS4j w21x6OD82aW8
7oczGKAlPRF1eICOOvwCRR3O8mjZGdThAP0mE3U42ydmEUcdjn48dd7qcIBr 9qgOxyAUO0dN
HQ5QbzxThwfoqMMDaOpwQE9RkwNTh3NGZN+dvfTec7IVK8JoscSjDg9guNJr hWa5/A4M9/wG
d7NSvL+raxLDPV+h1lnzohuII6HinarDAS4RQ0wdHqCjDg+gqcMB7b9ULlV1 OOrdB+p1HdVm
6vpwHVV/Mz903t+jug5gVIcH+KjDAc6V2ymAdbfe32V2xJl7LjqHjjo8gKbm Zl/MgsXU4ah3
pb4uOm9fVIcPjHzqyjOatMadk6MyZJ9YuJnfQ7ase2fI6BUtU+DSWoUVcYnq 8AAFae2ALq1B
QG0KubTWLF7IkdYaDOBb/3FJazBGk6MlSGsRdGntgC6FNZh8jlsdjpqdaVS6 GowJXFo7YJDW
0OwW2V8Z6acEAU6bnVYuF93ecEnfklxawwVRxhP5tgMFae2AQVo7oEthuIUY NC5KazD3efQp
49ANN3IyaQ0gTfmjtIaDcERLJal39HQvJLLg+dp73xamr1edqCCtHTBIa1Sv 5lsdjilQC0mX
1jAr9sbt0lqFxND0eVKktQi5tBZBldZgzZhVbHUO41TiUhiuxdyCPdOXNLrm KMJ96LEOxDD4
qMMHtak3Sw3+RRjMow4fYFZobe7q8AAddXgATR3O8mbrr23R7OY7K3aA9QnX wpc0evZ0002s
yVsdHsCjDufHKauYQjU3K1lrHOhLBqH1Fx244narwwdPHjWBFHV4gI46PICm Dmd50r6jDme9
syvXXqW8wNKaOhzgmjNfdNPsuo46/AJNHY6P9xaa1wy/V4IskL659lSEVXDZ rDPS2fV536PU
5ksP1/fhJ3UfOrjv2IY02awhEEeP6vAABdnsgC6bdXB2aoXrstmu9xGLPpe5 dvue3MuPSzbb
oI7hoYMxYFFmwmSz7ma4LpsdKMhmBIucIC6GdUYprd9AcZk7MhcM9S6rpC8Z abVUPXRhRoJs
tkscJd/qcE7UUNMKl80O6DIX7OT6COLal7axqfbB6N6VvA3f9SUcP8dwa/fw s/9VRF8xfO9/
GdH3Zfjesxu+q1gH6+vws/8+oq8buuvjgf/dxwcb98/gvAzft3DwkPIYvu9N sQ6EZwZYw/Pi
u+hEBYVKHglPFEB4TGQ1WJ8itgBUE4WKIK9wtzDoSxojqynQeaM1mutX7Mmw eI5gQCZW9sjB
ED05mdsFm2vf8NglNMKXR79At+c3Q4KD+ZSZNlRTr41spg0HSseZ8YCPG6Iz LJdAxxB9rxmG
soH1oRqiZ4kW59CXdK7TCsvAXy/wGKI7ON3A3Byu+gyG6GazGOgexBzqhI4h uoMjGKInXIgl
LgWwoKO+lgzmpOvHx2A9zSZ0xxDd2Cw0Rk1SHVrBEN1AjLUbojuY3cAcVtBg swzixxscq7/o
ygO+HpDHjzALNZjmuSF6VZE8LBAzBb8WUlblQqB7L8wvW68yUbsvxxDdwScY ouM7mNYBdEN0
BDoqAZRZIQeLReeG6I/wEKjGDNEDdAzRA2iG6FBdPDI6xxDdK8luYL7Z+MVG hzC11CuM56J7
