[ATL] Running ATL programmatically [message #553898] |
Thu, 19 August 2010 11:19 |
Jorge Carballo Messages: 7 Registered: July 2010 |
I have an ATL transformation that run correctly, but when I use that with Command-line interface from Dennis Wagelaar ... fails.
A simple transformation runs OK, but when the ATL transformation have some more complicated, like ...
result <- s.getNameResultSet()->collect(e | thisModule.Result(e))
the ATL file runs perfectly, but the Command-line interface from Dennis Wagelaar fails when I call "launch", specifically at AtlLauncher.class:
ASMInterpreter ai = new ASMInterpreter(asm, asmModule, env, asmParams);
org.eclipse.m2m.atl.engine.vm.VMExceptionorg.eclipse.m2m.atl.engine.vm.VMException
NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.debug(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny,org.eclipse.m2m.atl.engine.vm.nativelib.ASMString)
args = ['']
Java Stack:
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDebugger.java:167)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(StackFrame.java:95)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(StackFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(ClassNativeOperation.java:73)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:130)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java:78)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:251)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation.java:173)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:357)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:346)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:216)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:127)
at org.eclipse.m2m.atl.engine.vm.AtlLauncher.launch(AtlLauncher.java:92)
at com.example.atl.commandline.Main.run(Main.java:340)
at com.example.atl.commandline.Main.main(Main.java:109)
Caused by: java.lang.IllegalArgumentException: wrong number of arguments
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(ClassNativeOperation.java:69)
... 32 more
I use these libraries:
ATL-parser.jar
ebnfextractor.jar
ebnfinjector.jar
org.antlr.runtime_3.0.0.v200803061811.jar
org.atl.eclipse.engine.jar
org.eclipse.core.jobs_3.5.0.v20100515.jar
org.eclipse.core.resources_3.6.0.v20100526-0737.jar
org.eclipse.core.runtime_3.6.0.v20100505.jar
org.eclipse.core.runtime.compatibility_3.2.100.v20100505.jar
org.eclipse.emf.common_2.6.0.v20100614-1136.jar
org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar
org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
org.eclipse.equinox.common_3.6.0.v20100503.jar
org.eclipse.m2m.atl.common_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.core_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.core.emf_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.drivers.emf4atl_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.engine_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.engine.emfvm_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.engine.source_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.engine.vm_3.1.0.v201006150240.jar
org.eclipse.m2m.atl.engine.vm.source_3.1.0.v201006150240.jar
org.eclipse.osgi_3.6.0.v20100517.jar
vm.jar
Jorge.
Re: [ATL] Running ATL programmatically [message #554788 is a reply to message #553898] |
Tue, 24 August 2010 12:11 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
Op 19-08-10 13:19, Jorge schreef:
> org.eclipse.m2m.atl.engine.vm.VMExceptionorg.eclipse.m2m.atl .engine.vm.VMException
> org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.debug(org. eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse.m2m.atl.eng ine.vm.nativelib.ASMOclAny,org.eclipse.m2m.atl.engine.vm.nat ivelib.ASMString)
> args = ['']
> Java Stack:
> at
> org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
> Regards,
> Jorge.
Hmm, looks like different methods are invoked from the command line and in
Eclipse. Can you file a bug report, in which you attach/link the Eclipse
project that allows us to reproduce your issue?
Thanks already,
Dennis
Re: [ATL] Running ATL programmatically [message #758475 is a reply to message #554788] |
Wed, 23 November 2011 12:15 |
Pedro Messages: 1 Registered: November 2011 |
Is there a solution for this this problem?
Im trying to run a Atl launch programatically with two differents input models with the same metamodel and im getting the same error.
Instead of having the same cause im having this:
argument type mismatch. Is there a solution for that?
What can be wrong?
NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMSet org.eclipse.m2m.atl.engine.vm.nativelib.ASMSet.asSet(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse.m2m.atl.engine.vm.nativelib.ASMSet)
args = [OrderedSet {IN!pedro}]
Java Stack:
at ATLTransformation.launchTransformation(ATLTransformation.java:87)
at ATLTransformation.main(ATLTransformation.java:101)
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
... 23 more
[Updated on: Wed, 23 November 2011 12:18] Report message to a moderator
FUDForum. Page generated in 0.03351 seconds
