[Acceleo 3] write all the imports of a class [message #554861] |
Tue, 24 August 2010 14:49 |
Sergio Messages: 21 Registered: August 2010 Location: Cardedeu |
I wanna write all the imports of a class, so I want to get all the classes included in the parameters of the operations.
I tried this:
[query public getParametersOperations(class : Class) : Sequence(T) =
class.getAllOperations().parameterableElements()->select(not oclIsKindOf(Class))/]
[template public importBlock(class : Class)]
// [protected ('for imports')]
[for (at : Parameter | class.getParametersOperations())]
import [packageDomain(class) + at.type.name /];
[/for]
// [/protected]
[/template]
but If the same class is in more than one parameter, I've got a repeated import.
I want to use this in more than one place...
How can I filter the correct classes? Or you know another way to do that?
THANK YOU!!
Sergio Sacristán
http://s2o-bcn.blogspot.com/
Re: [Acceleo 3] write all the imports of a class [message #554870 is a reply to message #554861] |
Tue, 24 August 2010 15:14 |
The key in your problem here is to use asSet() which will transform your collection into a Set. Because a set cannot have a duplicate element, you just have to create a set of the name of the type and duplicates will be delete. I have created an Acceleo project to show you how you can do it. My example uses Ecore as a metamodel contrary to UML in your example but it doesn't matter for that problem.
You can see that there are two ways to do it, and it is exactly the same mechanism. With OCL you should use "myCollection->collect(a | a.doSomething())" but we also tolerate "myCollection.doSomething()". both operation will create a collection. Then you just have to use asSet() to suppress all duplicates.
Stephane Begaudeau, Obeo
Re: [Acceleo 3] write all the imports of a class [message #555927 is a reply to message #555354] |
Mon, 30 August 2010 09:22 |
--------------070307080402080200060608
Hi Sergio,
With this, you still have duplicate entries? or the processing fails
before that?
I'd suggest you use this:
[template public parametersOperations(class : Classifier)]
[for (typeName : String |
class.getAllOperations().ownedParameter.type.name->asSet())]
import [packageDomain(class) + '.' + typeName/];
[/for]
// [/protected]
[/template]
Laurent Goubet
Obeo
Sergio wrote:
> yeah, thats great. Thank you.
> I tried this, but no luck...
> [let packDomain:String = packageDomain(class)]
> [for (eOperation : Operation | class.getAllOperations())]
> [for (name : String | eOperation.ownedParameter -> collect(param |
> param.type) -> collect (type | type.name) -> asSet())]
> import [packDomain + '.' + name/];
> [/for]
> [/for]
> // [/protected]
> [/let]
> [/template]
> Maybe it's because I'm using Class and not EClass? How can I use EClass
> from a Class (class.oclAsType(EClass) --> error cast)?
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070307080402080200060608--
FUDForum. Page generated in 0.03319 seconds
