Home » Eclipse Projects » Virgo » Deployment order based on the artifact type
Deployment order based on the artifact type [message #577137] Fri, 28 May 2010 10:30 Go to next message
Hi All,
I wonder if there is some benefit in ordering deployment based on the artifact type. I see benefit for config-admin property files to be deployed prior to bundles that need that config. A simple use case is to bootstrap spring application with cm-properties, where config admin entries must be present before app context start up.
Dmitry
Re: Deployment order based on the artifact type [message #577164 is a reply to message #577137] Fri, 28 May 2010 10:47 Go to previous message
Yes, you're right. In general, when the user needs to control deployment ordering, they either need to deploy artifacts in separate groups or, preferably, use a suitably structured plan which therefore controls the order in which artifacts are started.
Make sense?
Previous Topic:Deployment order based on the artifact type
Next Topic:Build Virgo
Current Time: Thu Sep 25 00:03:54 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
