Home » Language IDEs » PHP Development Tools (PDT) » An internal error occurred during: "Initializing Java Tooling".
An internal error occurred during: "Initializing Java Tooling". [message #554542] Mon, 23 August 2010 10:00 Go to next message
I keep getting the following error:
Invalid signature file digest for Manifest main attributes
I have had this several times recently, and each time, if I create a new workspace on import my project (from subversion), the problem goes away.
Any idea what might be causing this?
I am using eclipse-rcp-galileo-SR2-win32 with cdt-6.0.2 and subclipse 1.6.13.
p.s. I recently allowed Java to update to 1.6.20. However, I am not sure if the errors started to occur before, or after the update.
Re: An internal error occurred during: "Initializing Java Tooling". [message #634641 is a reply to message #554542] Fri, 22 October 2010 10:33 Go to previous messageGo to next message
i am getting the same error.
Were you able to find the solution to the problem ?
Thank you,
Re: An internal error occurred during: "Initializing Java Tooling". [message #635640 is a reply to message #634641] Wed, 27 October 2010 11:15 Go to previous messageGo to next message
Yes. My problem was that I had corrupted one of the Eclipse jar files. When I replaced it with an uncorrupted version it all worked.
Re: An internal error occurred during: "Initializing Java Tooling". [message #756414 is a reply to message #635640] Sat, 12 November 2011 17:48 Go to previous message
How do you know which files are corrupted? I installed a new plugin and my Eclipse Helios could not open anymore any project. Following are the errors messages:
java.lang.NoSuchMethodError: org.osgi.framework.Version.compareTo(Lorg/osgi/framework/Version;)I
at org.eclipse.pde.internal.core.plugin.PluginBase.getMatchRule(PluginBase.java:359)
at org.eclipse.pde.internal.core.plugin.PluginImport.load(PluginImport.java:112)
at org.eclipse.pde.internal.core.plugin.PluginBase.loadImports(PluginBase.java:189)
at org.eclipse.pde.internal.core.plugin.PluginBase.load(PluginBase.java:113)
at org.eclipse.pde.internal.core.plugin.Plugin.load(Plugin.java:43)
at org.eclipse.pde.internal.core.plugin.AbstractPluginModelBase.load(AbstractPluginModelBase.java:88)
at org.eclipse.pde.internal.core.plugin.ExternalPluginModelBase.load(ExternalPluginModelBase.java:70)
at org.eclipse.pde.internal.core.PDEState.createExternalModel(PDEState.java:352)
at org.eclipse.pde.internal.core.PDEState.createTargetModels(PDEState.java:203)
at org.eclipse.pde.internal.core.PDEState.<init>(PDEState.java:109)
at org.eclipse.pde.internal.core.PluginModelManager.initializeTable(PluginModelManager.java:512)
at org.eclipse.pde.internal.core.PluginModelManager.findModel(PluginModelManager.java:901)
at org.eclipse.pde.core.plugin.PluginRegistry.findModel(PluginRegistry.java:110)
at org.eclipse.pde.internal.core.RequiredPluginsInitializer.initialize(RequiredPluginsInitializer.java:27)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeContainer(JavaModelManager.java:2707)
at org.eclipse.jdt.internal.core.JavaModelManager$11.run(JavaModelManager.java:2613)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAllContainers(JavaModelManager.java:2653)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathContainer(JavaModelManager.java:1845)
at org.eclipse.jdt.core.JavaCore.initializeAfterLoad(JavaCore.java:3463)
at org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob.run(InitializeAfterLoadJob.java:35)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
eclipse.buildId=M20110210-1200
java.version=1.6.0_26
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=it_IT
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/pnhoang/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -product org.eclipse.epp.package.java.product -keyring /Users/pnhoang/.eclipse_keyring -showlocation
Previous Topic:Run configuration problems / paths
Next Topic:How to attach source code to thirt-party plugin for debug?
Current Time: Fri Oct 31 03:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.04250 seconds