91gHAt5bnCw5zvzveHKBveC99RkMx5lzRWHNmVHLtTa3uLXSTbf02bqHoNQb XCnriSRBqQ8U
glI7qK+3EJARN+3b3z0EpT6gB6Vu2HxgUnoISt1MXdM92HSD51p5DvQlnd/s a77ofJBCUGoH
/fjsmBNuhSpPzH8KKA+IFkSeJsMZVmmLlPtSVcv8BmWdQ6gDlvR0qAp0DkGV p0/nB9w8cK/d
LOo7zRQGeFZmK4BFPU8sg76kMZUiSKDzMx+u1FXN+u3lbOD9jTa6B4JWVC8v BzG1T4E5Ilgw
WxWlJrfk71VvPnNjgDHpSPcq61U1n4HO+huP4wOG9d3NnPQjiN3bbLgchEZ9 TTGa3/tdTqyy
bLgQ8kCPJ3rmEmoUhWmZq/dXh/MM+jK2BFhpbYk5pobUIBsGvnYEuvdCUpP0 MMvJIjDEoWDI
VZ361p4Rb6Zd93z0ZjpDZjxmoPP7ZsrDvLax0LC/I8j+SD8CNPBQ+qYb2exv MaVJVyEhHZtK
G8VA9+6c2t8micnHxamhQI+zwLkh0ArZUeEm6Ygsyilwus4QvDLLx18Cka2H nubqL+HQE/wl
DOzL/SXg8LqUB3B/iT0VT9K7XcOcLFWo9RMKFI2eY85INxiYVmbuhDnBdpwy J+YvYdB4gr+E
b9sT9RON0UV3g+KWOXLwg9i3cz+QlvhAvI90YUaivwQk7iJnpNvkDNOW9BMK NIDT/SDg/a/M
y/GXQAjltS66dyW6SLaASgcmq9b/ziGiyZb++ezwGfT8HPYt7w4Lc+JgOEX8 28/gvMKcmImj
thB23IyK2V9pMhjR4ALbYSoYV11NUTdz+f586k57fb7oA+AdRJQKaLuvHbVM Aj07BUZy7Wn3
jlr2gHXoEMKB3qFxR03c6uCXz446UNhRDp4dhaAoLT33jkL4FD5onp2ywHnN du+ohbvMBCyl
w1toK/eOYqiOJ8cd5VDcUQDJpcfNsxvDJ5E3uAewxZ1Cg86U7x0Fm8yi/LLR hRmJVm4WCCPu
KExUL/XeUQf0nYJAGC1uHh3FYovT6N6VuIVdoiejVWt/x7W+Pt2tBwwMJWzu crmu+mXKuHjV
wwSQ7o6BzmxXonx8wCAfL7OTPnLvgkP602/5mAaA45KjT6ODfOygbR1mMaA+ x1b/nwKqkHu2
zr53qMgbJ+RwAEPI4SdIyPpugxgaWXk0f99BXgTK/oEuqQfwCCGHHzN5Gh5y OEIecjiCGnL4
MQvdEUIOP+Z7MU7IYaaMENHQQg4fqJ+QwwG0kMOAOuPT9hByGIMg16qHEkZj RLERQg4/JiQF
uoxEKSKBeHDbJ1PbI6CFHD5gCDmMMaSLh/M/rJkvDoFPYgtrWS86hzzk8AE9 5DCmk2Eyegg5
jGQg6ZF70UMOPy7uecjhJ4itHnL4cYbRQw4fKIQcPqCHHMZw0ZZzhJDDiONC IwJfwN8XukfY
EON2C65hf4cDgCFPahq/Ac9e8m9P1p0AxswpXuBHMGbdga1r4SvetUMh5o11 dXCvIN93+3qX
geh24+lOidBz9PkO2mKX8oqtmlxP0JSU57Ve1xmxk57BYoMdOuQugHLmKi+Z S/Op1yFqxFRn
fcDdDyhEtTyVGtkArzfd4/Ievy8fVgZvs+PnT/lcEhicM+lAsTkGhs3jwxA3 mRkuBjqDruF3
