Home » Archived » BIRT » Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #554960 is a reply to message #554957] |
Tue, 24 August 2010 22:10 |
It looks like you are trying to start-up the engine each time. Look at
the BirtEngine class in the wiki page that you referenced:
public static synchronized IReportEngine getBirtEngine
It only starts up the platform once.
Also look further down the wiki page for later version examples.
Jason
On 8/24/2010 5:44 PM, dash wrote:
> I'm using birt 2.3.1 engine api in a web service deployed to weblogic
> 10.x. The birt engine is instantiated properly on the first call. i keep
> getting 'Could not initialize class
> org.eclipse.birt.report.engine.api.impl.ReportEngine' error on
> subsequent calls.
> I kind of following implementation example on
> http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1 because i can't
> find an birt 2.3 Servlet implementation example.
> I appreciate any help in advance.
> dash.
> // code snippets
> private IReportEngine getBirtEngine(ServletContext sc) {
> IReportEngine re = null;
> if (sc != null) {
> EngineConfig ec = new EngineConfig();
> ec.setLogConfig(BIRT_LOGS_PATH, Level.FINE);
> ec.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADE R_KEY,
> Thread.currentThread().getContextClassLoader());
> ec.setEngineHome("");
> IPlatformContext pc = new PlatformServletContext(sc);
> ec.setPlatformContext(pc);
> try {
> Platform.startup(ec);
> catch (BirtException be) {
> e.printStackTrace();
> IReportEngineFactory ref = (IReportEngineFactory)
> Platform.createFactoryObject(IReportEngineFactory.EXTENSION_
> REPORT_ENGINE_FACTORY);
> // offending line. remote debugger hangs here.
> re = ref.createReportEngine(ec);
> return re;
> @WebMethod
> public RetrieveReportResponse getReport(RetrieveReportRequest request)
> throws OperationTimeoutException, OperationValidationException,
> OperationException
> ServletContext sc = wsctx.getHttpSession().getServletContext();
> IReportEngine re = getBirtEngine(sc);
> if (re != null) {
> // debugging code
> String [] formats = re.getSupportedFormats();
> if (formats != null){
> for (String format: formats){
> System.out.println("*****supported format:" + format);
> else {
> System.out.println("***** Unable to obtain birt engine");
> try {
> if (re != null) {
> re.destroy();
> re = null;
> Platform.shutdown();
> catch (Exception e){
> // handle exception
> return response;
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555221 is a reply to message #555204] |
Wed, 25 August 2010 22:16 |
dash Messages: 20 Registered: August 2010 |
Jason,
I've the report designer crashing issue fixed by starting the designer with -vm C:\dev\jdk1.5.0_22\bin\java.exe. I'm able to preview my report with proper data showing in the designer.
However, when I run the same report in WebLogic, the data don't show up in the generated pdf, that shows the headings and date/time. The birt log indicates that the data are returned properly, so there isn't an issue of the jdbc connection.
Any thought?
kenny
// birt log
Aug 25, 2010 4:48:56 PM org.eclipse.birt.data.engine.odaconsumer.ResultSet fetch
FINEST: Fetched next row: 1,TestComp,Testing Company,1 .
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555245 is a reply to message #555221] |
Thu, 26 August 2010 04:14 |
Can you post the report?
On 8/25/2010 6:16 PM, dash wrote:
> Jason,
> Any thought?
> kenny
> // birt log
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #555459 is a reply to message #555403] |
Thu, 26 August 2010 16:30 |
Kenny,
If you create a report off the sample db does it work?
Jason
On 8/26/2010 10:02 AM, dash wrote:
> Here is the report.
