Re: Birt 2.5.2 - JNDI not used after application reload under tomcat--> Missing properties in Con [message #558915 is a reply to message #558879] |
Tue, 14 September 2010 20:18 |
Are you doing a task.close after running the report?
Jason
On 9/14/2010 1:29 PM, Lionel wrote:
> I have an issue when using a jndi datasource.
> I start the Platform and report engine when the application starts (using a
> ContextListener)
> I destroy the engine and the Platform when the application stopts (using the
> same ContextListener)
> When I start tomcat, everything works fine, the jndi datasource is used and
> my report is well displayed.
> If I stop/start the application (either using tomcat manager or by saving a
> java file), the jndi datasource is not used anymore and BIRT tries to open a
> connection, which crashes:
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: Missing properties in
> Connection.open(Properties)
> Stopping and restarting tomcat solves the problem. But I can't restart the
> server for each deployment, this consumes too much time.
> What did I do wrong ?
> Hiere is my listener:
> public void contextDestroyed(ServletContextEvent event) {
> BirtEngine.destroyBirtEngine();
> public void contextInitialized(ServletContextEvent event) {
> BirtEngine.getBirtEngine();
> BirtEngine.java:
> public static synchronized IReportEngine getBirtEngine() {
> if (birtEngine == null) {
> EngineConfig config = new EngineConfig();
> config.getAppContext().put(EngineConstants.APPCONTEXT_CLASSL OADER_KEY,
> BirtEngine.class.getClassLoader());
> try{Platform.startup( config );}
> catch ( BirtException e ){e.printStackTrace( );}
> IReportEngineFactory factory = (IReportEngineFactory)
> Platform.createFactoryObject(
> IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
> birtEngine = factory.createReportEngine( config );
> return birtEngine;
> public static synchronized void destroyBirtEngine() {
> if (birtEngine == null) {return; }
> birtEngine.destroy();
> Platform.shutdown();
> birtEngine = null;
> Thanks for your help.
Re: Birt 2.5.2 - JNDI not used after application reload under tomcat--> Missing properties in Con [message #559090 is a reply to message #558986] |
Wed, 15 September 2010 15:10 |
Lionel,
Do you only get this error on JNDI datasources? Have you tried the
default viewer to see if you get the same issue?
Jason
On 9/15/2010 4:45 AM, Lionel wrote:
> Lionel wrote:
>>> Jason
>> Yes.
>> task.run(); is immediatly followed by
>> task.close();
> The following scenario works:
> - Start tomcat
> - use application
> - reload application
> - launch report --> ok
> The following scenario doesn't work:
> - Start tomcat
> - use application
> - launch report --> crash
> Here is how I create and run the task:
> ServletContext sc = getContext().getServletContext();
> IReportEngine birtReportEngine = BirtEngine.getBirtEngine();
> IReportRunnable design = birtReportEngine.openReportDesign(getReportUrl());
> birtReportEngine.getConfig().setResourcePath(sc.getRealPath( "/") +
> "WEB-INF/classes/");
> task = birtReportEngine.createRunAndRenderTask(design);
> task.setParameterValue("param", "value");
> task.validateParameters();
> reportOutput = new ByteArrayOutputStream();
> HTMLRenderOption options = new HTMLRenderOption();
> options.setOutputFormat(IHTMLRenderOption.OUTPUT_FORMAT_HTML );
> options.setOutputStream(reportOutput);
> options.setEmbeddable(true);
> task.setRenderOption(options);
> task.run();
> task.close();
Re: Birt 2.5.2 - JNDI not used after application reload under tomcat--> Missing properties in Con [message #559167 is a reply to message #559129] |
Wed, 15 September 2010 19:48 |
Were you able to try the viewer in the runtime download?
On 9/15/2010 12:56 PM, Lionel wrote:
> BIRRT Logs, without JNDI URL, at first start when everything works fine (no
> change compared to previous log, only an application reload):
> FIN: Finished preparing query.
