Using Riena and JodaTime [message #574239] |
Thu, 04 September 2008 06:37 |
boss182 Messages: 10 Registered: July 2009 |
Hi Riena Team,
I encountered some problems when using Riena in combination with JodaTime
(i.e. org.joda.time.LocalDate). When sending over the wire from server to
client everything works fine. The other direction causes an
java.lang.InstantiationException, because hessian tries to instantiate the
abstract class Chronology instead of the real class ISOChronology. A part
of the stacktrace is following below.
Perhaps you can help me with some useful hints to solve or bypass this
problem. While googling the problem i found
http://maillist.caucho.com/pipermail/hessian-interest/2007-A pril/000054.html,
but this thread is not really a help.
Thanks in advance
Johannes
----Part of the Stacktrace----
Caused by: com.caucho.hessian.io.HessianFieldException:
org.joda.time.LocalDate.iChronology: org.joda.time.Chronology:null
at
com.caucho.hessian.io.JavaDeserializer.logDeserializeError(J avaDeserializer.java:586)
at
com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializ er.deserialize(JavaDeserializer.java:387)
at
com.caucho.hessian.io.JavaDeserializer.readMap(JavaDeseriali zer.java:199)
at
com.caucho.hessian.io.JavaDeserializer.readMap(JavaDeseriali zer.java:141)
at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1634)
at
com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializ er.deserialize(JavaDeserializer.java:383)
at
at
at
com.caucho.hessian.io.SerializerFactory.readMap(SerializerFa ctory.java:343)
at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1929)
at
com.caucho.hessian.io.CollectionDeserializer.readList(Collec tionDeserializer.java:78)
at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1666)
at
at
at
at
com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkel eton.java:149)
at
org.eclipse.riena.communication.publisher.hessian.HessianRie naDispatcherServlet.service(HessianRienaDispatcherServlet.ja va:153)
... 18 more
Caused by: com.caucho.hessian.io.IOExceptionWrapper:
at
com.caucho.hessian.io.JavaDeserializer.readMap(JavaDeseriali zer.java:147)
at
... 34 more
Caused by: java.lang.InstantiationException
at
sun.reflect.InstantiationExceptionConstructorAccessorImpl.ne wInstance(InstantiationExceptionConstructorAccessorImpl.java :30)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at
com.caucho.hessian.io.JavaDeserializer.instantiate(JavaDeser ializer.java:270)
at
com.caucho.hessian.io.JavaDeserializer.readMap(JavaDeseriali zer.java:139)
... 36 more
FUDForum. Page generated in 0.03133 seconds
