Re: How checkout and build Subversive trunk? [message #558894 is a reply to message #558856] |
Tue, 14 September 2010 19:00 |
Daniel N Messages: 6 Registered: September 2010 |
Alexander Gurov wrote on Tue, 14 September 2010 11:44 | Hi,
To build Subversive just perform following steps:
1) Checkout everything in trunk as projects (because trunk itself is not a project)
2) Build update sites.
Beside this in order to obtain full Subversive build (including connectors) you should also checkout connectors from the Polarion.org repository: http://svn.polarion.org/repos/community/Subversive
I created a project with File->New Project->Plugin Development->Update Site project.
What do I do from there? I tried adding the projects to site.xml with Add feature... but couldn't find them in the dialog (and editing the site.xml file directly appears to be a bit of a hazzle). You're saying I should create one update site that includes all the projects right?
How should the connectors fit into the project? Can they just be randomly added to the project setup? And how access them? The repos asks for authentication and I don't have any username there.
[Updated on: Tue, 14 September 2010 19:41] Report message to a moderator
Re: How checkout and build Subversive trunk? [message #559282 is a reply to message #559159] |
Thu, 16 September 2010 09:23 |
Alexander Gurov Messages: 148 Registered: July 2009 |
Hello Daniel,
About PrepareInstallProfileJob3_6.java, I was really surprised myself, but there are some incompatible changes between Eclipse 3.5 and Eclipse 3.6 versions. So, the trick is to build plug-in with Eclipse 3.6 instance and then add into the build *.class files for the 3.5 version which is committed to the source control nearby their respective *.java sources.
Now about the Mylyn plug-in. Main Subversive distribution includes support for Mylyn because it is very popular and useful to many people project. So, building Subversive just requires Mylyn as dependency.
Regarding you unable to checkout SVN connectors, I will check the reason, but earlier SVN connectors repository were publicly accessible with "read-only" permissions, as far as I remember.
Regarding running head slice of the Subversive sources for test purposes - you could just run it from the Eclipse IDE without building. Just use "Run As->Eclipse Application" action over the UI project, for example.
Re: How checkout and build Subversive trunk? [message #559986 is a reply to message #559282] |
Mon, 20 September 2010 15:55 |
Alexander Gurov wrote on Thu, 16 September 2010 05:23 | Hello Daniel,
I'm using Eclipse 3.5. Are you saying that I need 3.6 to properly build all parts?
Any news on this one? I still can't do an anonymous checkout. When I click on Run->Run as..->Eclipse application, a new Eclipse instance is started and a popup appears that asks me for what connector to use. It gives me multiple choices but I can't install any of them. I'm assuming that I need to have the connectors in the source tree? Maybe I can put the binaries available for on polarion.org in the project?
FUDForum. Page generated in 0.05226 seconds
