Problems when running with remote app server [message #573754] |
Fri, 15 May 2009 11:35 |
Mark D-B Messages: 188 Registered: July 2009 |
When I run both app server and client on one machine, the database
connection is fine.
However, I now want to run OSEE for real in a small test project. To this
end, PostgreSQL and the app server were installed on a Windows 2008 Server
box.
When I ran the database initialisation from the client, the tables all
appeared to be created correctly but then an error appeared. I therefore
ran the database init locally on the 2008 Server box to see if the OS or
something in the way I had set up PostgreSQL on that machine was the
problem. The database initialised correctly and I could then run the
oseeLocal client and all seems to be well.
However, if I go back to running the client from another machine, it
connects to the app server but then comes up with an error 'Artifact with
name space "" and name "Root Artifact" is not available.'. This is
followed by 'The key "common" does not refer to any branch".
What am I doing wrong please?
FUDForum. Page generated in 0.03074 seconds
