OCL 'source code' of an OCLExpression [message #556303] |
Tue, 31 August 2010 12:54  |
Hi!
I have trouble obtaining the OCL source code of an OCLExpression instance. I thought this to be a rather trivial problem at first, so I hope I didn't miss something obvious!
I want to annotate an Ecore model with OCL expressions for validation, but when I create an EAnnotation with the return value of myOclExpr.toString() as the value of a detail entry, I get code which is syntactically incorrect, e.g.
PackageA::ClassA.allInstances()->forAll(x : ClassA, y : ClassA | x.referenceA->includes(y).implies(x.referenceB->includes(y)))
instead of
PackageA::ClassA.allInstances()->forAll(x : ClassA, y : ClassA | x.referenceA->includes(y) implies x.referenceB->includes(y))
Obviously I'm not able to run any validation on my model with this code.
I figure the toString()-method (and hence the ToStringVisitor) is not the correct way to obtain the OCL source, but what exactly IS the correct way?
Kind regards,
Martin
Re: OCL 'source code' of an OCLExpression [message #556312 is a reply to message #556303] |
Tue, 31 August 2010 13:22   |
Hi Martin
The API of ToStringVisitor is documented as:
* Converts an OCL expression to a string for debugging. This is not
intended
* to be used by client applications as an AST-to-text transformation.
For debugging purposes ".implies()" etc is more readable than "implies".
There is an explicit OCL unparser as part of the M2M/QVTd project.
There is unparsing as part of the Xtext editors, but slightly difficult
to access. Please raise a Bugzilla to have a useful public API for this.
I'm not clear why you are starting with the AST. If you use OCLinEcore
you can annotate your Ecore model directly.
Ed Willink
On 31/08/2010 17:54, Martin Knauer wrote:
> Hi!
> instead of
> correct way?
> Kind regards,
> Martin
Re: OCL 'source code' of an OCLExpression [message #556522 is a reply to message #556429] |
Wed, 01 September 2010 12:11  |
For now, I would recommend starting with
org.eclipse.qvt.declarative.parser.unparser.OCLUnparser
since it's simple with few dependencies. You can tweak it to your taste.
The Xtext config is part of a more powerful framework so it may be
harder to exploit.
Ed Willink
On 01/09/2010 11:10, Martin Knauer wrote:
> Hi Ed,
> thanks a lot for your reply!
> Edward Willink wrote on Tue, 31 August 2010 19:22
> The model and the OCL constraints are supposed to be programmatically
> generated at the same time, so the plan was to build an AST rather than
> to build the OCL code with Strings. I hope I will find what I need in
> M2M/QVTd or Xtext!
> Thanks again,
> regards,
> Martin
FUDForum. Page generated in 0.04385 seconds
