Re: [MTL] UML primitive type problems [message #55978 is a reply to message #55910] |
Thu, 22 January 2009 16:13 |
--------------040509090604090809090209
Hi Max,
For the UML2Java example we have in MTL, we had defined our own
primitive types. We then never encountered this issue :(. As this is
most probably a bug, could you raise a bugzilla describing this issue?
Laurent Goubet
Obeo
Max Bureck a
Re: [MTL] UML primitive type problems [message #56162 is a reply to message #56085] |
Fri, 23 January 2009 12:17 |
--------------020704050203060207070707
Thanks Max,
We'll try and get a look at this ASAP. This is most probably a problem
with the pathmap:// like uris :(.
laurent Goubet
Obeo
Max Bureck a
FUDForum. Page generated in 0.02700 seconds
