Home » Language IDEs » C / C++ IDE (CDT) » Debugging (Cygwin, MIPS toolchain)
Debugging (Cygwin, MIPS toolchain) [message #58078] |
Wed, 15 January 2003 10:24 |
Originally posted by: goran.pantar.xylon.hr
I'm using Eclipse IDE with CDT pluggin on Windows/Cygwin with mips-elf
toolchail (mips-elf-gcc, mips-elf-gdb..). I can build "Standard Make C
projects" and debug with Insight gdb as external tool.
Is it possible to debug with mipsel-elf-gdb within Eclipse/CDT debugging
interface?
I use:
CDT: org.eclipse.cdt-200301080308-win32_1.0.1.bin.dist.zip
Eclipse: eclipse-SDK-M4-win32.zip
Thank you
goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58148 is a reply to message #58078] |
Wed, 15 January 2003 13:47 |
Originally posted by: kishore.tlon.de
Dear Mr.Goran,
I am also facing a similar problem. Except that i use arm-elf tool chain.
I could debug externally. But when i try to debug in the CDT domain, the
project debugger option says: no debugger available.
I am using Insight arm-elf-gdb.exe(v5.2.1). Optionally i also tried with
PURE version gdb ,but dint help.
Also If i need to change the settings of tartget in gdb within cdt domain,
should i only use command version gdb?
I would very much appreciate, if someone could help.Im very much impressed
with eclipse environment and i am curious to use, if eclipse could support
it at this stage.
thanks in advance,
Kishore Kumar Sathyanandam
TLON GmbH
kishore@tlon.de
+49 (0)791 - 9305017
"goran pantar" <goran.pantar@xylon.hr> schrieb im Newsbeitrag
news:b03ct8$sbk$1@rogue.oti.com...
> interface?
> I use:
> Thank you
> goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58172 is a reply to message #58148] |
Wed, 15 January 2003 19:10 |
Originally posted by: mikhailk.qnx.com
Unfortunately you can not debug remote targets with this version of CDT. It
needs an extension to support the remote debugging.
Mikhail Khodjaiants
"Kishore Kumar Sathyanandam" <kishore@tlon.de> wrote in message
news:b03nee$56a$1@rogue.oti.com...
> Dear Mr.Goran,
impressed
> it at this stage.
> thanks in advance,
> TLON GmbH
> kishore@tlon.de
> > interface?
> > I use:
> > Thank you
> > goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58246 is a reply to message #58172] |
Thu, 16 January 2003 07:56 |
Originally posted by: johan.nosp.m.appeal.se
Have you thought about just calling gdb through ssh? Wouldn't that be a
way of solving the problem without much work? So instead of starting
gdb with "/usr/bin/gdb" or whatever you do currently, start it with "ssh
remotehost /usr/bin/gdb".
Cheers //Johan
> Mikhail Khodjaiants
>>Dear Mr.Goran,
> impressed
>>it at this stage.
>>thanks in advance,
>>TLON GmbH
>>kishore@tlon.de
>>>interface?
>>>I use:
>>>Thank you
>>>goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58271 is a reply to message #58172] |
Thu, 16 January 2003 09:38 |
Is remote debugging planed to be done in near future. If not, do you
thing it would be a problem to implement it. We are very interested in
using Eclipse and this is the only thing missing to have complete IDE.
Goran Pantar
> Mikhail Khodjaiants
> \"Kishore Kumar Sathyanandam\" <kishore@tlon.de> wrote in message
> > Dear Mr.Goran,
> impressed
> > it at this stage.
> > thanks in advance,
> > TLON GmbH
> > kishore@tlon.de
> > \"goran pantar\" <goran.pantar@xylon.hr> schrieb im Newsbeitrag
> > > I\'m using Eclipse IDE with CDT pluggin on Windows/Cygwin with mips-elf
> > > toolchail (mips-elf-gcc, mips-elf-gdb..). I can build \"Standard Make C
> > > projects\" and debug with Insight gdb as external tool.
> > > interface?
