Re: Unable to debug OSGi modules on Virgo in Eclipse [message #560229 is a reply to message #560224] |
Tue, 21 September 2010 15:40 |
Glyn Normington Messages: 1222 Registered: July 2009 |
Did you specify the -debug switch to the Virgo startup script? That should listen for the debugger to attach. If you want to prevent Virgo from starting until you have attached the debugger (and, for example, set a breakpoint), use both the -debug and -suspend switches.
Details are in the user guide.
(I am assuming you are happy to run Virgo externally to Eclipse and attach the Eclipse debugger to the Virgo process. If you are trying to run Virgo in debug mode using the Virgo tooling, e.g. in STS, then that's a different story.)
[Updated on: Tue, 21 September 2010 15:42] Report message to a moderator
FUDForum. Page generated in 0.04254 seconds