8JyF7/apZeYWd5PoKaXF9ndcmglrTrVuH8Bzi8G+WWxPwjz1zf4/r3MKNsPC rh+6IeMR1SK0
VabM4mqRAB21yAFVi4+42XM83/8OapEAmloE0F7W41KLAKz1KUHdwfwQRXkH U4uw83RECXQ+
SEctckDf6cjkNcOp4X/H/YzsFHT/ukBcnxGkCWFhRPEeciYhzwIfPbvnTDpQ yJl0QM+ZhPQs
XSHPmZQt+IclL4AMO9P5O+kDYT/pkQajwrffgT4akcxyJtECWTTJIWdSzsbP eM6kAzFnkppD
O2g5k9DALKLTyZkUar5yJsGslJGPgtIf5qLCnZ2jIZt7WZAHYCEqhh6BDrmL hmxPN+DI5hji
Sv8AHaV/AE3pjypyUsgNOHKXMT5Kf/Sj0BEmKP2ZqoGB2IPS/wLdgOOAJ6uA RRqIp1TGY2i/
6SzFSlD6B/Ao/dlsKgPPyQCr5Eu/r83uxlmfJAzPqPqI4Ob2m81YusnN8Nah FcztDQxK/wCa
Mp9ZCh7VTLsBB8B+PQ4AUvHgKP2Z94DxDYLSn5bTJbVrgZj787WQEDEh54vu vTC/bL3KRAWl
fwCP0p+JIpJytG7AgSQfOQVQZqUUueTdgANpQ8gautL/gtyAI4JqwLEhZa6P 0j9UYsp8JiuZ
LR3oS3cec2UGuneP1Sx2M6+9nnPV/+53soWa+/gdGG63YlZ8Z82VKil+rrWJ VAvzuemayr7x
ditNnz7O7XagcLs5aPbDVYwVvv0db7cD+u0GA2cm5Ym3G+zGlz+Q8taCMbI8 WoTbDabkz1gX
nQ9SuN0c9PO8WMyfoPQHOJ8sZ6Up/WkvSvNtV+bDylL1oEfpTxNNhoE4dAc6 Sv8AHqU/TDmV
pzNlPi2bs77kmdKf9qz0Vwp0fuYfpT9AEZtc6R+go/Q/oCv9WZ6tClP600hY FC9n9ayXfv/r
DzWLrlFjcPobj+MDhvVdmddq/QYMSv8AmtIfJa6kJ5Yp/WlJO7NokkXpD0gs rYLSH80Wd2JX
5nOOaWARlP4yDLigA917IanFbZhlU/pfQ2FKfxkyU0U/Zn/dl95MPmQMyTov obf4fXOU/gDz
6HLHitL/QEHpH0BT5nNKH12FpvQ/VsaH7lvntM9DfRqCipLmv7KM/Yao5hAR bxKYrpKjC3T7
HMv9uVSUsFquNDlzFWWAQv4vB11FSVNYphgLKkqa/84VNPw0rRXf3KCipDmx qJ8OHd5bs+rv
LORmHcb8ev4vh4KKUsBcL20kGqOL7gY3FjT8bExJere75REMQ5JpdJUuzEiw PNolNvKEQUXJ
iTLx2C2PDuh5vWB4XJV5ccsjtLGosGh070ouy6P9vb608uFYeso3n/MzxwiY f09y8zw8uTlT
kv9zqG2M/0Yq9TH+wdp2L622MU9t6EGT6J78KR4Qdcv98WeI7gnfJZpN4bK1 T8R0aosHZjuF
ndcqO8GfNEBPeMOKP+v4TbH6iRabT7G724jC/qf+/E1r67exEZOsf/pP//k/ /uO//Nd/+/Ev
//5j/84//v1f/u0Hipo/moRURc489UnmT1FGkiD81Oiq//o/2KjfTtjVoHQa tH/OehpU3w3y