> 15 sept. 2010 18:52:53
> org.eclipse.birt.data.engine.odaconsumer.ConnectionManager
> addProfileProviderService( Map )
> FIN: Added default property service:
> org.eclipse.datatools.connectivity.oda.profile.connectionPro pertyService
> 15 sept. 2010 18:52:53 org.eclipse.birt.report.data.oda.jdbc.OdaJdbcDriver
> getConnection
> FIN: JDBCConnectionFactory.getConnection( )
> connectionClassName=org.eclipse.birt.report.data.oda.jdbc
> 15 sept. 2010 18:52:53 org.eclipse.birt.report.data.oda.jdbc.Connection open
> FIN: Connection.open(Properties). connProperties =
> OdaPropertyConfigId=org.eclipse.birt.report.data.oda.jdbc_My Application;odaURL=jdbc:postgresql://serveur2003:5432/MyApplication ;odaDriverClass=org.postgresql.Driver;odaPassword=***;odaUse r=MyApplication;contentBidiFormatStr=ILYNN;metadataBidiForma tStr=ILYNN;
> close
> FIN: Connection closed.
> JDBCDriverManager
> FIN: JDBCDriverManager starts up
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager getConnection
> FIN: Request JDBC Connection: driverClass=org.postgresql.Driver;
> url=jdbc:postgresql://serveur2003:5432/MyApplication; jndi name url=null
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadDriverExtensions
> INFO: Found JDBC driverinfo extension:
> driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
> driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver ,
> connectionFactory=org.eclipse.birt.report.data.oda.sampledb. SampleDBJDBCConnectionFactory
> loadAndRegisterDriver
> INFO: Loading JDBC driver class: org.postgresql.Driver
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager findDriver
> INFO: Driver class not in class path: org.postgresql.Driver. Trying to
> locate driver in drivers directory
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Driv erClassLoader
> addNewURL
> INFO: JDBCDriverManager: found JAR file
> drivers/postgresql-8.2-507.jdbc4.jar.
> URL= bundleentry://40.fwk13586438/drivers/postgresql-8.2-507.jdbc 4.jar
> createStatement
> FIN:
> Connection.createStatement(org.eclipse.birt.report.data.oda. jdbc.JdbcSelectDataSet)
Re: Birt 2.5.2 - JNDI not used after application reload under tomcat--> Missing properties in Con [message #559189 is a reply to message #559167] |
Wed, 15 September 2010 21:32 |
I tried this with the viewer and tomcat/mysql connection pooling and did
a reload and did not see the issue. I assume you setup connection
pooling like:
http://wiki.eclipse.org/BIRT/FAQ/Deployment#Q:_How_do_I_setu p_BIRT_to_use_Tomcat_Connection_Pooling
Jason
>> fine (no
>> getConnection
>> close
>> JDBCDriverManager
>> addNewURL
>> createStatement
>> FIN:
Re: Birt 2.5.2 - JNDI not used after application reload under tomcat--> Missing properties in Con [message #559486 is a reply to message #559474] |
Thu, 16 September 2010 18:38 |
Can you open a bug for this? I can not reproduce the issue. I have
tried with both the viewer and my own servlet. I am posting my code in
this thread. I shutdown the engine on destruction of the servlet.
2 Classes BirtEngine and WebReport
//BirtEngine
import java.io.IOException;
import java.io.InputStream;
import java.util.Properties;
import java.util.logging.Level;
import javax.servlet.ServletContext;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformServletContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
public class BirtEngine {
private static IReportEngine birtEngine = null;
private static Properties configProps = new Properties();
private final static String configFile = "BirtConfig.properties";
public static synchronized void initBirtConfig() {
loadEngineProps();
public static synchronized IReportEngine getBirtEngine(ServletContext sc) {
if( configProps != null){
String logLevel = configProps.getProperty("logLevel");
Level level = Level.OFF;
if ("SEVERE".equalsIgnoreCase(logLevel))
level = Level.SEVERE;
} else if ("WARNING".equalsIgnoreCase(logLevel))
level = Level.WARNING;
} else if ("INFO".equalsIgnoreCase(logLevel))
level = Level.INFO;
} else if ("CONFIG".equalsIgnoreCase(logLevel))
level = Level.CONFIG;
} else if ("FINE".equalsIgnoreCase(logLevel))
level = Level.FINE;
} else if ("FINER".equalsIgnoreCase(logLevel))
level = Level.FINER;
} else if ("FINEST".equalsIgnoreCase(logLevel))
level = Level.FINEST;
} else if ("OFF".equalsIgnoreCase(logLevel))
level = Level.OFF;
config.setLogConfig(configProps.getProperty("logDirectory"), level);
config.setEngineHome("");
IPlatformContext context = new PlatformServletContext( sc );
config.setPlatformContext( context );
//Create the report engine
//birtEngine = new ReportEngine( config );
//ReportEngine engine = new ReportEngine( null );
try
IReportEngineFactory factory = (IReportEngineFactory) Platform
return birtEngine;
return;
birtEngine = null;
public Object clone() throws CloneNotSupportedException {
throw new CloneNotSupportedException();
private static void loadEngineProps() {
try {
//Config File must be in classpath
ClassLoader cl = Thread.currentThread ().getContextClassLoader();
InputStream in = null;
in = cl.getResourceAsStream (configFile);
configProps.load(in);
in.close();
} catch (IOException e) {
e.printStackTrace();
//WebReport
import java.io.PrintWriter;
import java.util.logging.Logger;
import javax.servlet.ServletConfig;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
public class WebReport extends HttpServlet {
private static final long serialVersionUID = 1L;
* Constructor of the object.