> Thanks for your help,
> kenny
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/first_report.gif</property>
> <property
> name="cheatSheet">org.eclipse.birt.report.designer.ui.cheatsheet.firstreport
> </property>
> <property name="bidiLayoutOrientation">ltr</property>
> <template-parameter-definitions>
> <template-parameter-definition name="NewTemplateParameterDefinition"
> id="28">
> <property name="allowedType">Table</property>
> <text-property name="description">Customer Listing</text-property>
> <default>
> <table id="29">
> <property name="width">100%</property>
> <property name="pageBreakInterval">50</property>
> <column id="49"/>
> <column id="50"/>
> <column id="51"/>
> <column id="52"/>
> <header>
> <row id="30">
> <cell id="31">
> <label id="32">
> <property name="fontFamily">sans-serif</property>
> <property name="fontWeight">bold</property>
> <text-property name="text">Contact</text-property>
> </label>
> </cell>
> <cell id="33">
> <label id="34">
> <text-property name="text">First</text-property>
> </label>
> </cell>
> <cell id="35">
> <label id="36">
> <text-property name="text">Last</text-property>
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> <text-property name="text">Phone</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="39">
> <cell id="40"/>
> <cell id="41"/>
> <cell id="42"/>
> <cell id="43"/>
> </row>
> </detail>
> <footer>
> <row id="44">
> <cell id="45"/>
> <cell id="46"/>
> <cell id="47"/>
> <cell id="48"/>
> </row>
> </footer>
> </table>
> </default>
> </template-parameter-definition>
> <template-parameter-definition name="NewTemplateParameterDefinition1"
> id="78">
> <text-property name="description">Customer Listing Table</text-property>
> <default>
> <table id="79">
> <property name="refTemplateParameter">NewTemplateParameterDefinition
> </property>
> <column id="99"/>
> <column id="100"/>
> <column id="101"/>
> <column id="102"/>
> <header>
> <row id="80">
> <cell id="81">
> <label id="82">
> </label>
> </cell>
> <cell id="83">
> <label id="84">
> </label>
> </cell>
> <cell id="85">
> <label id="86">
> </label>
> </cell>
> <cell id="87">
> <label id="88">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="89">
> <cell id="90"/>
> <cell id="91"/>
> <cell id="92"/>
> <cell id="93"/>
> </row>
> </detail>
> <footer>
> <row id="94">
> <cell id="95"/>
> <cell id="96"/>
> <cell id="97"/>
> <cell id="98"/>
> </row>
> </footer>
> </table>
> </default>
> <template-parameter-definition name="NewTemplateParameterDefinition2"
> id="132">
> <default>
> <table id="133">
> <property name="refTemplateParameter">NewTemplateParameterDefinition1
> </property>
> <column id="157"/>
> <column id="158"/>
> <column id="159"/>
> <column id="160"/>
> <header>
> <row id="134">
> <cell id="135">
> <label id="136">
> </label>
> </cell>
> <cell id="137">
> <label id="138">
> </label>
> </cell>
> <cell id="139">
> <label id="140">
> </label>
> </cell>
> <cell id="141">
> <label id="142">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="143">
> <cell id="144">
> <data id="145"/>
> </cell>
> <cell id="146">
> <data id="147"/>
> </cell>
> <cell id="148">
> <data id="149"/>
> </cell>
> <cell id="150">
> <data id="151"/>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="152">
> <cell id="153"/>
> <cell id="154"/>
> <cell id="155"/>
> <cell id="156"/>
> </row>
> </footer>
> </table>
> </default>
> </template-parameter-definitions>
> <data-sources>
> <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
> name="devDataSource" id="248">
> <property name="odaDriverClass">oracle.jdbc.OracleDriver</property>
> <property
> name="odaURL">jdbc:oracle:thin:@devdb.lab.com:1521:DEVDB</property >
> <property name="odaUser">devuser</property>
> <encrypted-property name="odaPassword"
> encryptionID="base64">dWJ2YnVpbGQ=</encrypted-property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> name="accounts" id="249">
> <list-property name="columnHints">
> <structure>
> <property name="columnName">ID</property>
> <property name="displayName">ID</property>
> </structure>
> <structure>
> <property name="columnName">EXTERNALACCOUNTNUMBER</property>
> <property name="displayName">EXTERNALACCOUNTNUMBER</property>
> </structure>
> <structure>
> <property name="columnName">ACCOUNTNAME</property>
> <property name="displayName">ACCOUNTNAME</property>
> </structure>
> <structure>
> <property name="columnName">STATUS</property>
> <property name="displayName">STATUS</property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> <property name="position">1</property>
> <property name="name">ID</property>
> <property name="dataType">decimal</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">EXTERNALACCOUNTNUMBER</property>
> <property name="dataType">string</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">ACCOUNTNAME</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">STATUS</property>
> </structure>
> </list-property>
> </structure>
> <property name="devDataSource">devuser</property>
> <structure>
> <property name="nativeName">ID</property>
> <property name="nativeDataType">2</property>
> </structure>
> <structure>
> <property name="nativeName">EXTERNALACCOUNTNUMBER</property>
> <property name="nativeDataType">12</property>
> </structure>
> <structure>
> <property name="nativeName">ACCOUNTNAME</property>
