Home » Eclipse Projects » Eclipse Platform » Add action to external editors
Add action to external editors [message #555905] Mon, 30 August 2010 03:39 Go to next message
I am working on an application in which I need to add an action to
context menu of editor. However, this action should be visible only for
external editors (i.e. for editing files which are external to the
workspace).
In my plugin, plugin.xml file if I use,
objectClass="org.eclipse.core.resources.IResource", this action is
visible and enabled in context menu of internal editors only.
If objectClass="org.eclipse.ui.IEditorInput" is used, the action is
visible and enabled in context menu of both internal and external editors.
Following is the code snipppet of plugin.xml for my plug-in.
<objectContribution
adaptable="true"
id="my.plugin.objectContributionAction1"
objectClass="org.eclipse.core.runtime.IResource">
<action
class="my.plugin.internal.Action1"
enablesFor="1"
icon="icons/obj/image.png"
id="my.plugin.Action1"
label="Action Label"
tooltip="Action Tooltip">
</action>
</objectContribution>
I am not able to find any hints on how to show the action in context
menu of external editors only.
Any suggestions would be of great help.
Sneha
Re: Add action to external editors [message #555950 is a reply to message #555905] Mon, 30 August 2010 06:58 Go to previous messageGo to next message
Please let me know if there are any pointers for this.
Thanks in advance,
Sneha
sneha wrote:
> workspace).
> <objectContribution
> adaptable="true"
> <action
> enablesFor="1"
> </action>
> Sneha
Re: Add action to external editors [message #555979 is a reply to message #555905] Mon, 30 August 2010 08:55 Go to previous message
You would probably need to use a more complex <enablement> clause, so
you can evaluate that it is <not> an IResource.
With core expression, you would use <not><adapt
type="...IResource/></not>. That's used with org.eclipse.ui.menus
menuContributions.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Is there an equivalent to DreamWeaver's Library Asset?
Next Topic:IMarkers and Problems View for validation without any IResource?
Current Time: Thu Nov 06 10:59:57 EST 2025
Powered by FUDForum. Page generated in 0.04444 seconds
