Connectathon perticipents should install your one instans of the bridge [message #576691] |
Sat, 09 December 2006 00:51 |
Eishay Smith Messages: 109 Registered: July 2009 |
Hi there :-)
After few discussions with IHE it was concluded that each of the OHF
Bridge users should install their own instant of the bridge. Actually,
its not that bad :-)
I listed the steps of doing that here:
http://wiki.eclipse.org/index.php/Bridge_Install_Steps
It should be very easy if you have the binaries. Since we don't have an
official release yet, you have to send me an email asking for the
binaries and I'll send them over.
If you see flaws in the description, please let me know or edit the wiki
yourself if you think there are clarifications you can add.
So what will be at the Connectathon?
Each of the bridge users will run the bridge on the machine that runs
their application. The bridge was tested on both windows and Linux, I
expect it should run on a mac the same way (its a Java application).
The bridge can drew the RHIO configuration from a URL. At the
connectathon we'll provide a server for configuration so we'll be able
to configure RHIOs for all the tests you'll be doing. It will be very
useful since based on last year's experience finding the attributes of
all the systems participating is a big headache. The same server will
also server updates to the bridge in case will need to.
See you at the Connectathon :-)
--eishay
FUDForum. Page generated in 0.04088 seconds
