DSL book - tabbed.propertySections [message #577542] |
Thu, 23 July 2009 12:01 |
Bill Hinge Messages: 156 Registered: July 2009 |
Hi Rich
I have been following the method in your book for EMF-GMF
editors.
I noticed on pg134 that when I copied the property.section.domain
I ended up with 2 property sections in the diagram editor. Confused
me at first as in some perspectives the second copy is hidden right
at the bottom of the editor so initially look OK.
If I delete the property.section.domain from the Diagram extensions
then the problem goes away. Probably obvious but the text didn't mention
this.
Also I notice that on my tree editor tab, there is a white space above
where the properties are displayed. In the diag tab it displays the
name of the selected node, but not in the tree editor. Additionally
when I select the resource file in the tree editor I get properties
not available, I've added the gmf & gef edit parts as shown in the
book. The nodes under the resource work fine. I've checked my code
but can't see what I've missed, any clues as to what may be missing?
regards
Steve
FUDForum. Page generated in 0.02800 seconds
