Home » Archived » Buckminster » Think about multiple p2 repositories
Think about multiple p2 repositories [message #558375] Sat, 11 September 2010 13:53 Go to next message
my question is about multiple p2 repositories in a RMap.
The idea is to define one URL to a p2 repository and within a CQuery I
write down a list of possible branches. A part of the URL will then be
replaced by every entry from the list. As it is done with a SVN-Provider
and a list of branches and tags.
I'm looking for that because we create a p2 repository for every
release. And if we have to list all these p2 repositories in a RMap the
RMap will grow to large.
Does anybody have an idea for that?
Thanks for helping...
regards,
Matthias
Re: Think about multiple p2 repositories [message #558376 is a reply to message #558375] Sat, 11 September 2010 21:37 Go to previous messageGo to next message
Hi Mattias,
One idea is that you combine all your repositories in a composite repository and then have our RMAP reference that.
- thomas
On 09/11/2010 07:53 PM, Matthias Kappeller wrote:
> regards,
> Matthias
Re: Think about multiple p2 repositories [message #558389 is a reply to message #558376] Sun, 12 September 2010 03:05 Go to previous messageGo to next message
Hi Thomas,
I've thought about that. My problem is, we do not rest upon the
osgi-version :(
regards,
Matthias
Am 12.09.10 03:37, schrieb Thomas Hallgren:
> Hi Mattias,
> - thomas
>> regards,
>> Matthias
Re: Think about multiple p2 repositories [message #558396 is a reply to message #558389] Sun, 12 September 2010 05:40 Go to previous messageGo to next message
On 09/12/2010 09:05 AM, Matthias Kappeller wrote:
> Hi Thomas,
> osgi-version :(
Not sure why that would change the circumstances in this case. Can you elaborate?
- thomas
> regards,
> Matthias
>> Hi Mattias,
>> - thomas
>>> Hi,
>>> regards,
>>> Matthias
Re: Think about multiple p2 repositories [message #558430 is a reply to message #558396] Sun, 12 September 2010 15:18 Go to previous messageGo to next message
Am 12.09.10 11:40, schrieb Thomas Hallgren:
>> Hi Thomas,
>> osgi-version :(
> elaborate?
I think a example will show what i meant:
Two Bundles (A) and (B), both have the version 1.0.0
(A) has a dependency to (B)
Within a release build both bundles - (A)_1.0.0.release1 and
(B)_1.0.0.release1 - will end up in a repository named [release_1]
Now (B) will be changed in an incompatible way so also (A) has to be
changed - BUT we do not change the OSGi versions! (unfortunately :( )
Another release build and the bundles - (A)_1.0.0.release2 and
(B)_1.0.0.release2 - end up in a repository named [release_2]
So if I will get (A) from [release_1] i also have to get (B) from
[release_1].
I think we will run into a problem if we put both repositories into a
composite because:
When i create a CQuery to get (A)_1.0.0.release1, I will also get the
newest from (B) with version 1.0.0 this will be (B)_1.0.0.release2. But
they are not compatible.
Am i right?
> - thomas
>> regards,
>> Matthias
>>> Hi Mattias,
>>> - thomas
>>>> Hi,
>>>> SVN-Provider
>>>> regards,
>>>> Matthias
Re: Think about multiple p2 repositories [message #558436 is a reply to message #558430] Sun, 12 September 2010 15:51 Go to previous message
Hi Matthias,
Not changing the versions does of course create problems. It actually
violates the whole p2 logic since an installable unit is uniquely
identified by its name and version (this combination should be
considered immutable). So you're right, a composite won't work for you.
- thomas
>>> Hi Thomas,
>>> osgi-version :(
>> elaborate?
> [release_1].
> composite because:
> Am i right?
>> - thomas
>>> regards,
>>> Matthias
>>>> Hi Mattias,
>>>> - thomas
>>>>> Hi,
>>>>> SVN-Provider
>>>>> the
>>>>> regards,
>>>>> Matthias
Previous Topic: "svn: authentication cancelled" error
Next Topic:Cannot open launch config (junit run)
Current Time: Mon Nov 03 15:53:07 EST 2025
Powered by FUDForum. Page generated in 0.03227 seconds
