Home » Modeling » Epsilon » Error when adding a model to a newly created launch configuration for an evl file
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558568 is a reply to message #558520] |
Mon, 13 September 2010 13:53 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
On 13.09.10 12.51, Dimitris Kolovos wrote:
> Fixed in the interim site.
It worked, thanks!
My students are working on their first assignment, where they must use
Emfatic and HUTN for creating a model and sample data, and eol/evl for
constraints. They're very grateful for the quick response :-)
A quick comment on creating launch configurations for evl files: I would
guess the usual case is validating a single model. Hence, a slightly
different design, where the source and model are chosen on the main tab,
and the other tab used for adding additional models, would make sense.
What do you think?
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #558591 is a reply to message #558568] |
Mon, 13 September 2010 15:37 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Hallvard,
Is this just a UI issue (given that EVL already supports access to
multiple models)?
Dimitris
> It worked, thanks!
> What do you think?
> Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593793 is a reply to message #558520] |
It worked, thanks!
What do you think?
Hallvard
Re: Error when adding a model to a newly created launch configuration for an evl file [message #593835 is a reply to message #558568] |
Hi Hallvard,
multiple models)?
Dimitris
> It worked, thanks!
> What do you think?
> Hallvard
Current Time: Sat Apr 27 03:52:13 GMT 2024
Powered by FUDForum. Page generated in 0.02698 seconds
