Home » Eclipse Projects » Rich Client Platform (RCP) » NullPointerException in ApplicationActionBarAdvisor
NullPointerException in ApplicationActionBarAdvisor [message #553552] Tue, 17 August 2010 19:43 Go to next message
I am getting the following error in my ApplicationActionBarAdvisor class.
	at org.eclipse.ui.internal.actions.CommandAction.init(CommandAction.java:201)
	at org.eclipse.ui.internal.actions.CommandAction.<init>(CommandAction.java:86)
	at org.eclipse.ui.internal.actions.CommandAction.<init>(CommandAction.java:65)
	at org.eclipse.ui.actions.ActionFactory$WorkbenchCommandAction.<init>(ActionFactory.java:85)
	at org.eclipse.ui.actions.ActionFactory$41.create(ActionFactory.java:1146)
	at com.xmlnamespace.operatorpanel.isymphonyclientrcp.ApplicationActionBarAdvisor.makeActions(ApplicationActionBarAdvisor.java:27)
	at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:147)
	at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3481)
	at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:404)
	at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
	at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1731)
	at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1729)
	at org.eclipse.ui.internal.Workbench$60.runWithException(Workbench.java:3362)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
	at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at com.xmlnamespace.operatorpanel.isymphonyclientrcp.Application.start(Application.java:26)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
This error seems to happen randomly and once it happens if i close my RCP app the workbench widow closes however the process is still running and I have to kill it manually.
Here is my make actions method:
    protected void makeActions(IWorkbenchWindow window) {
	        exitAction = ActionFactory.QUIT.create(window); <<<<<<<< EXCEPTION HERE
	        register(exitAction);
	        aboutAction = ActionFactory.ABOUT.create(window);
	        register(aboutAction);
			preferencesAction = ActionFactory.PREFERENCES.create(window);
			register(preferencesAction);
I traced the exception in the source and the exception seems to be thrown at this line in the CommandAction Class:
	protected void init(IServiceLocator serviceLocator, String commandIdIn,
			Map parameterMap) {
		if (handlerService != null) {
			// already initialized
			return;
		handlerService = (IHandlerService) serviceLocator
				.getService(IHandlerService.class);
		ICommandService commandService = (ICommandService) serviceLocator
				.getService(ICommandService.class);
		ICommandImageService commandImageService = (ICommandImageService) serviceLocator
				.getService(ICommandImageService.class);
		createCommand(commandService, commandIdIn, parameterMap);
		if (parameterizedCommand != null) {
			setId(parameterizedCommand.getId());
			try {
				setText(parameterizedCommand.getName());
			} catch (NotDefinedException e) {
				// if we get this far it shouldn't be a problem
			parameterizedCommand.getCommand().addCommandListener(
					getCommandListener());
			parameterizedCommand.getCommand().setEnabled(
					handlerService.getCurrentState());
			setEnabled(parameterizedCommand.getCommand().isEnabled());
			setImageDescriptor(commandImageService.getImageDescriptor(
					commandIdIn, ICommandImageService.TYPE_DEFAULT));<<<<<<<<<<<<<<EXCEPTION HERE
			setDisabledImageDescriptor(commandImageService.getImageDescriptor(
					commandIdIn, ICommandImageService.TYPE_DISABLED));
			setHoverImageDescriptor(commandImageService.getImageDescriptor(
					commandIdIn, ICommandImageService.TYPE_HOVER));
Could anyone explain to me why this would be happening?
Best Regards,
Mike
[Updated on: Tue, 17 August 2010 19:55] by Moderator
Re: NullPointerException in ApplicationActionBarAdvisor [message #553613 is a reply to message #553552] Wed, 18 August 2010 04:19 Go to previous message
On 18/08/10 5:13 AM, Michael Yara wrote:
> Hello,
> java.lang.NullPointerException
> at
> org.eclipse.ui.internal.actions.CommandAction.init(CommandAc tion.java:201)
> at
Sounds like there is no ICommandImageService is registered. Its
actually registered when the workbench is created. Not sure why it
should be null.
Can you create a bug with steps to reproduce this?
http://bit.ly/NewBugInPlatformUI
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Previous Topic:Multiple windows for Eclipse RCP apps
Next Topic:load plugin programmatically
Current Time: Sat Nov 08 12:16:59 EST 2025
Powered by FUDForum. Page generated in 0.02623 seconds