OfXP+VPiwuLUjj//KkRsQUpzkPyVpVw/07I7Y4sIPyUuLLsdfv4+RGyhV/7e QE2cOvelhXzV
WJnH87syuXF+g2BgewAJTTDBDX5DUwy/K5Lslj3CABkQhRB9yBrsYlSWw8dk 9RoDPk7SJRjo
7hFjaFTRe5IOkRiaWSoS6mtfea01yYypdA2MfYM1JdzTWB6DVDUad4itM0AY 8nAE9l+PJNls
TflwjMjmGBs/ykhXZsOUUj0gR0RvaAcJke9gI5A1UWusc5/KaO4kBwioF7bs +PcAJKfQYIze
oG7mTCDTNqAny0sGK0GwEYxIg0DC9vE92qEvaXTPcx7wl3WQgesabWAHzS45 DjBCc1A7uJ6e
Dyh9QfLARtez03C+TgDMtSaZIubuxpTbOw/ALYDo0qBqA1V0pPpzSDuYN/EB 2fCK5MPQ8ura
xd8Z/lAcbBUlKuNic22YpXJFbOot1B2IdegYR7rNB2TOU/e8rli7vPQ5yczr CmghfHEzTyMt
b6Q2pcPLBrDhih4vEMntZjurV0Ga6AKUvK6kg88Iu6d5XdkXaH3YHOZrBUTx 1aEvGQbe9ZFO
s0azXs3rWh/EoFzvZi8JyXuDQ56em3n7gmzhwc3mA0EoIEpen0F7XfMbhA45 zVDWJoNkzCm3
9wOAPC6ucwjZj5H/+w2yS/65lgqN49NOC6vot/DtZkTlxEwNck95gThs2Gxv Ic6FWk9ZS1x1
rtWHIBarXqsKuuIkJZ3Vl7r4IkY6aJiaHB2WYroy+3CXpSYppisTznOBV08x jfJojNksjjah
zWB3bkrzL0dj+pbnOBsih6HJPXPnH8cMdK71edFlfQxrwdEDIA0Yr7GzZKg3 +Iit+jWgNA/k
6aLZpQFSoei1aAPHvCtOcCfpz0WHDpckx2cSCQ6gbvOuWaM5Bsgj7tCXTtzU 28PoFuZBzuiT
XbpCZY2k9L7+0OxcP1yjuUhS9UZfNV0hSHKMY4Sl4oGWUJPtBl3rlLOSzvW6 0cVXGZXsosuB
SNfklo10WAycUSypoTPVEWVD651cIYy08Mh9Q5dg0iGGKbmM2JMpxpE3uCkz 5w+7qjQDqZ3g
XYcUk6ymzSIXqnkho9lzHz6yAeijiu61lMeBdBhSf9JFlyWZLns8sw5XFndG OT95BeEtoPK8
c8eTv0lfmI3a9jGDQdTXAVUQObiXbyAlnBbcXWvZl3ZJNe4U+r3X145CztBc bjpEP+1ybZqe
rUoCUtlmEiQf0JYO69ncWt7etUP3EyulgBX+5vNzC0Hyq4Q60AudejahywKZ no096EtaJvqz
ytAJyjWYng2dpz9YpNtX9sjKnKieDWNMLejZ/Ez7us4sIE7Bet8dyIrR8nsW uij8Qlm46953
xwYpjl9LFvk2Ydn5Bkv9fndA6THHPEc0S522K/3chu4nL1mOZrNQi5oi8zhh Ql5Acm7Qx645
HV8Tmjnm/hKQ+erfYG088OJYLDH3eIMl5Rb7s9kfjX/TzFtewWfmV5lQhMlE 3yC30N0kPAaM
dzvx5EzGo3lCXraz6pErb7ysuz7Pgb60leWpL7qWun6qWvXK5CElLH5cJcLT +7S8p092P9Q6
