Home » Eclipse Projects » Runtimes » PDE API Tools
PDE API Tools [message #572298] Thu, 25 June 2009 12:21 Go to next message
Hi Folks,
Apologies for the cross post. I tried posting to eclipse.pde but I was not
authorized to do so.
I'm trialling the pde api tools for use within our organization and I'm
seeing some behavior that I dont understand. Hopefully someone will be able
to explain the rational.
I have a reference plugin v1.0.0 (my baseline)
I have a separate identical copy of that plugin imported into my workspace
(the working copy).
I create a baseline using the reference copy.
I enable the working copy for api analysis.
And I immediately get an error stating:-
"The minor version should be incremented in version 1.0.0.qualifier, since
new APIs have been added since version 1.0.0.qualifier."
But I havent yet changed the plugin at all.
I would not expect this sort of error to appear until I make the first
change. Is this an incorrect expectation? If so, why?
Mnay thanks
_Paul
Re: PDE API Tools [message #654467 is a reply to message #572298] Tue, 15 February 2011 17:18 Go to previous message
Paul,
Being that this thread is a bit dated, I hope you will still receive this followup.
I too have come into this exact same situation. Would you mind following up with what / how / if you were able to bypass this issue?
I'd really like to take advantage of the the PDE API baseline tools.
Michael
Previous Topic:equinox experience reports
Next Topic:Need Latest Jetty 7 SAR
Current Time: Fri Aug 29 03:14:48 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
