Documentation is misleading on audit calls [message #576549] |
Fri, 01 December 2006 22:14 |
Daniel Hale Messages: 24 Registered: July 2009 |
Junior Member |
The documentation on
http://wiki.eclipse.org/index.php/OHF_Bridge_Documentation doesn't seem
to match the wsdl and may need to be updated. For example, the
documentation lists auditPatientRecordReadEvent as:
auditPatientRecordReadEvent(int eventOutcome, String initiatingUser,
String patientId)
* eventOutcome event outcome from AtnaAuditClient
* initatingUser User Id passed along to the IHE Actor
* patientId the id of the patient the record pertains to
However, the wsdl appears to want a patient Id object instead of a
string, and a sessionContext instead of a username. Audit also needs to
have its first letter capitalized.
<wsdl:message name="AuditPatientRecordReadEventRequest">
<wsdl:part name="sessionContext" type="tns1:sessionContext"/>
<wsdl:part name="eventOutcome" type="xsd:int"/>
<wsdl:part name="patientId" type="tns1:patientIdType"/>
</wsdl:message>
I assume these are both referring to the same functions for use through
the bridge. I wrote my auditing module based on the documentation page
instead of the wsdl, and needless to say the server wasn't happy with me.
Oops! *slaps head*
-Dan
FUDForum. Page generated in 0.03323 seconds
