Re: product feature cannot be resolved in build [message #557040 is a reply to message #557027] |
Fri, 03 September 2010 17:11 |
Alex Kravets Messages: 561 Registered: November 2009 |
Johannes Utzig wrote on Fri, 03 September 2010 11:57 | Hi Alex
Am 03.09.2010 17:45, schrieb Alex:
> About TP in Hudson. If you already don't have this in place, I suggest
> you create a separate job for TP and reuse the job in your builds. This
> has two advantages: first, you can independently build you TP, second
> your builds are faster because TP does not need to be imported on each
> build but reused. You can reference
> http://www.eclipse.org/forums/index.php?t=msg&th=163429& amp; amp;start=0&S=42b5f47586ad19bd17a9f9fe0e0cb93c
> post for information on how to do it.
Two additional comments on this approach:
1. If you do not delete the materialized TP after the build, the
execution time should be rather similar
2. So far the Target Platform Publisher does not work in a distributed
environment, so it's important that the TP job runs on the same physical
machine as all the builds that use this TP.
Johannes
Thanks Johannes,
I'll have to double check on #1, I was certain that with importtargetdefintion it was always a bit slower.
Thanks for mentioning #2.
Alex
FUDForum. Page generated in 0.03321 seconds
