Re: Birt + Excel [message #557766 is a reply to message #557689] |
Wed, 08 September 2010 19:02 |
Anthony,
Have you seen this post?
http://birtworld.blogspot.com/2010/06/birt-excel-output.html
Jason
On 9/8/2010 10:16 AM, Anthony S wrote:
> Hi
> I'm new to birt. I have to make dynamic reports using Birt. My reports
> must be in XLS.
> I worh with an Eclipse Birt distribution.
> I tried some tutorials etc. and I had a problem with to general reports
> with, images, charts, several sheets.
> It seems I need a more powerfull emiter than the one I have with my
> distribution.
> The Tribix emiter is not considered for now
> So I am here for that I would like to use the Actuate solution in trial
> in order to validate if it feets my needing.
> I would like your suggestions on that.
> Anthony
Re: Birt + Excel [message #557786 is a reply to message #557766] |
Wed, 08 September 2010 22:34 |
Anthony S Messages: 19 Registered: September 2010 |
Yes I saw this post and reoriented my work on Actuate. It's the purpose
of my question. I didn't find an Actuate Eclipse distribution that allow
me to put images, charts etc. in an XLS report file whereas it would be.
My computer at work do not allow me (no admin rights) to install
actuate executable programs. I will try with my own computer but I am
looking for a plugin, or an eclipse, that could reach my needs even if a
payable license is necessary.
[Updated on: Wed, 08 September 2010 22:34] Report message to a moderator
Re: Birt + Excel [message #558234 is a reply to message #558092] |
Fri, 10 September 2010 15:28 |
The A11 version has the improved xls emitter. A10 does not.
Jason
On 9/10/2010 3:48 AM, Anthony S wrote:
> I managed to generate images&charts in XLS with Birt-Actuate designer
> V11 (trial version, testing before buying) but not with the V10.
> I tought the Birt-Acutate report designer 10 was able to to generate
> images, charts etc. in XLS ? Someone has already tried ?
Re: Birt + Excel [message #558639 is a reply to message #558282] |
Mon, 13 September 2010 18:26 |
We should have some video recording demos up this week.
Jason
On 9/10/2010 3:20 PM, Anthony S wrote:
> Thank you. Now I understand better. I think i am in the good direction
> with Actuate 11.
> Is there tutorials on Actuate somewhere ?
FUDForum. Page generated in 0.04354 seconds
