Re: IMarkers and Problems View for validation without any IResource? [message #556026 is a reply to message #555898] |
Mon, 30 August 2010 15:07 |
Ed Merks Messages: 33142 Registered: July 2009 |
Ralf,
It might make some sense it be separate but it's not right now. The
interface is also marked like this
* @noimplement This interface is not intended to be implemented by clients.
* @noextend This interface is not intended to be extended by clients.
And it has stuff to do with line numbers or characters start/end ranges,
which don't make much sense unless source text is involved.
You're pretty much stuck writing your own problems view...
Ralf Zahn wrote:
> I have a custom application that is based on Eclipse and should run
> with both RCP and RAP. Within this application, I have a model that is
> stored within a database. I want to provide validation functionality
> and would therefore provide the Problems view.
> The problem is that the Problems View and the IMarker interface are
> both part of the org.eclipse.core.resources plugin that is not
> supported by RAP. Is there any possibility that I do not have to write
> a custom Problems view by myself? Wouldn't it make sense to extract
> the problems view and IMarker interface from the Resources Plugin and
> make it indepentent from a workspace?
Ed Merks
FUDForum. Page generated in 0.03091 seconds