> </structure>
> <structure>
> <property name="nativeName">STATUS</property>
> </structure>
> </list-property>
> <property name="queryText">select *
> from APPACCOUNT</property>
> <xml-property name="designerValues"><![CDATA[<?xml version="1.0"
> encoding="UTF-8"?>
> <model:DesignValues
> xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
> xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
> <Version>1.0</Version>
> <design:ResultSets derivedMetaData="true">
> <design:resultSetDefinitions>
> <design:resultSetColumns>
> <design:resultColumnDefinitions>
> <design:attributes>
> <design:name>ID</design:name>
> <design:position>1</design:position>
> <design:nativeDataTypeCode>2</design:nativeDataTypeCode>
> <design:precision>19</design:precision>
> <design:scale>0</design:scale>
> <design:nullability>NotNullable</design:nullability>
> <design:uiHints>
> <design:displayName>ID</design:displayName>
> </design:uiHints>
> </design:attributes>
> <design:usageHints>
> <design:label>ID</design:label>
> <design:formattingHints>
> <design:displaySize>22</design:displaySize>
> </design:formattingHints>
> </design:usageHints>
> </design:resultColumnDefinitions>
> <design:attributes>
> <design:name>EXTERNALACCOUNTNUMBER</design:name>
> <design:position>2</design:position>
> <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
> <design:precision>32</design:precision>
> <design:uiHints>
> <design:displayName>EXTERNALACCOUNTNUMBER</design:displayName >
> </design:uiHints>
> <design:usageHints>
> <design:label>EXTERNALACCOUNTNUMBER</design:label>
> <design:displaySize>32</design:displaySize>
> <design:attributes>
> <design:name>ACCOUNTNAME</design:name>
> <design:position>3</design:position>
> <design:precision>255</design:precision>
> <design:uiHints>
> <design:displayName>ACCOUNTNAME</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>ACCOUNTNAME</design:label>
> <design:displaySize>255</design:displaySize>
> <design:attributes>
> <design:name>STATUS</design:name>
> <design:position>4</design:position>
> <design:uiHints>
> <design:displayName>STATUS</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>STATUS</design:label>
> </design:resultSetColumns>
> </design:resultSetDefinitions>
> </design:ResultSets>
> </model:DesignValues>]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> <style name="report" id="110">
> <property name="fontFamily">"Verdana"</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab-cell" id="246">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="247">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <property name="topMargin">0.25in</property>
> <property name="leftMargin">0.25in</property>
> <property name="bottomMargin">0.25in</property>
> <property name="rightMargin">0.25in</property>
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <label id="245">
> <property name="fontSize">x-large</property>
> <property name="textAlign">center</property>
> <text-property name="text">Customer Listing</text-property>
> </label>
> <table id="163">
> <property name="dataSet">accounts</property>
> <property name="refTemplateParameter">NewTemplateParameterDefinition2
> </property>
> <list-property name="boundDataColumns">
> <structure>
> <expression name="expression">dataSetRow["ACCOUNTNAME"]</expression >
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["EXTERNALACCOUNTNUMBER"]</expression >
> </structure>
> <structure>
> <expression name="expression">dataSetRow["STATUS"]</expression>
> </structure>
> <structure>
> <expression name="expression">dataSetRow["ID"]</expression>
> </structure>
> </list-property>
> <column id="187"/>
> <column id="188"/>
> <column id="189"/>
> <column id="190"/>
> <header>
> <row id="164">
> <cell id="165">
> <label id="166">
> <text-property name="text">Account Name</text-property>
> </label>
> </cell>
> <cell id="167">
> <label id="168">
> <text-property name="text">Ext Name</text-property>
> </label>
> </cell>
> <cell id="169">
> <label id="170">
> </label>
> </cell>
> <cell id="171">
> <label id="172">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="173">
> <cell id="174">
> <data id="250">
> <structure>
> </structure>
> </list-property>
> <property name="resultSetColumn">ACCOUNTNAME</property>
> </data>
> </cell>
> <cell id="176">
> <data id="251">
> <structure>
> <expression
> </structure>
> </list-property>
> <property name="resultSetColumn">EXTERNALACCOUNTNUMBER</property>
> </data>
> </cell>
> <cell id="178">
> <data id="252">
> <property name="resultSetColumn">STATUS</property>
> </data>
> </cell>
> <cell id="180">
> <data id="253">
> <property name="resultSetColumn">ID</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="182">
> <cell id="183"/>
> <cell id="184"/>
> <cell id="185"/>
> <cell id="186"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556055 is a reply to message #556000] |
Mon, 30 August 2010 16:53 |
Kenny,
I meant that in the designer, there is a preference that determines how
many rows to return. When deployed the engine retrieves all the data.
What I am wondering is if something in the full data is causing the
issue. If you run a report against the sample db we can eliminate so
possible causes.
Jason
On 8/30/2010 10:08 AM, dash wrote:
> Hi Jason,
> Any pointers to debug the missing data issue?