woKe4BMVHu8InB0OmYpLk6wvFqYyVZVPW3KG7ulNQkftG5Z7Wbp9+PFqutcr mK/K7S/jz2QT
X9IYPvs1D51QocFBgACHSKdug5Fur7q+hG7ZdqxTVJeoZO6jXaauSziD5qET ADEagEP8eEsi
KfeLDh5xUw6y1FRugwLt4RkCrp9SStUIKhiECktZHQTq9HH8jkmpZ9PROoNb YMrbH8C5us45
rAikKTJ33c0b2GhyFYFuiFkOD/2mBy20b0Wvhy3+LBuEp5GLPzP8XgmyQLhp nrDDuUB03MP6
gm9659HX3eSEs8LzBT6iSfqM3G2P3pJq88CPhdcravpRGSpDBTAzEWFjHt30 emnQq6gEiHTF
NtOhK3YOx/Kq8bBeL1zhG1nk6jYe/Hg9wpF0qFo2lE1qDHNCZ7J+jcu38fNh nSaPmMlJ5bkx
VtzucMgtNlyhOcyUEpi9prEwLqawqfVjoMOwJh7Y9/DrEj71vtunzd5iWc5H 5ARXI1dNOBzh
UCsXyA322urNLDToiFO+5mlKVOh7PhFrbt10mkvMywMdHDsfO2jo9lqZKKGU A5EuS2aASJdh
VdRlG2sMrM3xyBNrkxhYWB/wMe26ZCwGFj7W20TOX/iICNenf6tauYXwU/yo LmXZGdsK3zGW
yiWjwDV11hTpMB4tiXhj4acA0lzRKt0j+Yya49976l+NgHuRsMEWIwFQ7q0f 6Etnqsx00YGD
tlPOG9GsscaNIPMFD3VdMr1JHrRrdcA7ZT79BTbTdIUlsyn3TryWAp9ln9eS oXNESxfdMlVI
WDLj+YlWx6UwkuSuv5bMCHK70WEC9VNfMkPjsYYlM/TXtWRoqjAPfwoTyJ7P 7ImnRL5nawT+
UpcCnCzwenUtGXQqP9eSwXjIHRJmq/sFqet0CNvqf08JVXavW/iY1GvJ0HhZ OTRfMh0BbV50
EILS82pEs8bakhm4QuxqU5udOpoEow5n69CYUpcqAZkCxosOzMaQs9psdgCq EtaCrgCisyeP
ebXZAbjrFqlQbHZQL9NythB0Be1LIv5Z0BX0g3GOHPqSzo1U5gF/Cbh3jYBm s7MlVfHsD8c3
cyisIOZrzYzjEOmqDdYJugKQgSVbCLqCjxkrLOyT0SU437WfBqw55nWlDojG qjwxmx2Ae//2
OOtwGnnInZ6gKwD5+t9C0BWAelZYMBVW0ts6kH7MLDk33dEPaNAVgjIyJ+gK QCYdigtkj3Qv
L53UcJXhoXsvzC9fry7kq80OwP6oNsFsdgAyNV8LQVcwBXWuAHKqlqgDTtAV TupSiUlsdmQl
VlFtmM0OwdyETmx2OPU5mR6+d6Oj3Z+LElJvX+PHJV1giYynXHTvHutAwPCw H/3ifMRD7TrW
Z5IkNTeIOLm6YP2s35RTpCxfc0hRnMfrrJ8wYOzXWb8huu1cugQE4e9Jz2bR JcwqgSMvXcI0
lZYegxNmt08/fxdTEgddwlQbm6BLIJ0e165LmFn8w4KOYMLBxQVcFV6YHmOM iw53RFMdhukS
xjL1uR2f0zWYOgtTIulcmtmJS7NdqxuB5UsJG4PN2BOsV4TTNby+yy5wzSxc wJrKMqqZRYz7
teSYdM3s1EAoQTM7ETBlvq4wZAAoaV5zOiVe5z336yjsjQ7K2hbOQ9DBq6mr RtKVsEjiTDV5