> > > I use:
> > > Thank you
> > > goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58390 is a reply to message #58271] |
Thu, 16 January 2003 15:49 |
Yes, we are planning to implement remote debugging in the near future but
the release date has not set yet. I don't think it would be a problem, we
just have to write a special launcher.
Mikhail Khodjaiants
"goran pantar" <goran.pantar@xylon.hr> wrote in message
news:b05uhp$ndu$1@rogue.oti.com...
It
> Goran Pantar
> > Mikhail Khodjaiants
> > > Dear Mr.Goran,
chain.
the
with
domain,
> > impressed
support
> > > it at this stage.
> > > thanks in advance,
> > > TLON GmbH
> > > kishore@tlon.de
mips-elf
Make C
debugging
> > > > interface?
> > > > I use:
> > > > Thank you
> > > > goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58521 is a reply to message #58390] |
Thu, 16 January 2003 17:35 |
> Mikhail Khodjaiants
Do you mean that the only thing that needs to be done to call gdb with
parameters for remote debugging?
Something like this :
set remote baud 115200
target remote com1
load
Or maybe use gdb.ini?
goran
> It
> > Goran Pantar
> > > Mikhail Khodjaiants
> > > > Dear Mr.Goran,
> chain.
> the
> with
> domain,
> > > impressed
> support
> > > > it at this stage.
> > > > thanks in advance,
> > > > TLON GmbH
> > > > kishore@tlon.de
> mips-elf
> Make C
> debugging
> > > > > interface?
> > > > > I use:
> > > > > Thank you
> > > > > goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58559 is a reply to message #58521] |
Thu, 16 January 2003 19:08 |
David Inglis Messages: 45 Registered: July 2009 |
Member |
Current the CDI framework does not support remote debugging (in a generic way)
so either you need to create your own launch delegate within the eclipse framework
(involving work that maybe not necessary in the future...) or you could try creating
a gdbinit file with the initial set of commands needed to start the remote debug session
and add the command line argument --command=<gdbinit> to gdb in the debugger tab (I have not
tried this myself so let us know if this works...)
Dave.
>>Mikhail Khodjaiants
> target remote com1
> load
> goran
>>It
>>>Goran Pantar
>>>>Mikhail Khodjaiants
>>>>>Dear Mr.Goran,
>>chain.
>>the
>>with
>>domain,
>>>>impressed
>>support
>>>>>it at this stage.
>>>>>thanks in advance,
>>>>>TLON GmbH
>>>>>kishore@tlon.de
>>mips-elf
>>Make C
>>debugging
>>>>>>interface?
>>>>>>I use:
>>>>>>Thank you
>>>>>>goran
Re: Debugging (Cygwin, MIPS toolchain) [message #58702 is a reply to message #58559] |
Fri, 17 January 2003 10:52 |
I have created simple gdb.ini file (located in Eclipse project directory)
which sets breakpoint to function "function1" (break function1).
When I start gdb from command prompt with: gdb -nw -x gdb.ini
my_program.exe ; it reads gdb.ini and sets breakpoint. (also works with:
gdb -nw -command gdb.ini my_program.exe )
But when I start debuginig from Eclipce and add to debuger tab "MI
Debugger: gcc -x gdb.ini". It doesn't work, no break point is set, it
probably didn't read -x option and gdb.ini.
Does that mean that I can't set extra options in tab "MI Debugger:" ? That
only name of debugger is read, and -x is ignored?
Or maybe I'm doing something wrong?
goran
way)
framework
creating
debug session
tab (I have not
> Dave.
> >>Mikhail Khodjaiants
> > target remote com1
> > load
> > goran
> >>It
> >>>Goran Pantar
> >>>>Mikhail Khodjaiants
> >>>>>Dear Mr.Goran,
> >>chain.
> >>the
> >>with
> >>domain,
> >>>>impressed
> >>support
> >>>>>it at this stage.
> >>>>>thanks in advance,
> >>>>>TLON GmbH
> >>>>>kishore@tlon.de
> >>mips-elf
> >>Make C
> >>debugging
> >>>>>>interface?
