Home » Modeling » OCL » Some OCL beginner questions
Some OCL beginner questions [message #557267] |
Mon, 06 September 2010 11:18 |
from an old application, I use the xsd-schmea to build a new EMF model.
This is also complete atthe most things, the only big point at the
moment are the attribute definitions and also the validation of it.
In our old xsd, we had many type definitions with inheritance and so one.
Now I want to dissolve theses type definitions and put the constrains of
it into ocl definitions for validating.
For this I test some things and also do rebuild the tutorial inside the
eclipse documentation, but I do have some stupid questions and I hope
somebody can answer me or can point me to a solution.
1. Reusing an OCL expression on some points:
Many of my needed expressions I need on more points, e.g.
the length of a String should not be longer than 30
( self.<attribute>.size()<30 )
It is possible to define this expression one time an use it for
a) diffrent attributes inside one class
b) diffrent attributes inside diffrent classes of one package
c) diffrent attributes inside diffrent classes of one package and his
subpackages?
2. Type definitions inside XML allows inheritence, it is poossible to
use the expression of quition 1 and extend it with an other expression
like: first char must be an "A" ?
3. Using RegEx expresion inside an OCL expression,
is at the moment only available with Customize the environment ?
http://www.eclipse.org/forums/index.php?t=tree&th=10433& amp;S=14a8a1aea530c5f36c12ae0b49a03269
http://www.eclipse.org/forums/index.php?t=msg&goto=49060 5&
Or comes up an better solution with the Helios release?
Thanks in advance for your answers
Heiko
Re: Some OCL beginner questions [message #557315 is a reply to message #557267] |
Mon, 06 September 2010 15:43 |
Ed Willink Messages: 7670 Registered: July 2009 |
Hi Heiko
Inline...
On 06/09/2010 12:18, Heiko wrote:
> subpackages?
I can't see a question here.
Yes, The standard way to re-use partial expressions is to place them in
functions/operations/procedures.
regex is a pending OMG OCL issue which MDT/OCL will track/anticipate.
Ed Willink
Re: Some OCL beginner questions [message #557567 is a reply to message #557315] |
Wed, 08 September 2010 06:41 |
Hi Ed,
thanks for your quick answer,
I have forgotten to say, at the moment I try to define the OCL
expressions with the OCLInEcore Editor.
For point 1:
I have a model class Person with the attributes name and surename
and for both should work the same expression like
self.{attribute}.size()<30
but at the moment I only know to define this with:
self.name.size()<30
self.surename.size()<30
I would like a more dynamic way, but I doesn't know how.
Am 06.09.2010 17:43, schrieb Ed Willink:
> Hi Heiko
> Inline...
>> Hi,
>> subpackages?
> Regards
> Ed Willink
Re: Some OCL beginner questions [message #557608 is a reply to message #557567] |
Wed, 08 September 2010 09:26 |
Hi Heiko
By more dynamic, I think you mean reflective. This is an ongoing
discussion topic and may appear in a future OCL specification and
MDT/OCL implementation.
Ed Willink
On 08/09/2010 07:41, Heiko wrote:
> Hi Ed,
> For point 1:
> self.name.size()<30
>> Hi Heiko
>> Inline...
>>> Hi,
>>> one.
>>> subpackages?
>> Regards
>> Ed Willink
Current Time: Fri Sep 20 02:12:15 GMT 2024
Powered by FUDForum. Page generated in 0.04105 seconds
