Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Emfatic] Pattern Validation and Creating Dynamic Instances
[Emfatic] Pattern Validation and Creating Dynamic Instances [message #558361] |
Sat, 11 September 2010 17:33 |
Toñi Reina Messages: 209 Registered: July 2009 |
Hi all,
I'm writing a small metamodel to test some regular expressions. I
have used emfatic, and as you can see below, the metamodel is very
simple. It only contains the root class named Test and other class with
two attributes: name and value. Value represents a string that should
match a regular expression (the regular expression I'm testing). To
constraint the values, a datatype named RegExp1 has been specified (you
can see the details below.
@namespace(uri="http://regexp.test", prefix="test")
package testregexp;
class Test {
val Example[+] examples;
class Example{
attr String name;
attr RegExp1 value;
@ExtendedMetaData(name="RegExp1",
baseType="http://www.eclipse.org/emf/2003/XMLType#string",
pattern="[A-Z]")
datatype RegExp1: String;
My problem arises when I try to write a model that conforms to this
metamodel by creating a dynamic instance with the Sample Reflective
Ecore Model Editor. Every time I try to write some text in the value
attribute the exception I have included below is thrown. My question is
if I'm missing something, it's seems there's some kind of problem with
the validation of the regular expression, but I really don't know what
the problem is, so I'd be grateful if you could give some hint:
null Error
Unhandled event loop exception
at
org.eclipse.emf.ecore.util.EObjectValidator.reportDataValueT ypeViolation(EObjectValidator.java:1652)
at
org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:1447)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:209)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:197)
at
org.eclipse.emf.edit.ui.provider.PropertyDescriptor$EDataTyp eValueHandler.isValid(PropertyDescriptor.java:176)
at org.eclipse.jface.viewers.CellEditor.isCorrect(CellEditor.ja va:529)
at
org.eclipse.emf.edit.ui.provider.PropertyDescriptor$EDataTyp eCellEditor.isCorrect(PropertyDescriptor.java:253)
at org.eclipse.jface.viewers.CellEditor.setValue(CellEditor.jav a:853)
at
org.eclipse.ui.views.properties.PropertySheetEntry.getEditor (PropertySheetEntry.java:384)
at
org.eclipse.ui.views.properties.PropertySheetViewer.activate CellEditor(PropertySheetViewer.java:163)
at
org.eclipse.ui.views.properties.PropertySheetViewer.handleSe lect(PropertySheetViewer.java:727)
at
org.eclipse.ui.views.properties.PropertySheetViewer.access$8 (PropertySheetViewer.java:707)
at
org.eclipse.ui.views.properties.PropertySheetViewer$6.mouseD own(PropertySheetViewer.java:816)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:185)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Toñi
Re: [Emfatic] Pattern Validation and Creating Dynamic Instances [message #558365 is a reply to message #558361] |
Sat, 11 September 2010 18:19 |
Ed Merks Messages: 33142 Registered: July 2009 |
Toñi,
It looks like eDataType.getInstanceClass().getName() fails. So probably
the instance class can't be created. Perhaps we should be using
eDataType.getInstanceTypeName, but not being able to create the class
instance would make verifying that something is an instance of that data
type's class difficult (impossible). Should you have specified
java.lang.String somewhere?
Toñi Reina Quintero wrote:
> Hi all,
> with two attributes: name and value. Value represents a string that
> should match a regular expression (the regular expression I'm
> testing). To constraint the values, a datatype named RegExp1 has been
> specified (you can see the details below.
> package testregexp;
> class Test {
> class Example{
> attr String name;
> attr RegExp1 value;
> pattern="[A-Z]")
> is if I'm missing something, it's seems there's some kind of problem
> with the validation of the regular expression, but I really don't know
> what the problem is, so I'd be grateful if you could give some hint:
> null Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards,
> Toñi
Ed Merks
Re: [Emfatic] Pattern Validation and Creating Dynamic Instances [message #558399 is a reply to message #558365] |
Sun, 12 September 2010 10:59 |
Hi Ed,
thanks for the help. That was the problem, I wasn't using
java.lang.String as Instance type name. However, the strange thing is
that I have written other metamodels setting Instance type name to
String, instead of java.lang.String and they worked.
Now, I know that I have to be very careful with the datatypes.
El 11/09/2010 20:19, Ed Merks escribió:
> Toñi,
>> Hi all,
>> I'm writing a small metamodel to test some regular expressions. I have
>> used emfatic, and as you can see below, the metamodel is very simple.
>> It only contains the root class named Test and other class with two
>> package testregexp;
>> class Test {
>> class Example{
>> attr String name;
>> attr RegExp1 value;
>> pattern="[A-Z]")
>> null Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Regards,
>> Toñi
Re: [Emfatic] Pattern Validation and Creating Dynamic Instances [message #623169 is a reply to message #558361] |
Toñi,
> Hi all,
> package testregexp;
> class Test {
> class Example{
> attr String name;
> attr RegExp1 value;
> pattern="[A-Z]")
> null Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards,
> Toñi
Ed Merks
Re: [Emfatic] Pattern Validation and Creating Dynamic Instances [message #623170 is a reply to message #558365] |
Hi Ed,
> Toñi,
>> Hi all,
>> package testregexp;
>> class Test {
>> class Example{
>> attr String name;
>> attr RegExp1 value;
>> pattern="[A-Z]")
>> null Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Regards,
>> Toñi
Current Time: Fri Apr 26 17:17:34 GMT 2024
Powered by FUDForum. Page generated in 0.03552 seconds
