not mirror pack200 bundles [message #556195] |
Tue, 31 August 2010 09:52 |
Jacek Pospychala Messages: 159 Registered: July 2009 |
hi,
to speed up our internal build system, we maintain local mirror of several p2 repositories, such as emf, gef, wtp, mylyn, etc. For mirroring, p2.mirror ant task is used. e.g. for emf:
<p2.mirror verbose="true">
<repository location="${localRepo}" append="true" />
<source>
<repository location="http://download.eclipse.org/modeling/emf/updates/" />
</source>
<iu id="org.eclipse.emf.all.feature.group" version="" />
</p2.mirror>
A while ago emf and gef repositories started distributing both packed (pack.gz) and canonical (jar) bundles, which broke our build. Out of sudden p2.mirror task started logging following problems:
[p2.mirror] Artifact: canonical: osgi.bundle,org.eclipse.zest.layouts,1.1.0.v20100616-1515 already exists in repository: file:/disk2/hudson/../mirrors/7.3/.
[p2.mirror] Artifact: packed: osgi.bundle,org.eclipse.zest.layouts,1.1.0.v20100616-1515 already exists in repository: file:/disk2/hudson/../mirrors/7.3/.
later on during the build, p2.director was failing to install any of bundles from the local repo that were available in packed and canonical form. The error log was simply saying that bundle xyz was not found, altough looking in the file system, both formats were available and listed in artifacts.xml file.
Since we were always happy with jars, I tried several ways to get rid of packed bits:
1. use p2.remove.ui - it seems to apply the filter only to IU mentioned in IU tag, and not to all other dependent IUs. I'd need a way to express that we want to remove all packed bundles, without explicitly listing their IDs.
2. tried exclude tag inside comparator in p2.mirror task but apparently, exclude affects only comparator and not mirroring.
3. tried to use query filter in iu tag in p2.mirror, but honestly I have no clue how to define it to filter all packed bundles.
The temporary solution to this problem turned to be removing all *.pack.gz files and regenerating repository metadata. This made p2.director working again. Altough it's less than perfect solution, because now every run, p2.mirror copies packed bits and in next step they're removed.
Is there a simple way to not mirror packed bundles, but only jared ones?
thanks!
Jacek
FUDForum. Page generated in 0.02555 seconds
