Home » Language IDEs » Java Development Tools (JDT) » erroneous "Potential null pointer access" warning
erroneous "Potential null pointer access" warning [message #556589] Wed, 01 September 2010 18:21 Go to next message
The following code
	public int test() {
		String a = getA();
		boolean aNull = (a == null);
		String b = getB();
		boolean bNotNull = (b != null);
		return (aNull && bNotNull) ? b.length() : 42;  // <<< warning
	public String getA() {
		return "foo";
	public String getB() {
		return "bar";
will generate the following warning for the indicated line:
Potential null pointer access: The variable b may be null at this location.
Given the preceding code, b cannot be null at that location. Is this a bug?
Thanks.
Re: erroneous "Potential null pointer access" warning [message #556622 is a reply to message #556589] Thu, 02 September 2010 02:59 Go to previous messageGo to next message
Brian Vosburgh wrote:
> The following code
> public int test() {
> String a = getA();
> String b = getB();
> return "foo";
> return "bar";
> location.
> bug?
No. It's a "potential" null pointer access. In your case it's obvious:
the methods could return different values from subclasses. But even if
you would declare the methods private the compiler would still warn
because it does not try to fully compute the values.
Dani
> Thanks.
Re: erroneous "Potential null pointer access" warning [message #556811 is a reply to message #556622] Thu, 02 September 2010 12:53 Go to previous messageGo to next message
Dani Megert wrote on Thu, 02 September 2010 02:59
> The following code
> public int test() {
> String a = getA();
> String b = getB();
> return "foo";
> return "bar";
> location.
> bug?
Thanks for the response, Dani.
"b.length()" can only be called if "bNotNull" is true and "bNotNull" is calculated in line 4 of the method to be "(b != null)".
So, I see no "potential" at all. Or am I missing something?
Brian
Re: erroneous "Potential null pointer access" warning [message #556892 is a reply to message #556589] Fri, 03 September 2010 00:35 Go to previous messageGo to next message
This is not a bug in my opinion.
Static analysis in the compiler doesn't compute values of expressions, but only take into account the initilization status and null status of variables.
In this case, when u write
we flag b as being potentially null as the code compares b with null. But we dont calculate true/false status of bNotNull. Again in the line
when the compiler analyzed b.length, it find the null status of b in the flow info as potentially null, hence flagging off the warning.
Re: erroneous "Potential null pointer access" warning [message #556899 is a reply to message #556811] Fri, 03 September 2010 02:07 Go to previous messageGo to next message
>> > The following code
>> > public int test() {
>> > String a = getA();
>> > String b = getB();
>> > return "foo";
>> > return "bar";
>> > Potential null pointer access: The variable b may be null at this >
>> location.
>> this a > bug?
>> obvious: the methods could return different values from subclasses.
>> But even if you would declare the methods private the compiler would
>> still warn because it does not try to fully compute the values.
Yes, you are. Your class might be used in a different context where a
subclass returns 'null' in getA() and getB(). But as said before, even
if you declared your class private the compiler would not detect the
case because it does not do a full-fledged flow + value analysis.
Dani
> Brian
Re: erroneous "Potential null pointer access" warning [message #556983 is a reply to message #556899] Fri, 03 September 2010 09:53 Go to previous messageGo to next message
Dani Megert wrote on Fri, 03 September 2010 02:07
>> > The following code
>> > public int test() {
>> > String a = getA();
>> > String b = getB();
>> > return "foo";
>> > return "bar";
>> location.
>> this a > bug?
Even if the subclass returns null for getB(), b.length() would never be executed, given the check that is captured in bNotNull. The value of b is never changed between "bNotNull = (b != null)" and the ternary statement controlled by the value of bNotNull. If the compiler does not perform a full-fledged "flow + value analysis" it seems it is overstepping its helpfulness with this warning?
Some sort of analysis is performed, since, if I change the ternary statement to this:
return (aNull && (b != null)) ? b.length() : 42;
the warning goes away.
I was just looking to make some code a bit a more readable, using semantically-named temporary variables. (The actual code is a bit more complicated than this example....) But then this warning popped up. Rats! Smile
Thanks for the help.
Brian
Re: erroneous "Potential null pointer access" warning [message #559482 is a reply to message #556589] Thu, 16 September 2010 14:36 Go to previous message
Agreed, that's a nasty bug in Eclipse's control flow analyzis. Just
return null from getB() and you'll see that no NPE is thrown. Maybe you
want to file an enhancement request?
Sebastian
Am 02.09.10 00:21, schrieb Brian Vosburgh:
> The following code
> public int test() {
> String a = getA();
> String b = getB();
> return "foo";
> return "bar";
> Thanks.
Previous Topic:Autocompletion implementaion
Next Topic:Poor junit performance with threaded tests in 3.6
Current Time: Thu Nov 06 21:07:29 EST 2025
Powered by FUDForum. Page generated in 1.06842 seconds
