Home » Modeling » Graphiti » Properties and Listeners
Properties and Listeners [message #565867] Tue, 31 August 2010 14:32 Go to next message
Hi guys,
May I ask your help to understand if I am properly implementing the listeners for two fields in the property section?
My questions are:
Q1: is it correct to have a different listener for each field/attribute?
Q2: if I have another businessObject, namely "IntentionSpec", which:
- is a specialization of the businessObject "Intention"
- has the two attributes inherited from "Intention" plus another attribute called "newAttribute"
and I want that in the property section when:
i) an "Intention" diagram element is selected --> two attributes are visualized in the panel and if I edit them the "Intention" business object is changed (similar to the actual code)
ii) an "IntentsionSpec" is selected ---> three attributes are visualized in the panel and if I edit them the "IntentionSpec" business object is changed.
Do you have some suggestions how to do that?
For example, should I put everything it the same:
public void createControls(Composite parent, TabbedPropertySheetPage tabbedPropertySheetPage)
and add some lines such as:
Object bo= Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
if (bo == Intention) then
<actual code>
else
<code to visualize the previous two fields + the newAttribute, and in this case I use the same listeners plus a new one>
Is this correct?
Thank you very much for any help or suggestions :)
public class IntentionSection extends GFPropertySection implements ITabbedPropertyConstants {
private Text nameText;
private Text descriptionText;
private ModifyListener listenerIntentionName = new ModifyListener(){
public void modifyText (ModifyEvent arg0){
PictogramElement pe = getSelectedPictogramElement();
Intention bimElement = (Intention) Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
bimElement.setName(nameText.getText());
bimElement.setDescription(descriptionText.getText());
System.out.print("\Name setted: "+bimElement.getName());
private ModifyListener listenerIntentionDescription = new ModifyListener(){
System.out.print("\nDescription setted: "+bimElement.getDescription());
public void createControls(Composite parent, TabbedPropertySheetPage tabbedPropertySheetPage) {
super.createControls(parent, tabbedPropertySheetPage);
TabbedPropertySheetWidgetFactory factory = getWidgetFactory();
Composite composite = factory.createFlatFormComposite(parent);
FormData data;
// nameText
nameText = factory.createText(composite, ""); //$NON-NLS-1$
data = new FormData();
//data.left = new FormAttachment(0, STANDARD_LABEL_WIDTH);
data.left = new FormAttachment(0, 100);
data.right = new FormAttachment(100, 0);
data.top = new FormAttachment(0, VSPACE);
nameText.setLayoutData(data);
//Daniele: I am adding the listener here
nameText.addModifyListener(listenerIntentionName);
CLabel valueLabel = factory.createCLabel(composite, "Name:"); //$NON-NLS-1$
data.left = new FormAttachment(0, 0);
data.right = new FormAttachment(nameText, -HSPACE);
data.top = new FormAttachment(nameText, 0, SWT.CENTER);
valueLabel.setLayoutData(data);
// descriptionText
descriptionText = factory.createText(composite, "", SWT.MULTI | SWT.BORDER | SWT.V_SCROLL); //$NON-NLS-1$
//TODO: try to modify the layout for property
data.top = new FormAttachment(nameText, VSPACE);
descriptionText.setLayoutData(data);
descriptionText.addModifyListener(listenerIntentionDescripti on);
CLabel valueLabelDescription = factory.createCLabel(composite, "Description:"); //$NON-NLS-1$
//-HSPACE
data.right = new FormAttachment(descriptionText, -HSPACE);
data.top = new FormAttachment(descriptionText, 0, SWT.CENTER);
valueLabelDescription.setLayoutData(data);
public void refresh() {
if (pe != null) {
Object bo = Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
// the filter assured, that it is a Intention
if (bo == null)
return;
// Remove listener
nameText.removeModifyListener(listenerIntentionName);
// Modify values of the properties
String name = ((Intention) bo).getName();
System.out.print("\nSet Name property: "+name);
nameText.setText(name == null ? "" : name); //$NON-NLS-1$
// (RE)Add listener
// Remove listener
descriptionText.removeModifyListener(listenerIntentionDescri ption);
String description = ((Intention) bo).getDescription();
System.out.print("\nSet Description property: "+description);
descriptionText.setText(description == null ? "" : description); //$NON-NLS-1$
// (RE)Add listener
descriptionText.addModifyListener(listenerIntentionName);
Re: Properties and Listeners [message #567773 is a reply to message #565867] Thu, 02 September 2010 15:44 Go to previous messageGo to next message
Hi guys,
with the above code I have the following error :(
Have someone some suggestions?
Please :)
Thank you very much!!!
Daniele
eclipse.buildId=I20100608-0911
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_CA
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data /home/daniele/workspace/../runtime-EclipseApplication -dev file:/home/daniele/workspace/.metadata/.plugins/org.eclipse. pde.core/Eclipse Application/dev.properties -os linux -ws gtk -arch x86
Error
Thu Sep 02 15:38:22 EDT 2010
Unhandled event loop exception
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:284)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:240)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:280)
at BIM.impl.ThingImpl.setName(ThingImpl.java:210)
at org.eclipse.graphiti.bim.property.IntentionSection$1.modifyT ext(IntentionSection.java:58)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:173)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3171)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: Properties and Listeners [message #567918 is a reply to message #565867] Mon, 06 September 2010 08:53 Go to previous messageGo to next message
you can not modify an EObject directly if it is controlled
by an EditingDomain.
See EMF Model Transaction Developer Guide
in the eclipse help for an explanation of the concepts.
In general, you can access the EditingDomain of an EObject
via
org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(...)
Also you can use the method
public void execute(IFeature feature, IContext context)
of the GFPropertySection to have your model modification executed
inside a feature. Then the framework takes care of using the editingdomain of the diagram editor.
Best, Tim
Re: Properties and Listeners [message #567991 is a reply to message #567918] Tue, 07 September 2010 18:07 Go to previous messageGo to next message
Thank you very much Tim!!!
I much appreciated your help. Actually, I am trying to understand how this work looking at the guide you suggested.
Daniele
p.s.
I was wondering if you have also an example within the graphiti tutorial which I can use to better undestand the editingDomain or the execute method.
Re: Properties and Listeners [message #568015 is a reply to message #567991] Tue, 07 September 2010 19:47 Go to previous messageGo to next message
Hi Tim,
what about this solution (w.r.t. the above code)?
it seems work but I am not sure if there is a better way.
Thanks in advance for any suggstions
Daniele
// set the new name for the Intention
final Intention bimElement = (Intention) Graphiti.getLinkService().getBusinessObjectForLinkedPictogra mElement(pe);
TransactionalEditingDomain editingDomain = TransactionUtil.getEditingDomain(bimElement);
editingDomain.getCommandStack().execute(new RecordingCommand(editingDomain) {
protected void doExecute() {
Re: Properties and Listeners [message #568065 is a reply to message #565867] Wed, 08 September 2010 11:19 Go to previous messageGo to next message
Looks good for me...
Best, Tim
Re: Properties and Listeners [message #568264 is a reply to message #565867] Tue, 14 September 2010 11:18 Go to previous message
probably you missed the last fix.
I checked in the fix to make it work on 6th of september.
If you update graphiti it should work
out of the box.
Best, Tim
Previous Topic:Graphiti 0.7.0 RC1 available
Next Topic:Font Size In Pixels
Current Time: Tue Oct 28 18:37:47 EDT 2025
Powered by FUDForum. Page generated in 0.04162 seconds
