RSEG1066U (RSE 2.0.0.1) [message #569142] |
Tue, 24 July 2007 13:09 |
Alphonse Van Assche Messages: 6 Registered: July 2009 |
Hello all,
Any idea in witch case this error is throw? This happen when I try to
connect to a Linux server using Dstore, this exception is throw with and
without a Dstore daemon started, so it's not a server side problem.
That have already worked here but I think that I don't have try it with
the last update.
Alphonse
The stack trace:
at
org.eclipse.rse.connectorservice.dstore.DStoreConnectorServi ce.internalConnect(DStoreConnectorService.java:761)
at
org.eclipse.rse.core.subsystems.AbstractConnectorService.con nect(AbstractConnectorService.java:412)
at
org.eclipse.rse.ui.operations.SystemFetchOperation.execute(S ystemFetchOperation.java:243)
at
org.eclipse.rse.ui.operations.SystemFetchOperation.run(Syste mFetchOperation.java:128)
at
org.eclipse.rse.ui.view.AbstractSystemViewAdapter.fetchDefer redChildren(AbstractSystemViewAdapter.java:1970)
at
org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:196)
FUDForum. Page generated in 0.03145 seconds