> >>>>>>I use:
> >>>>>>Thank you
> >>>>>>goran
Remote Debugging in Eclipse/CDT [message #58851 is a reply to message #58702] |
Mon, 20 January 2003 16:12 |
I can compile in Eclipse/CDT with mips-elf-gcc cross compiler (for MIPS
processor, Cygwin, Eclipse:C Make project).
But I can't debug.( I have mips-elf-gdb, ver. 5.2.1).
I know that remote debugging is not supported in Eclipse jet, but I'm
interested in possibility to use gdb.ini file to initialize remote
debugging.
But the problem is that I can't even select debugger in Eclipse. When I
select exe file (compiled in debug mode with mips-elf-gcc) I can no longer
see "Cygwin GDB Debugger" or "GDB debugger" options in "Debugger:" combo
box. Also there is nothing in "Debugger Options" selection and I get
error "No debugger available".
My exe file in C/C++ Projects window has "-[mipsle]" mark and is
represented with the "Running man icon". Also exe file can be opened in
Eclipse editor.
Does anybody know how to setup remote debugging in Eclipse?
Thank You
goran
Re: Remote Debugging in Eclipse/CDT [message #59049 is a reply to message #58949] |
Tue, 21 January 2003 10:57 |
Dear David
Thank you very much. I have added "mips" in plugin.xml and now it finally
works. I can select Cygwin GDB debugger and start debugging.
It still did'n accept command to read gdb.ini (gdb -x gdb.ini in "MI
Debugger:" box). But I can start remote debugging by entering commands in
Cygwin GDB Debugger console window : set remotebaud 115200; target remote
com1; load.
Now I will try with new mi plugin from CVS. I hope that new field will
accept option "-x gdb.ini" to read gdb.ini file.
Thank you.
Goran
> We made some changes/additions to the mi plugin to help with this, the
changes
> are in cvs so you will need to check it out and build it yourself to try
them out.
> Essentially there is a new field to specify the gdb command file to startup
> with.
> Your second problem can be fixed by adding the string "mips" to the cpu
> attribute for the debugger extension in the mi.core plugin.xml file,
currently
> only "native" is there.
> Hope this helps.
> Dave
> > debugging.
> > Eclipse editor.
> > Thank You
> > goran
Remote Debugging in Eclipse/CDT works! [message #59401 is a reply to message #59049] |
Wed, 22 January 2003 13:16 |
Thanks to David Inglis and other CDT developers who added new options to
CDT and made remote debuging possible.
Instructions to setup remote debugging (Mips platform):
You can download new nightly build (2003/01/20) of CDT at
http://download.eclipse.org/tools/cdt/downloads/cdt/eclipse- CDT-200301200336-win32_1.0.1.bin.dist.zip.
Unzip it in Eclipse folder.
Add string "mips" to cpu attribute in file
../eclipse/plugins/org.eclipse.cdt.debug.mi.core_1.0.1/plugi n.xml,
(like this
<debugger
platform="win32"
name="%CygwinGDBDebugger.name"
modes="run,core,attach"
cpu="native,mips" <- here was only native
class="org.eclipse.cdt.debug.mi.core.CygwinGDBDebugger"
id="org.eclipse.cdt.debug.mi.core.CygwinCDebugger">
</debugger>).
In Eclipse Window->preferences->C/C++->Debug->GDB MI/ you must set MI
debugget timeout to longer time period (100000ms) so it doesnt timeout
during download of code to remote target.
You must create gdb.ini file with these commands (sets up serial remote
debugging):
target remote com1 //or com2
load
Go to Eclipse menu Run->Debug..
In Main: setup file to debug
In Debugger: setup CygwinGDBDebugger, Browse to location of gdb(ver.
5.2.1), Browse to location of gdb.ini.
Press Debug
Goran Pantar
Current Time: Sat Apr 27 02:02:32 GMT 2024
Powered by FUDForum. Page generated in 0.03886 seconds
