Home » General (non-technical) » Eclipse Foundation » The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program redistr
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #55942 is a reply to message #55842] |
Thu, 18 September 2008 19:41 |
Originally posted by: nospam_kowalskilee.gmail.com
NOte: I am not a lawyer. I cannot give legal advice. (I have to put that
up front here).
FAQ #24 of the eplfaq says that if your question isn't answered there,
to contact license@eclipse.org.
I think that your question is:
"If I modify Eclipse code and compile the modified code, can I use the
resulting object code in a commercial program redistributed in object
form only?"
(If I'm incorrect, please clarify further).
The eplfaq has question #15 that says "Can I take a Program licensed
under the EPL, compile it without modification, and commercially license
the result?"
If I'm correct about your question, it is a question like "Can I take a
Program licensed under the EPL, modify it, compile it, and commercially
license the result?"
Sincerely,
Lee Anne
Edoardo Comar wrote:
> Hi
> ** I am not expecting legal advice here **
> Just an opinion please.
> Even after reading
> http://www.eclipse.org/legal/epl-v10.html
> http://www.eclipse.org/legal/legalfaq.php
> http://www.eclipse.org/legal/eplfaq.php
> I wasn't able to clarify whether snippets of Eclipse/EPL code can be
> used/modified in a commercial program redistributed in object from only.
> The FAQ only say that *if* source is redistributed, then the source that
> originated from EPL sources must be licensed under EPL.
> But if one chooses not to redistribute source ?
> thanks
> Edoardo
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #56016 is a reply to message #55942] |
Fri, 19 September 2008 09:12 |
Edoardo Comar Messages: 102 Registered: July 2009 |
Hi Lee
your interpretation of my post
is not exactly what I meant. I was essentially asking if you can
take "code snippets" (lines/methods/classes) of an EPL program,
possibly modfy them to suit your program, and use them in you own
commercially licensed, distributed in object code form only, without
having to distribute your sources (the ones where you have made use of
some code coming from an EPL-licensed program).
Edoardo
> up front here).
> form only?"
> the result?"
> Sincerely,
> Lee Anne
>> Hi
>> Even after reading
>> that originated from EPL sources must be licensed under EPL.
>> thanks
>> Edoardo
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #56042 is a reply to message #55842] |
Fri, 19 September 2008 16:47 |
Tom Morris Messages: 89 Registered: July 2009 |
Member |
Well, you're asking for an opinion about a legal document (the EPL) and
applicable copyright law, so it certainly sounds like legal advice to
me. If there's an economic/legal risk, you should ask your lawyer. If
there's no risk, flip a coin.
Here's my non-lawyer opinion about your question...
The FAQ isn't the controlling document, the license (EPL) is. The
license says that sources for any derivative works created from EPL code
must be distributed.
You could claim a "fair use" exception if the "snippets" are small
enough, but that's a very gray area and the courts weight a whole bunch
of factors like total size, % of overall work, use, economic impact,
etc, etc. You might have seen guidelines from various projects that say
anything more than NN lines of code requires a contributors agreement
and you could try to pick a number out of the air like that as well, but
it's really not that simple.
Your followup gives examples of "snippets" (some of which are pretty
non-snippety to may way of thinking), so here's my gut reaction to them:
- Class - definitely not fair use
- Method - probably not fair use unless its a small/trivial method
- Lines - probably fair use as long as it's not too many lines (whatever
"too many" means)
Tom
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #56072 is a reply to message #56016] |
Fri, 19 September 2008 16:48 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------010901080403080300030206
Edoardo,
If you copy any EPL code *and *make changes to that copy, those changes
need to be made available under EPL-license in source form. That
doesn't mean the whole product built around it can't be commercially
licensed closed source, it just means you must share the source. I know
of IBM products that do this kind of copy it and change it type of thing
with EMF/SDO, and then make a zip file of just the changed files
available on some public website when the product is shipped...
> Hi Lee
> Edoardo
>> that up front here).
>> there, to contact license@eclipse.org.
>> the resulting object code in a commercial program redistributed in
>> object form only?"
>> a Program licensed under the EPL, modify it, compile it, and
>> commercially license the result?"
>> Sincerely,
>> Lee Anne
>>> Hi
>>> Even after reading
>>> only.
>>> thanks
>>> Edoardo
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Edoardo,<br>
<br>
If you copy any EPL code <b>and </b>make changes to that copy, those
changes need to be made available under EPL-license in source form.
That doesn't mean the whole product built around it can't be
commercially licensed closed source, it just means you must share the
source. I know of IBM products that do this kind of copy it and change
it type of thing with EMF/SDO, and then make a zip file of just the
changed files available on some public website when the product is
shipped...<br>
<br>
<br>
<blockquote cite="mid:gavqd7$2sr$1@build.eclipse.org" type="cite">Hi
Lee
<br>
<br>
<br>
<br>
take a
<br>
commercially
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Edoardo
<br>
<br>
<br>
Lee Anne wrote:
<br>
<blockquote type="cite"><br>
<br>
<br>
to contact <a class="moz-txt-link-abbreviated" href="mailto:license@eclipse.org">license@eclipse.org</a>.
<br>
<br>
<br>
form only?"
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Sincerely,
<br>
Lee Anne
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi
<br>
<br>
<br>
<br>
<br>
Even after reading
<br>
<br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/legal/epl-v10.html">http://www.eclipse.org/legal/epl-v10.html</a>
<br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/legal/legalfaq.php">http://www.eclipse.org/legal/legalfaq.php</a>
<br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/legal/eplfaq.php">http://www.eclipse.org/legal/eplfaq.php</a>
<br>
<br>
only.
<br>
<br>
<br>
<br>
<br>
<br>
thanks
<br>
Edoardo
<br>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------010901080403080300030206--
Ed Merks
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #56099 is a reply to message #56042] |
Fri, 19 September 2008 17:11 |
Thanks Tom
this explanation is good for me.
> "too many" means)
> Tom
Re: The FAQ aren't clear for me on this : inclusion/modification of EPL code snippets in program red [message #56126 is a reply to message #56072] |
Fri, 19 September 2008 17:12 |
Ed - doubts cleared now
Ed Merks wrote:
> Edoardo,
>> Hi Lee
>> Edoardo
>>> object form only?"
>>> Sincerely,
>>> Lee Anne
>>>> Hi
>>>> Even after reading
>>>> only.
>>>> thanks
>>>> Edoardo
Current Time: Fri Apr 26 06:11:57 GMT 2024
Powered by FUDForum. Page generated in 0.03564 seconds
