Home » Archived » SeMantic Information Logistics Architecture (SMILA) » Deployment of own plugins to SMILA(Creating config.ini with own added plugins to config.ini)
Deployment of own plugins to SMILA [message #558700] Tue, 14 September 2010 01:57 Go to next message
we have several plugins that we want to deploy with SMILA. All works fine except for generating the config.ini file in the configuration folder. In the config file there is specify in which start level the plugins to be start. This is necessary for our plugins.
We adapt the SMILA product plugin to add our plugins to the config file while deployment. But this doesn't work Sad.
How can we add our plugins to the config file automatically?
Re: Deployment of own plugins to SMILA [message #558714 is a reply to message #558700] Tue, 14 September 2010 03:49 Go to previous message
Originally posted by: juergen.schumacher.attensity.com
Am 14.09.2010, 07:57 Uhr, schrieb SMILANewBee <nils.thieme@unister.de>:
> Hello,
> while deployment. But this doesn't work :(.
Sorry, I don't know this myself. The config.ini in the SMILA distribution
is currently not generated by the product, but copied from
SMILA.application/configuration, where it is maintained manually.
Maybe this also overwrites your generated config.ini?
However, I agree that it makes sense that this file is generated by the
build.
If you find a soluton and can provide instructions how to set up the
product build
to generate the correct config.ini immediately, I can probably apply the
changes to
the SMILA trunk. But I don't have much time currently for experimenting
with the build. (;
Thanks and Regards,
Juergen.
Previous Topic:Deployment of own plugins to SMILA
Next Topic:BPEL Designer extensionActivity bug
Current Time: Fri Nov 07 19:19:02 EST 2025
Powered by FUDForum. Page generated in 0.05104 seconds
