Hudson plugin fails to install buckminster [message #554466] |
Mon, 23 August 2010 06:04  |
Hi, I have the following error when installing buckminster through the
hudson plugin:
Unpacking
http://download.eclipse.org/tools/buckminster/products/direc tor_latest.zip
to /home/svw/.hudson/tools/Buckminster_3.6 on Hudson
[Buckminster_3.6] $
/home/svw/.hudson/tools/Buckminster_3.6/director/director -vm
/home/svw/.hudson/tools/JDK-5.0/bin/java -d
/home/svw/.hudson/tools/Buckminster_3.6/buckminster -p Buckminster -r
"http://download.eclipse.org/tools/buckminster/headless-3.6,
http://download.eclipse.org/tools/buckminster/headless-3.6/,
http://download.cloudsmith.com/buckminster/external-3.6" -installIU
"org.eclipse.equinox.p2.director.feature.feature.group,
org.eclipse.buckminster.psf.feature.feature.group,
org.eclipse.buckminster.emma.headless.feature.feature.group,
org.eclipse.buckminster.pde.headless.feature.feature.group,
org.eclipse.buckminster.subclipse.headless.feature.feature.g roup,
org.eclipse.buckminster.maven.headless.feature.feature.group ,
org.eclipse.buckminster.cmdline.product,
org.eclipse.buckminster.core.headless.feature.feature.group,
org.eclipse.buckminster.git.headless.feature.feature.group,
org.eclipse.buckminster.cvs.headless.feature.feature.group"
Installing org.eclipse.equinox.p2.director.feature.feature.group
1.2.1.v20100819-2107.
Installing org.eclipse.buckminster.psf.feature.feature.group 1.0.0.r11564.
Installing org.eclipse.buckminster.emma.headless.feature.feature.group
0.9.0.r11564.
Installing org.eclipse.buckminster.pde.headless.feature.feature.group
1.2.1.r11567.
Installing
1.1.0.r11440.
Installing org.eclipse.buckminster.maven.headless.feature.feature.group
1.2.0.r11564.
Installing org.eclipse.buckminster.cmdline.product 1.2.1.r11564.
Installing org.eclipse.buckminster.core.headless.feature.feature.group
1.3.1.r11564.
Installing org.eclipse.buckminster.git.headless.feature.feature.group
1.0.360.r11564.
Installing org.eclipse.buckminster.cvs.headless.feature.feature.group
1.1.0.r11564.
Installation failed.
Cannot complete the install because one or more required items could not
be found.
Software being installed: Buckminster - Team Project Set (PSF) support
1.0.0.r11564 (org.eclipse.buckminster.psf.feature.feature.group
1.0.0.r11564)
Missing requirement: Buckminster - Team Project Set (PSF) support
1.0.0.r11564) requires
'org.eclipse.buckminster.core.feature.feature.group 0.0.0' but it could
not be found
Application failed, log file location:
/home/svw/.hudson/tools/Buckminster_3.6/director/configurati on/1282402427843.log
Peter
Re: Hudson plugin fails to install buckminster [message #554705 is a reply to message #554580] |
Tue, 24 August 2010 03:11  |
Hi Peter,
Am 23.08.2010 17:32, schrieb Peter Kullmann:
> I had to setup a temporary buckminster install (without the psf feature)
> in order to keep my builds running. But as soon as the new plugin will
> be available I will switch over.
Sorry, you missunderstood me. I did not release a new version of the
plugin, I only updated the file that's telling the plugin which features
to install into a fresh buckminster. This file is fetched from
hudson-ci.org, so it will get distributed automatically and you don't
need to update anything manually.
http://hudson-ci.org/updates/hudson.plugins.buckminster.Buck minsterInstallation.BuckminsterInstaller.json
What I meant with 'takes 6 hours to 2 days' is
1. The time the hudson infrastructure needs to push the changes in
subversion to the URL above
2. The time your running hudson waits before checking for changes in the
update files
The file was updated pretty quickly yesterday so the installation should
work again for you. If not, it's a matter of a few hours before your
hudson checks for updates of the installer files again.
> BTW: Cool plugin, thanks for it!
Glad you like it, you are welcome :)
Johannes
FUDForum. Page generated in 0.04644 seconds
