| Firefox extension not working and account problem [message #562905] |
Wed, 14 January 2009 11:33 |
I try Azigo software and want to switch back to Higgins open source
solution. I installed Higgins selector but still have some message who
refer to Azigo. I removed all Azigo software from my computer, only use
Higgins connecter, Higgins selector selector and Higgins Identity Selector.
I use firefox 3.0.5, I have Higgins Connector Installed option set to
Selector Selector with default configuration. But when I try to login with
info card, firefox asking for application/x-informationcard.
My second problem is to create new account. I use the interface in
Accounts configuration. I have the Account creation failed. Please try
again error. Sniffing HTTPS request I have this:
Send message:
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SOAP-ENV:Body
SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<intf:addUserProfileFromHBX
xmlns:intf="urn:RPPSService/wsdlRPPSService">
<userId xsi:type="xsd:string">test_test</userId>
<password xsi:type="xsd:string">test</password>
</intf:addUserProfileFromHBX>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
RRPS message:
<?xml version="1.0" encoding="utf-8"?><soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException </faultcode><faultstring>java.rmi.RemoteException:
org.eclipse.higgins.icard.userprofile.UserProfileException:
org.eclipse.higgins.idas.api.IdASException:
org.eclipse.higgins.idas.registry.discovery.DiscoveryExcepti on: Cannot
resolve XRI.; nested exception is:
org.eclipse.higgins.rpps.core.RppsException:
resolve XRI.</faultstring><detail><ns1:hostname
xmlns:ns1="http://xml.apache.org/axis/">higgins.eclipse.org</ns1:hostname></detail></soapenv:Fault ></soapenv:Body></soapenv:Envelope>
I have now idea where the problem come from, maybe some trouble with my
configuration.
Tanks all.
FUDForum. Page generated in 0.03607 seconds
