IWAB0014E On Web Client Code Generation [message #559808] |
Sat, 18 September 2010 23:53 |
Bud Messages: 1 Registered: September 2010 |
I get the following error when attempting to genrate client code.
IWAB0014E Unexpected exception occured.
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.Stub2Be anCommand.execute(Stub2BeanCommand.java:121)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientC odeGenOperation$ClientWSModifyOperation.execute(ClientCodeGe nOperation.java:110)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientC odeGenOperation.execute(ClientCodeGenOperation.java:61)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:413)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:353)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:251)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:250)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:220)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:94)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:250)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:332)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:130)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
When I validate the WSDL I get a WARNING:
WS-I: (BP2803) The wsdl:import element's "namespace" attribute value is a relative URI.
This same WSDL successfully generates client code in other IDEs.
FUDForum. Page generated in 0.51975 seconds