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556097 is a reply to message #556088] |
Mon, 30 August 2010 18:56 |
Kenny,
I checked your report again and noticed your dataset did not have a
datasource property.
Jason
On 8/30/2010 2:22 PM, dash wrote:
> Jason,
> My test table only has 5 rows of data. I can preview all 5 rows of data
> in the designer. But, there isn't a single row showing at run-time even
> though all the data shows up in the birt log.
> The headings and data and time do get rendered properly in the PDF
> report. Just the data are missing...
>> // birt log
> I don't think the size of the dataset is the issue if it's what you
> meant. Can you think of any other area that I can dig around?
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556272 is a reply to message #556115] |
Tue, 31 August 2010 14:38 |
When you look at the xml view do any errors show up? Can you try
rebuilding the report without the template?
On 8/30/2010 4:53 PM, dash wrote:
> Jason,
> The data set has a property element pointing to the data-source element
> in the template. The birt log indicates that the data are fetched from
> the test table. I'm not quite sure what you meant...
> kenny
> <data-sources>
>> <property
>> </oda-data-source>
>> </data-sources>
> </data-sources>
>> <data-sets>
>> <oda-data-set
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556355 is a reply to message #556353] |
Tue, 31 August 2010 23:29 |
Can you try the helios allinone download?
On 8/31/2010 6:41 PM, dash wrote:
> Jason,
> The xml looks good. I'm trying to build a blank report without any
> template being used if that is what you meant. However, the designer
> keeps crashing again. I get java.lang.OutOfMemoryError: PermGen space
> error after a few operations such as previewing report, switching
> between layout and xml source views.
> I've tried different jvm startup settings for the designer without much
> luck. Any suggestion?
> C:\dev\ganymede\eclipse\ganymede-eclipse.exe -clean -vm
> C:\dev\jdk1.5.0_22\bin\java.exe vmargs -Xms128m -Xmx512m
> -XX:PermSize=512m -XX:MaxPermSize=1024m
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556558 is a reply to message #556355] |
Wed, 01 September 2010 18:28 |
Jason,
I pull down 2.5.2 because I don't have the appetite to try helios, the greatest and latest, yet. The 252 designer works like a champ, so far. However, I get the following error at run-time. Any idea?
I assume the deployment structure between the 231 and 252 is the same, right?
The documentation on the birt site seems to be for the older versions. Does 252 have its own documentation? If yes, can you please send me a pointer?
kenny
Sep 1, 2010 1:15:39 PM org.eclipse.birt.core.internal.plugin.ScriptEngineFactoryMan agerImpl createFactory
SEVERE: Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFa ctory.
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.birt.report.engine.script.javascript was unable to load class org.eclipse.birt.report.engine.javascript.JavascriptEngineFa ctory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556559 is a reply to message #556558] |
Wed, 01 September 2010 18:34 |
Kenny,
Can you verify that you do not have js.jar in your cp at runtime. If
you do this could conflict with the version that BIRT uses.
Jason
On 9/1/2010 2:29 PM, dash wrote:
> Jason,
> right?
> pointer?
> kenny
> createFactory
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #556782 is a reply to message #556720] |
Thu, 02 September 2010 14:56 |
Kenny,
Glad you have it working. What did you need to do?
What specific documentation are you referring to. A lot of the
development examples are older, but should still work. The deployment
instructions should also work. We have a lot on the FAQ for deployment
as well. We need to go through the site and add some content, so
getting your feedback would be much appreciated.
Jason
On 9/2/2010 8:51 AM, dash wrote:
> Jason,
> Thanks for all your help. The run-time is working fine now. The
> documentation and samples on the birt site seem to be for older
> versions. I wonder whether there is documentation for the version 252.
> kenny
Re: Could not initialize class org.eclipse.birt.report.engine.api.impl.ReportEngine [message #557003 is a reply to message #556884] |
Fri, 03 September 2010 15:09 |
Kenny,
can you look under http://wiki.eclipse.org/BIRT/FAQ and add an entry
under deployment.
Jason
On 9/2/2010 11:02 PM, dash wrote:
> Jason,
> I added <container-descriptor>
> <prefer-web-inf-classes>true</prefer-web-inf-classes>
> </container-descriptor> to the weblogic.xml in the WEB-INF of our war
> file. Instead of loading the js.jar from the ear's APP-INF/lib, the
> js.jar in the WEB-INF/lib gets loaded.
> I'm looking for general documentation because I'm still learning
> different aspects of the BIRT.
> I'm more than happy to contribute what I've learned back to the
> commnuity. Please send me a pointer.
> kenny
Current Time: Fri Apr 26 15:25:29 GMT 2024
Powered by FUDForum. Page generated in 0.06855 seconds