private IReportEngine birtReportEngine = null;
protected static Logger logger = Logger.getLogger( "org.eclipse.birt" );
public WebReport() {
super();
* Destruction of the servlet. <br>
public void destroy() {
super.destroy();
* The doGet method of the servlet. <br>
public void doGet(HttpServletRequest req, HttpServletResponse resp)
throws ServletException, IOException {
//get report name and launch the engine
resp.setContentType("text/html");
//resp.setContentType( "application/pdf" );
//resp.setHeader ("Content-Disposition","inline; filename=test.pdf");
String reportName = req.getParameter("ReportName");
ServletContext sc = req.getSession().getServletContext();
this.birtReportEngine = BirtEngine.getBirtEngine(sc);
IReportRunnable design;
try
//Open report design
sc.getRealPath("/Reports")+"/"+reportName );
//create task to run and render report
IRunAndRenderTask task = birtReportEngine.createRunAndRenderTask(
design );
task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY,
WebReport.class.getClassLoader());
task.getAppContext().put("BIRT_VIEWER_HTTPSERVLET_REQUEST", req );
//set output options
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML) ;
options.setOutputStream(resp.getOutputStream());
options.setImageHandler(new HTMLServerImageHandler());
options.setBaseImageURL(req.getContextPath()+"/images");
options.setImageDirectory(sc.getRealPath("/images"));
PDFRenderOption options = new PDFRenderOption();
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
resp.setHeader( "Content-Disposition", "inline;
filename=\"test.pdf\"" );
//run report
task.run();
task.close();
}catch (Exception e){
throw new ServletException( e );
* The doPost method of the servlet. <br>
public void doPost(HttpServletRequest request, HttpServletResponse
response)
response.setContentType("text/html");
PrintWriter out = response.getWriter();
out.println("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01
Transitional//EN\">");
out.println("<HTML>");
out.println(" <HEAD><TITLE>A Servlet</TITLE></HEAD>");
out.println(" <BODY>");
out.println(" Post Not Supported");
out.println(" </BODY>");
out.println("</HTML>");
out.flush();
out.close();
* Initialization of the servlet. <br>
* @throws ServletException if an error occure
public void init(ServletConfig sc) throws ServletException {
BirtEngine.initBirtConfig();
this.birtReportEngine = BirtEngine.getBirtEngine(sc.getServletContext());
logDirectory=c:/temp
logLevel=FINEST
Jason
>> did a reload and did not see the issue. I assume you setup connection
>> pooling like:
> Yes.
> My JNDI datasource has been configured long time before including BIRT in my
> JPA project
> I've never had any issue. Even when BIRT crashes, my application can still
> access my datasource without any trouble.
> It really looks like I did something wrong when I open/run/close my report
> that make BIRT "think" that there is no JNDI datasource.
> The logs clearly show that after a reload the connections properties are
> lost:
> -- Start tomcat:
> 16 sept. 2010 19:40:48 org.eclipse.birt.report.data.oda.jdbc.Connection open
> odaJndiName=java:comp/env/jdbc/MyApplication;OdaPropertyConf igId=org.eclipse.birt.report.data.oda.jdbc_MyApplication;oda URL=jdbc:postgresql://serveur2003:5432/MyApplication ;odaDriverClass=org.postgresql.Driver;odaPassword=***;odaUse r=MyApplication;contentBidiFormatStr=ILYNN;metadataBidiForma tStr=ILYNN;
> --reload application and refresh page:
> 16 sept. 2010 19:44:02 org.eclipse.birt.report.data.oda.jdbc.Connection open
> OdaPropertyConfigId=org.eclipse.birt.report.data.oda.jdbc_My Application;contentBidiFormatStr=ILYNN;metadataBidiFormatStr =ILYNN;
> What could I have done that would have done that ?
FUDForum. Page generated in 0.04544 seconds