BOcRbmxAl5gBXppZjGqa16nLBq5XxVMNIiJdl7DEl2YWrmxycLrGdY8BxepL M4uJe8q66DSV
x6WZjW/E/fE34lH9WTT87M8/+EaslzJ0YnzZ/edQmzyh/cWL9Mj/YG1iesHa aHBhtSGGoLw2
719DTtN9L59fKTw1V33nh+uJ0uszfz3vyfTlkxLrj2FbJfxK/Xclkl5LDC/U OGaKlJg+t7F8
G42PRgPFjAYqeAtZgxDcpZz+Q+zw8F/PryRv///6P9CW389MaEfzdrQfEqKG 7eivdti8wcxI
HpJhZsRtVxCQwX+lY7Pw3URg8l/177UQWLZG9q+s6o8ZfoU18rIO4IMvbhsx weGTP3QNCCTt
ZgDMGlVvLEkYQjXMkUdTJPq0cprYQV3f4PEW0RwjppaxhslLZMKjK5JJm0EA rNGeBaw3eZRe
wp/iNaqPZVQ0c864UymWPGDu9+bFu8DQ0xmtwIM1nhmgK2JbyUMYoo+uPGYM swdb6OROn5u4
1OUsl6l2nLFPDNMH6jk3R2KYPMxC45qT2GbYuyw84eCbAK0ckfygqXiF6I9R 8WEpa251faVd
HDCe1tpJ+i7jUU9f3bvEVjNEX4wTYq4b5u+yzMCO2NGmDUt72SAov2Ec7IEn mdyOLgyTAsdH
RJMWVdizxJsXL2imink0qn7OppCCGxMCYuZ09FZJXQURpF5fLdVH1hBSaRzC QAUGaI/eVRbE
GmyIUyMiUuzRQLtM5YQvZ0psPX2uUHrFiYw+mv4rIQzjiCPxHq8vG0W2CN+a 8itB6TyLY0Ra
1vHxdhQJoo8e6DMn2KP9Xw35khlhgtRA9YhpQhzrhFWyWaBQ46td2toma053 b8JLyp5A7C5/
wB+yUy+sY1+1syPgswTFCjMn2JM+IpbCPjls+zQk4d8LG8jzZt9qiRq2xlq2 JEZVbEV+xI73
hfGswcO08dqZPpsrLBZsSFxxcUlljbwdqODV3zghzmfDoWhz1sCUzcaTLs4o PEsal71/U6mX
uzWA5kz2Z5bsqPvfzmLjN2Jm4WAQDptUiYgz2Gg37iHULnwz6GGHbsiXVEc9 XqB6xMoDtRhz
DaMGyOg+h1kTqcf9D6+eWktY9RuhLe3+tz+BZerXFzB9AcuabB0PvfYAlpU9 ZrP0CQl00B9d
GAyr67qntYkL7gtjrI6zbtiHibxEzNegpzCcOsbz+nYKS39hQ4b+agvSEvZv 7VtITwpDAHv1
Qvt4Hvl+y12UYGe/SesQXzNQDbHxAWIyKfxNhuxJa8JTZpyC10TJVi5JDqvc z2tXhhU559hf
1PkKyWMgmdEavG0ajslqT11w4OFhl89LF7+cumf40AVfIrzi0y1QD7EC/7VB PkKfr/DqjBS5
huiLNj3NAlUT9Uia542rqD04Ljh74sLbOoLzYfXKyxXC6MNIxhBtBZV2gYpe aTwr/HkL5gBr
X5bw4ZPXrQxPbyD5PG7B2YrHcrG3rcy0PI2L2562CuISY6SbvVihDZylcImg rU9+IhXXkb9o
wU4AagGkyzD2oyDaEg9bm8T3VOsC0LiFemKWKfl0sJ3cKECNwc9aKl3C4521 JM/uvFAO1W7O
