Problem by cast from AnyTypeImpl to ModelImpl [message #557414] |
Tue, 07 September 2010 06:57  |
Hallo,
i am facing a problem after migration of my oaw 4 project to oaw 5 project.
the class SimpleJavaModificationComponent doesn't exist anymore in oaw 5. so i found the thread in http://www.openarchitectureware.org/forum/viewtopic.php?show topic=14146&lastpost=true#15202 and try to created SimpleJavaModificationComponent .
unfortunately i got the cast-exception:
1. my SimpleJavaModificationComponent:
import org.eclipse.emf.mwe.core.WorkflowContext;
import org.eclipse.emf.mwe.core.issues.Issues;
import org.eclipse.emf.mwe.core.lib.WorkflowComponentWithModelSlot;
import org.eclipse.emf.mwe.core.monitor.ProgressMonitor;
public abstract class SimpleJavaModificationComponent extends
WorkflowComponentWithModelSlot {
private Object modelObject;
protected void invokeInternal(WorkflowContext ctx, ProgressMonitor monitor,
Issues issues) {
String strName = getModelSlot();
modelObject = ctx.get(strName);
if (modelObject == null) {
issues.addWarning(this, "content of modelSlot " + getModelSlot()
+ " is null.");
doModification(ctx, monitor, issues, modelObject);
protected abstract void doModification(WorkflowContext ctx,
ProgressMonitor monitor, Issues issues, Object model);
2. my ModelTransformer Class
public class ModelTransformer extends SimpleJavaModificationComponent {
protected void doModification(WorkflowContext ctx, ProgressMonitor monitor,
Issues issues, Object model) {
ModelImpl dm = (ModelImpl) model;// <---caused an exception!!!
during debug i found out the Object model ist type of AnyTypeImpl. my question is how can i cast the AnyTypeImpl to ModelImpl?
thanks very much for your help.
Re: Problem by cast from AnyTypeImpl to ModelImpl [message #557489 is a reply to message #557414] |
Tue, 07 September 2010 12:45   |
Hi Ming
AnyType is the basic XMI element that Xtext uses until it can resolve a
proxy, so a CCE on an AnyType justvtells that a proxy resoluation failed
so your models/namespaces are incompatible or unresolvable.
If you search all ResourceSet.resources.errors you may find that
something is trying to tell you something; Xtext fails to explicitly
diagnose deep proxy resolution failures.
Ed Willink
On 07/09/2010 11:57, Ming Lu wrote:
> Hallo,
> @Override
> Issues issues) {
> + " is null.");
Re: Problem by cast from AnyTypeImpl to ModelImpl [message #557490 is a reply to message #557489] |
Tue, 07 September 2010 13:06   |
Hi Ming
Sorry wrong newsgroup. Nothing explicitly to do with Xtext, but the
proxy issue may still be relevant.
Ed Willink
> Regards
> Ed Willink
>> Hallo,
>> project.
>> @Override
>> monitor,
>> Issues issues) {
>> + " is null.");
>> monitor,
Re: Problem by cast from AnyTypeImpl to ModelImpl [message #558188 is a reply to message #557973] |
Fri, 10 September 2010 09:16  |
Hi, Christian, Karsten, Edward
thanks a lot for your kindly helps!
i resolved the problem with the new component4oaw. it was the problem of uml 2 compilable from the c4oaw 1.6.1. with c4oaw 2.0 rc3 is my project runnable.
thanks again for your helps!
best regards and nice weekend!
~Ming
FUDForum. Page generated in 0.05371 seconds
