Home » Modeling » OCL » Re: [OCL] AstNode - startPosition is a transient attribute
| Re: [OCL] AstNode - startPosition is a transient attribute [message #56574] |
Fri, 23 May 2008 09:27  |
Originally posted by: cdamus.zeligsoft.com
--=-JPqi7hPmMlHglIwWVn+n
Content-Type: text/plain
Hi, Jonathan,
As Eike indicated, the OCL component has its own newsgroup (which I have
copied in the reply).
This attribute is transient because it supports the parsing process, but
is not semantically relevant to OCL expressions. Traceability to the
source text doesn't belong in the abstract syntax model, but rather in
the concrete-syntax model. This attribute actually pre-dates the CST
implementation and is retained only for API compatibility reasons. A
better solution would use a mapping of AST nodes to the CST nodes from
which they were parsed.
Christian
On Fri, 2008-05-23 at 14:45 +0200, Jonathan MUSSET wrote:
> Hi everybody
> Do you know why the "startPosition" attribute (in the EClass ASTNode) is
> transient? I would like to know the position of each OCL expression in
> my AST model. Is it possible?
> Thank you
> Jonathan
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.1">
</HEAD>
<BODY>
Hi, Jonathan,<BR>
<BR>
As Eike indicated, the OCL component has its own newsgroup (which I have copied in the reply).<BR>
<BR>
This attribute is transient because it supports the parsing process, but is not semantically relevant to OCL expressions. Traceability to the source text doesn't belong in the abstract syntax model, but rather in the concrete-syntax model. This attribute actually pre-dates the CST implementation and is retained only for API compatibility reasons. A better solution would use a mapping of AST nodes to the CST nodes from which they were parsed.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hi everybody</FONT>
<FONT COLOR="#000000">Do you know why the "startPosition" attribute (in the EClass ASTNode) is </FONT>
<FONT COLOR="#000000">transient? I would like to know the position of each OCL expression in </FONT>
<FONT COLOR="#000000">my AST model. Is it possible?</FONT>
<FONT COLOR="#000000">Thank you</FONT>
<FONT COLOR="#000000">Jonathan</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-JPqi7hPmMlHglIwWVn+n--
| Re: [OCL] AstNode - startPosition is a transient attribute [message #56599 is a reply to message #56574] |
Fri, 23 May 2008 10:48   |
Hi Christian,
I agree with your choice.
Where can I find this information?
I'm using an an helper -> OCLHelper<EClassifier, EOperation,
EStructuralFeature, Constraint>
The method "createQuery" returns an OCL expression
Is there a way to find the CST information? perhaps "helper.getOCL()"?
Jonathan
Christian W. Damus a écrit :
> Hi, Jonathan,
> Cheers,
> Christian
>> Hi everybody
>> Thank you
>> Jonathan
| Re: [OCL] AstNode - startPosition is a transient attribute [message #56626 is a reply to message #56599] |
Fri, 23 May 2008 11:30   |
I found the following map :
helper.getOCL().getEnvironment()).getASTNodeToCSTNodeMap()
Is it the only way?
Jonathan MUSSET a écrit :
> Hi Christian,
> Cheers,
> Jonathan
>> Hi, Jonathan,
>> Cheers,
>> Christian
>>> Hi everybody
>>> is transient? I would like to know the position of each OCL
>>> expression in my AST model. Is it possible?
>>> Thank you
>>> Jonathan
| Re: [OCL] AstNode - startPosition is a transient attribute [message #56788 is a reply to message #56626] |
Mon, 26 May 2008 09:22  |
Hi, Jonathan,
Yes, that is the way to access the AST-to-CST mapping.
Christian
> Is it the only way?
> > Hi Christian,
> > Cheers,
> > Jonathan
> >> Hi, Jonathan,
> >> Cheers,
> >> Christian
> >>> Hi everybody
> >>> Thank you
> >>> Jonathan
Current Time: Wed Oct 29 07:20:56 EDT 2025
Powered by FUDForum. Page generated in 0.04890 seconds