LGy3W8vBdag/bKoayxXYyIG5qcdWrkCSe9q10eBxAgfQC+sS0S3XYyhX1Mwl V7OTI9VgO9xM
Dj2A2QjaIdZvBSovYVHcSA5x73mQHSpEH9sCKmo0Ezl4XXCoQ8sQ+f/pr9aq 44ufnRWvcmld
ZyeehvFic4YRDiqz1OvsxEMzAmeds7PCVwxcYzg7a5YQP/EcgmdLb98wbp+r A/vQx2PJCxtI
VhjPzt0H2rzEsxNv2TBKu76tEm7ihY0x73Oy8pm83VgWnVo8OyvNSyOvgndn mNbFs7Mi/zmm
JlKt8Yzr7KyaS1fPTr5Cr8i0vScqqhMQZFvk+/2rUnBEMIfzqxzh/rvoVgfi oOa/LwxqQWoF
EVf3r2q6uPCrRHH1NuyGjwtubjOPtz+Lb3RxuNjjC38XdpzBMxCqw5AvUA2x yA1UAxY3BWWZ
+kucjvd/xZqh9usgyZVfB3tU94WyEJ71B8xEVPXFuB4TrhZTmSz6LYGPNeRL W19bpLI+oizl
hA/WXcEFj6BSGJzwO6bOAldhpvISJ3JI7FpBEueddVdJl3R4ex8qRWBKo+qu gxXVYtG9GO8r
hmgn29rs+qHyiczBCLHwcSg9Pkmccj0lz8ThHQhTYXYXHCA8sO+NUbOKZQdJ Lioc7FEhScoa
MhYqSkmNWJZnSpqOYpg4ZHEu+aIa8AGvd1lwL9wLI9RoSHJx6GBZxTIpazNy 6KPeqKwRuf7C
SLzG64wiAm7zUFq6cfQVz7CAxHYodubcex4XI168ELLlUClyjbVhp8ZXu6S1 Uw2z4pwjmTLH
4/QUGZdxfBQP7w4fE6rMcagyuvtBkgd3P9gjoWylrPFa7ahxwC/OZxOKex6T Yc4REK3ViwoR
4+GHOT2s+8GWR3XnlzB5oRUbd8BUqc0QbYUkQTxUEHgXqSyiO7CnZ/ZIArof JIy/Y1nDubMs
tAuHm0ZzZ41QXmBcq5SVJNOGIdrvAsP2QIU3kX358iCew/utmAVyx5dU9p+Z fM+3roKhO1P1
ifZnOOeRObhf5zx17e0+56fyFoGqCkvNW7UpFTwPE8sXhu4g2Rk6x5iTR25/ lM/b4hNWszN0
EROGDsi+lWTIlKEDNsAyoh1k1QpydI82HfnSnsPXLVANP+6MoXPsapkexp8w vyOQ5Rd6BB17
+zN+sxCJa/4GW65+KEuFqLNBkO12hfvti95jGkX2UEGGbsXLIpXKBczYBPVp YYC23B35Es+v
vQlmpMJrsWzJNcVMvCAUGxNRL7XmcAR3uBpzHKyqAlvMNt9/Pm5E4Zjd+2wj zb0jJ7B7Qu41
UGl/sYXVgOJgWl3Rc+v1Z6xdMZaLN3ogGbbXhnzJnEgIwkOlM3fVblg9ym7y BNjNmldBnNZy
2M3i+1RW3IJ0Rcv5iVQwbM1yF6hnM924Ks6ZrI7NB0nu13ywR92a6UW1qgy5 ejVTwQ+7dl8E
1N3r1rWlwtbr1jUqKD8nJ8s8mtlvxCtjVrVcfhwEqb5MlAHGUyx5zgQ6fWW5 USM2i967dFJG
K6inN0RLe4awtUZ1Rv94MrMGvATAgV8dmfkt3A8M+xUw9EtsXR61nzNER23A 6iBQvcr/si
FUDForum. Page generated in 0.03745 seconds
