OSEE 0.9.1 [message #576265] |
Thu, 18 February 2010 06:00  |
I have been able to successfully configure and run the OSEE client and server 0.7.1 and have been trying to integrate the components for OSEE 0.9.1.
The existing setup with 0.7.1 already has a postgresql data base configured for OSEE and initialised.
I have downloaded all the packages required for OSEE 0.9.1 and have launched the server, but i do not see the server getting any connection pool size from the database.
When i launch the client the following errors occur:
1. Reason: http://xyz:8089/osee/session?operation=create
Error during POST - status code:
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:216)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.authenticate(InternalClientSessionManager.j ava:111)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.authenticateAsGuest(InternalClientSessionMa nager.java:103)
org.eclipse.osee.framework.core.client.ClientSessionManager. authenticateAsGuest(ClientSessionManager.java:99)
org.eclipse.osee.framework.skynet.core.ClientUser.executeGue stLogin(ClientUser.java:105)
org.eclipse.osee.framework.skynet.core.ClientUser.populateCu rrentUser(ClientUser.java:82)
org.eclipse.osee.framework.skynet.core.ClientUser.getMainUse r(ClientUser.java:50)
org.eclipse.osee.framework.skynet.core.UserManager.getUser(U serManager.java:63)
org.eclipse.osee.framework.skynet.core.OseeGroup.isCurrentUs erMember(OseeGroup.java:75)
org.eclipse.osee.framework.skynet.core.SystemGroup.isCurrent UserMember(SystemGroup.java:42)
org.eclipse.osee.framework.skynet.core.access.AccessControlM anager.isOseeAdmin(AccessControlManager.java:609)
org.eclipse.osee.framework.ui.skynet.ArtifactDecorator.isAdm in(ArtifactDecorator.java:108)
org.eclipse.osee.framework.ui.skynet.ArtifactDecorator.check ActionsCreated(ArtifactDecorator.java:92)
org.eclipse.osee.framework.ui.skynet.ArtifactDecorator.addAc tions(ArtifactDecorator.java:119)
org.eclipse.osee.framework.ui.skynet.ArtifactExplorer.create PartControl(ArtifactExplorer.java:336)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4212)
org.eclipse.ui.internal.WorkbenchPage$18.runWithException(Wo rkbenchPage.java:3271)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:597)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
org.eclipse.equinox.launcher.Main.run(Main.java:1311)
caused by
Error during POST - status code: [200]
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:163)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:211)
caused by
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.getCo ntentType(HttpProcessor.java:218)
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:154)
2. Problem Occured:
OTE Bulk load persistence has encountered problems
Error during POST [http://xyz:8089/osee/session?
3. OSEE Error:
Seesion is invalid authentication required.
Please let me know if i have missed out any steps in setting up the client or server.
Re: OSEE 0.9.1 [message #576908 is a reply to message #576265] |
Mon, 14 June 2010 07:17  |
Dear Kumar,
OSEE 0.9.4 is now available. Because the database is not compatible with 0.9.1, I have needed to initialise a 0.9.4 database to allow import.
When the app server is started and before the init has bee run, repeated exceptions of the following form occur. This is normal because the database has no tables in it yet:
SEVERE org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl runBatchUpdate (155)
This is the nested exception
org.postgresql.util.PSQLException: ERROR: relation "osee_server_lookup" does not exist
I then ran the init (option 1, to allow a test to be done on the client before using option 0 to import my real database). At the end of the init, on the server side, the following two exceptions were reported. However, stopping and restarting the application server yielded a functioning OSEE.
SEVERE org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet doPost (96)
Error processing session request [ org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor @1015495]
org.eclipse.osee.framework.core.exception.OseeInvalidAuthent icationProtocolException: Invalid protocol []
at org.eclipse.osee.framework.core.server.internal.Authenticati onManager.authenticate(AuthenticationManager.java:56)
at org.eclipse.osee.framework.core.server.internal.SessionManag er.createSession(SessionManager.java:144)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.createSession(SessionManagementServlet.java:113)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:87)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.eclipse.osee.framework.core.server.internal.InternalOsee HttpServlet.service(InternalOseeHttpServlet.java:79)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:502)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:380)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:535)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:880)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:748)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 219)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:520)
2010-06-14 12:12:57.703::WARN: ERROR: /osee/session
java.lang.IllegalStateException: STREAM
at org.mortbay.jetty.Response.getWriter(Response.java:595)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:98)
I suggest you try downloading 0.9.4 to see whether you are then able to run.
All the best,
Mark
FUDForum. Page generated in 0.04990 seconds
